[EMFStore]ResourcePersister throws NotSerializableException before commit [message #1250590] |
Wed, 19 February 2014 06:37  |
I'm using EMFStore v1.1.0 (together with ECP v1.1.1, but that seems not relevant here to me). When committing a NotSerializableException is thrown when the ChangePackage gets persisted prior to the actual commit.
More precise the commit includes a MultiAttributeOperation (containing a EStructuralFeatureImpl.ContainmentUpdatingFeatureMapEntry to be added) whose "referencedValues" feature value should get converted to a String by the EMFStoreResourceHelper.convertToString() method, but the NotSerializableException gets thrown as the aforementioned ContainmentUpdatingFeatureMapEntry is not serializable.
Please see the stack trace below:
java.io.NotSerializableException: org.eclipse.emf.ecore.impl.EStructuralFeatureImpl$ContainmentUpdatingFeatureMapEntry
at java.io.ObjectOutputStream.writeObject0(ObjectOutputStream.java:1183)
at java.io.ObjectOutputStream.writeObject(ObjectOutputStream.java:347)
at org.eclipse.emf.ecore.impl.EFactoryImpl.convertToString(EFactoryImpl.java:688)
at org.eclipse.emf.ecore.impl.EcoreFactoryImpl.convertEJavaObjectToString(EcoreFactoryImpl.java:937)
at org.eclipse.emf.ecore.impl.EcoreFactoryImpl.convertToString(EcoreFactoryImpl.java:209)
at org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.convertToString(XMLHelperImpl.java:1610)
at org.eclipse.emf.emfstore.internal.common.EMFStoreResourceHelper.convertToString(EMFStoreResourceHelper.java:51)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveDataTypeMany(XMLSaveImpl.java:1789)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveFeatures(XMLSaveImpl.java:1518)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveFeatures(XMLSaveImpl.java:1219)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveElementID(XMLSaveImpl.java:2711)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveElement(XMLSaveImpl.java:1176)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveElement(XMLSaveImpl.java:1037)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveContainedMany(XMLSaveImpl.java:2412)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveFeatures(XMLSaveImpl.java:1548)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.writeTopObject(XMLSaveImpl.java:678)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.traverse(XMLSaveImpl.java:586)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.save(XMLSaveImpl.java:251)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doSave(XMLResourceImpl.java:365)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(ResourceImpl.java:1430)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(ResourceImpl.java:999)
at org.eclipse.emf.emfstore.internal.common.model.util.ModelUtil.saveResource(ModelUtil.java:432)
at org.eclipse.emf.emfstore.internal.client.model.impl.ResourcePersister.saveDirtyResources(ResourcePersister.java:169)
at org.eclipse.emf.emfstore.internal.client.model.impl.ResourcePersister.inspectChanges(ResourcePersister.java:333)
at sun.reflect.GeneratedMethodAccessor14.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Method.java:606)
at org.eclipse.emf.emfstore.internal.common.observer.ObserverBus$ProxyHandler.notifiyObservers(ObserverBus.java:274)
at org.eclipse.emf.emfstore.internal.common.observer.ObserverBus$ProxyHandler.invoke(ObserverBus.java:260)
at com.sun.proxy.$Proxy24.inspectChanges(Unknown Source)
at org.eclipse.emf.emfstore.internal.client.model.controller.CommitController.commit(CommitController.java:136)
at org.eclipse.emf.emfstore.internal.client.model.controller.CommitController.run(CommitController.java:102)
at org.eclipse.emf.emfstore.internal.client.model.controller.CommitController.run(CommitController.java:1)
at org.eclipse.emf.emfstore.internal.client.model.connectionmanager.ServerCall.run(ServerCall.java:249)
at org.eclipse.emf.emfstore.internal.client.model.connectionmanager.SessionManager.executeCall(SessionManager.java:120)
at org.eclipse.emf.emfstore.internal.client.model.connectionmanager.SessionManager.execute(SessionManager.java:61)
at org.eclipse.emf.emfstore.internal.client.model.connectionmanager.ServerCall.execute(ServerCall.java:269)
at org.eclipse.emf.emfstore.internal.client.model.impl.ProjectSpaceBase.commit(ProjectSpaceBase.java:359)
at org.eclipse.emf.emfstore.internal.client.model.impl.api.ESLocalProjectImpl$10.call(ESLocalProjectImpl.java:391)
at org.eclipse.emf.emfstore.internal.client.model.impl.api.ESLocalProjectImpl$10.call(ESLocalProjectImpl.java:1)
at org.eclipse.emf.emfstore.client.util.RunESCommand$WithException$1.doRun(RunESCommand.java:60)
at org.eclipse.emf.emfstore.internal.client.model.util.EMFStoreCommandWithResult.commandBody(EMFStoreCommandWithResult.java:31)
at org.eclipse.emf.emfstore.internal.client.model.util.AbstractEMFStoreCommand.execute(AbstractEMFStoreCommand.java:64)
at org.eclipse.emf.common.command.BasicCommandStack.execute(BasicCommandStack.java:78)
at org.eclipse.emf.emfstore.internal.client.model.changeTracking.commands.EMFStoreBasicCommandStack.execute(EMFStoreBasicCommandStack.java:72)
at org.eclipse.emf.emfstore.internal.client.model.util.AbstractEMFStoreCommand.aRun(AbstractEMFStoreCommand.java:108)
at org.eclipse.emf.emfstore.internal.client.model.util.EMFStoreCommandWithResult.run(EMFStoreCommandWithResult.java:59)
at org.eclipse.emf.emfstore.client.util.RunESCommand$WithException.runWithResult(RunESCommand.java:77)
at org.eclipse.emf.emfstore.internal.client.model.impl.api.ESLocalProjectImpl.commit(ESLocalProjectImpl.java:385)
at org.eclipse.emf.emfstore.internal.client.ui.controller.UICommitProjectController.doRun(UICommitProjectController.java:199)
at org.eclipse.emf.emfstore.internal.client.ui.controller.UICommitProjectController.doRun(UICommitProjectController.java:1)
at org.eclipse.emf.emfstore.internal.client.ui.common.MonitoredEMFStoreAction$1.run(MonitoredEMFStoreAction.java:70)
at org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:464)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:372)
at org.eclipse.jface.dialogs.ProgressMonitorDialog.run(ProgressMonitorDialog.java:507)
at org.eclipse.ui.internal.progress.ProgressMonitorJobsDialog.run(ProgressMonitorJobsDialog.java:275)
at org.eclipse.ui.internal.progress.ProgressManager.run(ProgressManager.java:1162)
at org.eclipse.emf.emfstore.internal.client.ui.common.MonitoredEMFStoreAction.execute(MonitoredEMFStoreAction.java:67)
at org.eclipse.emf.ecp.emfstore.internal.ui.handler.CommitProjectHandler.execute(CommitProjectHandler.java:50)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:290)
at org.eclipse.ui.internal.handlers.E4HandlerProxy.execute(E4HandlerProxy.java:76)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:231)
at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:212)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:131)
at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:171)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.executeItem(HandledContributionItem.java:831)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.handleWidgetSelection(HandledContributionItem.java:724)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.access$7(HandledContributionItem.java:708)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem$4.handleEvent(HandledContributionItem.java:647)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4169)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3758)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1053)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:942)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:588)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:543)
at org.eclipse.emf.ecp.application3x.Application.start(Application.java:30)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
Can you tell me any solutions for this problem? Maybe provide some kind of handler for this specific object type to be serialized at any point? Or is there some possibility to configure EMFStore to use another way of persistence?
Thank you very much in advance!
Ferdinand
Re: [EMFStore]ResourcePersister throws NotSerializableException before commit [message #1251578 is a reply to message #1250590] |
Thu, 20 February 2014 06:17  |
Hi Ferdinand,
thanks for the report. Can you open up a Bug Report and provide us with
a model and/or test case, such that we are able to reproduce the
erroneous behavior?
Thanks!
Edgar
Am 19.02.2014 15:05, schrieb Ferdinand Meier:
> Hello,
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
> at
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
> at
> at
> at
> at
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
> at
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
> at
> at
> at
> at
> persistence?
> Ferdinand
Edgar Mueller
Get Professional Eclipse Support: http://eclipsesource.com/munich
FUDForum. Page generated in 0.03879 seconds
