0 Problems, "Errors exist in a required project" [message #1250002] |
Tue, 18 February 2014 16:22  |
Earlier today I downloaded and installed "Eclipse IDE for C/C++ Developers" from the official website as well as Cygwin (g++, make, gdb, etc packages). In an attempt to test it to make sure that I set everything up correctly, I made a new project and copy/pasted files from a previous program that will compile and run successfully in the Codeblocks IDE.
No errors are indicated by Eclipse. "0 items" is displayed in the "Problems" window (Window->Show View-> Problems). No lines of code are highlighted to indicate errors of any kind apart from some spell-checking indicators. The project will build successfully (Project -> Build Project), and from reviewing the console window (Window->Show View->Console) everything appears to have been built as expected. This is the only project open or even in the workspace at the time.
However, when I attempt to run the project using the appropriate button, I am prompted that "Errors exist in a required project. Continue launch?"
I have tried rebuilding the project several times (Project->Clean...->OK, Project->Build Project), but this error persists. Furthermore, the first two statements in main.cpp are a cout prompting the user for input and a cin statement. If I click yes to continue, the project terminates with "exit value:-1073741515," there is no prompt for user input in the console, and there is no pause to accept user input.
I am at a loss and would greatly appreciate any assistance. Thanks ^_^
Attachment: Untitled.png
(Size: 267.33KB, Downloaded 761 times)
FUDForum. Page generated in 0.04067 seconds
