Home » Eclipse Projects » Eclipse Scout » Authentication and Authorization in RAP
Authentication and Authorization in RAP [message #1248801] Mon, 17 February 2014 12:24 Go to next message
I have an application available in SWT and RAP.
Currently i have authentication working on SWT client with a custom security filter (that connects with a remote service).
On RAP, i would like to have a similar solution compared with SWT, meaning the only place that knows to talk with remote services is the server (it requires a bunch of legacy libraries and configuration).
Is it possible to put the RAP client talking with server security in order to authenticate the webuser?
Will this mechanism impact scout Authorization mechanisms??
Thanks for your help
Re: Authentication and Authorization in RAP [message #1249829 is a reply to message #1248801] Tue, 18 February 2014 12:28 Go to previous messageGo to next message
Hi again,
For RAP authentication i have decided to create a new custom filter that extends basicsecurityfilter.
protected int negotiate...{
      if (login(aCredentialsSet)) {
          //updates the holder with a new principal with user name
          return STATUS_CONTINUE_WITH_PRINCIPAL;
  protected boolean login(final SortedSet<Credential> theUpdatedCredentials) {
      try {
        // try to do a login based on credentials specified as application arguments
        Authentication aAuthenticationResult = SERVICES.getService(IAuthenticationService.class).doAuthenticate(theUpdatedCredentials);
        //Return a status depending on your query in your IPersistenceService
        if (aAuthenticationResult.isAuthenticated()) {
          return true;
      catch (Exception e) {
        // there was an error authenticated the user
    return false;
This filter will call a scout service, but it is not able to get it and returns null, causing the login to fail.
On the server side everything seems ok, so i believe the problem is on the client accesing the service.
Basicly my question now is: How to call scout service from a securityfilter??
Re: Authentication and Authorization in RAP [message #1249837 is a reply to message #1249829] Tue, 18 February 2014 12:39 Go to previous messageGo to next message
I have found a topic with a similar issue, but applied to SWT - server.
http://www.eclipse.org/forums/index.php/m/1223485/?srch=scout+service+from+filter#msg_1223485
I have also tried to implement a equivalent solution for RAP, but also without any success Sad
    ClientJob job = new ClientJob("security-filter-job", new ClientSession(), true) {
      public IStatus runNow(IProgressMonitor monitor) {
        try {
            return Status.OK_STATUS;
        return Status.CANCEL_STATUS;
    IStatus status = job.runNow(new NullProgressMonitor());
    try {
      job.throwOnError();
    catch (ProcessingException e) {
      // FIXME Auto-generated catch block
      e.printStackTrace();
    //Use the status to decide if the user is valid or not.
    if (status.isOK())
      return true;
    return false;
Re: Authentication and Authorization in RAP [message #1251753 is a reply to message #1249837] Thu, 20 February 2014 10:10 Go to previous message
i have managed to have authentication working in RAP and SWT, both solutions using a custom scout service provided by the server.
SWT
Custom filter defined on the server that calls the scout service:
    ServerJob job = new ServerJob("security-filter-job", new ServerSession()) {
      protected IStatus runTransaction(IProgressMonitor monitor) throws Exception {
        //Here you can call serviceS.getservice(..)
        Authentication anAuthentication = SERVICES.getService(IAuthenticationService.class).doAuthenticate(theUpdatedCredentials);
        //Return a status depending on result
        if (anAuthentication.isAuthenticated())
    if (status.isOK()) {
      return true;
    return false;
For RAP, it was not easy. The only option i have found was to create a custom authentication servlet in scout server (declared in server plugin.xml) and then call it from the RAP security filter.
For the servlet code i have:
public class AuthenticationServlet extends ServiceTunnelServlet {
   * The long <code>serialVersionUID</code>.
  private static final long serialVersionUID = 1L;
  protected void doGet(HttpServletRequest theReq, HttpServletResponse theResp) throws IOException, ServletException {
    // creates the credential set with mandatory credentials (user and pass)
    SortedSet<Credential> aCredentialsSet = new TreeSet<Credential>();
    // fill the empty credentials with values received in http headers
    if (fillCredentials(aCredentialsSet, theReq)) {
          theResp.setStatus(HttpServletResponse.SC_OK);
          return;
    theResp.setStatus(HttpServletResponse.SC_UNAUTHORIZED);
   * Invokes the custom server security service to perform the authentication based on credentials.
   * @param theUpdatedCredentials
   * @return true if login has success
      return true;
    return false;
In RAP security filter :
public class DialogSecurityFilter extends AbstractChainableSecurityFilter {
   * the prop used to control the filter
   * The String <code>PROP_BASIC_ATTEMPT</code>.
  public static final String PROP_BASIC_ATTEMPT = "BasicSecurityFilter.basicAttempt";
  protected int negotiate(HttpServletRequest theReq, HttpServletResponse theResp, PrincipalHolder theHolder) throws IOException, ServletException {
    String aUser;
    // get user name and password from request and try to efectuate the login
    if ((aUser = login(theReq)) != null) {
        theHolder.setPrincipal(new SimplePrincipal(aUser));
    int attempts = getBasicAttempt(theReq);
    if (attempts > 2) {
      return STATUS_CONTINUE_CHAIN;
    else {
      setBasicAttept(theReq, attempts + 1);
      theResp.setHeader("WWW-Authenticate", "Basic realm=\"" + getRealm() + "\"");
   * Call a server authentication servlet responsable for user authentication
   * @param theReq
   * @return the user name if login succeeds
  protected String login(HttpServletRequest theReq) {
    URL aAuthServlet = null;
    try {
      String h = theReq.getHeader("Authorization");
      if (h != null && h.matches("Basic .*")) {
        String[] a = new String(Base64Utility.decode(h.substring(6)), "ISO-8859-1").split(":", 4);
        String user = unescapeColon(a[0].toLowerCase());
        String pass = unescapeColon(a[1]);
        // TODO we should get server base url from configuration
        aAuthServlet = new URL("localhost/example_server/auth?user=" + user + "&pass=" + pass);
        HttpURLConnection servletConnection = (HttpURLConnection) aAuthServlet.openConnection();
        servletConnection.setRequestMethod("GET");
        servletConnection.connect();
        int aResultStatus = servletConnection.getResponseCode();
        if (aResultStatus == HttpServletResponse.SC_OK) {
          return user;
      // TODO
    return null;
The code is still a proof of concept, so if you have a better suggestion please tell me.
Previous Topic:Cannot Close Outline using OutlineViewButton
Next Topic:Desktop Extensions - Location of a Menu
Current Time: Sat Jul 19 23:35:31 EDT 2025
Powered by FUDForum. Page generated in 0.05244 seconds
