Browser object - IE MaxConnectionsPerServer difference [message #1187698] |
Fri, 15 November 2013 03:27  |
I notice, then when using the SWT Browser object, the property 'maxConnectionsPerServer' is always limited to 2, while when retrieving the same property in IE native, this isn't the case.
I've already configured the registry settings according to the MS documentation: Microsoft KB282402, and added them also for the 'javaw.exe' process with value '6'(Content of HKEY_LOCAL_MACHINE\Software\Microsoft\Internet Explorer\MAIN\FeatureControl\FEATURE_MAXCONNECTIONSPER1_0SERVER & ..\FEATURE_MAXCONNECTIONSPERSERVER: iexplore.exe with value 6, javaw.exe with value 6), and tried pushing the setting with the Group Policy. For the native iexplore.exe process this always works - but it doesn't when doing the request via the SWT browser.
In attachment:
- My testpage, which I execute from the SWT browser, and from iexplore.exe
- Source of my testclass with the SWT browser
Question:
- Is there any hard limit of 2 coded within? Is it possible to change it? We're running a real-time application (which uses 1 of the 2 available AJAX connections with long running queries, and need to raise the limit to get this working with the SWT browser).
Thanks ahead,
Re: Browser object - IE MaxConnectionsPerServer difference [message #1404515 is a reply to message #1256550] |
Sat, 02 August 2014 13:38  |
Daniel
Very interesting but cannot get it to work. However what ~I want is a bit unusual. I want a single threaded browser so I can ensure each request sent is matched with the right reply.
I've got IE v11 running 32 bit Windows 7 Professional.
If Daniel or anyone has any thoughts or update on this it would be greatly appreciated.
Cheers Nigel
FUDForum. Page generated in 0.25752 seconds
