status bar + infinitest obscures text position [message #1248939] |
Mon, 17 February 2014 15:30  |
I'm not that much of a newcomer... but I recently started using Infinitest.
This has a very wide indicator bar in Eclipse's status bar.
The other 3 components in the status bar are (usually) the words "Writable", "Insert" and the line number and character position (of the cursor).
Unfortunately, in a good display on my screen, although there is plenty of room for all 4 elements, the status bar does not extend all the way to the right, meaning that the line number + character pos are hidden. I have to make the screen wider than I want to make them visible again. They are the only things of the 4 elements I'm interested in (altho occasionally the Infinitest bar).
Annoyingly it seems it is not possible to configure the Eclipse status bar, or to modify the way the Infinitest indicator bar. Nor, it appears, is there any way to make sure the display area of the status bar extends all the way to the right.
Can anyone suggest 1) anything I might do to configure the status bar or Infinitest indicator 2) know if I can make the font in the status bar smaller so that everything takes up less space 3) alter some obscure Eclipse setting somewhere to tweak this.
In particular it seems a bit bonkers that the status bar won't extend all the way to the right of the Eclipse window...
FUDForum. Page generated in 0.08328 seconds
