Manually add swt.jar will make SWT controls invisible [message #124671] |
Fri, 12 May 2006 12:26  |
Originally posted by: javacard.hotmail.com
Creat a new project,then open project properties->java Build Path->Libraries tab page.If add swt.jar via 'Add JARs' or 'Add External JARs',the SWT controls would NOT be parsed correctly,which means invisible in the VE editor.If add swt.jar via 'Add Library'->SWT,then it works fine.
It only takes some inconvienence for me,not so serious a bug.
Xu Song
Re: Manually add swt.jar will make SWT controls invisible [message #612880 is a reply to message #124671] |
Fri, 12 May 2006 13:02  |
You mustn't add SWT.jar itself. You need to use the SWT Library
Container. That is how it works.
> Xu Song
Rich Kulp
FUDForum. Page generated in 0.05020 seconds
