Home » Archived » BIRT » BIRT Dataset Usage (Is it possible to pass entire dataset into the IN CLAUSE of another Data set)
BIRT Dataset Usage [message #1243860] Tue, 11 February 2014 09:50 Go to next message
My requirement is to get the list of ids from one database suppose sybase and then I wish to pass this list of ids to another database for processing using NOT IN clause in the sql query.
For example: I have two separate database. I will get the records from one db in one data set and then pass the entire records to another data set.
select * from second_table where id not in (select id from first_database_table)
Re: BIRT Dataset Usage [message #1243944 is a reply to message #1243860] Tue, 11 February 2014 12:27 Go to previous message
Moving this to the BIRT forum.
Previous Topic:Slot ID in BIRT
Next Topic:Birt on windows mobile
Current Time: Sun Jul 20 07:13:34 EDT 2025
Powered by FUDForum. Page generated in 0.04515 seconds
