Home » Modeling » TMF (Xtext) » Custom Code Overridden - Generator Model
Custom Code Overridden - Generator Model [message #1243193] Mon, 10 February 2014 11:53 Go to next message
Hey,
I use a mwe script to generate code...e.g.:
 component = org.eclipse.emf.mwe2.ecore.EcoreGenerator
    generateCustomClasses = false
    genModel = "platform:/.../gen.genmodel"
    srcPath = "platform:/.../src"
However, this causes my custom added code (in the Java classes) to be overriden, even though I have @generated NOT or just add a Method in the class.
Any ide how this can be avoided? Thanks!
Re: Custom Code Overridden - Generator Model [message #1243206 is a reply to message #1243193] Mon, 10 February 2014 12:11 Go to previous messageGo to next message
Create a class PersonImplCustom extends PersonImpl in the same
package and customize the code there
http://christiandietrich.wordpress.com/2013/07/26/use-of-ecoregenerator
-to-customize-emfs-generated-java-classes/
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext at itemis dot de
Re: Custom Code Overridden - Generator Model [message #1243783 is a reply to message #1243206] Tue, 11 February 2014 07:38 Go to previous messageGo to next message
I'm aware of this option, but I'm talking about code that are added in the "original" Java classes. This code is overriden, which is not desirable. Is there an option or something than can be used in the mwe-script?
Re: Custom Code Overridden - Generator Model [message #1243788 is a reply to message #1243783] Tue, 11 February 2014 07:49 Go to previous messageGo to next message
you have to write your own/subclass EcoreGenerator
and reenable jmerge there
Re: Custom Code Overridden - Generator Model [message #1243848 is a reply to message #1243788] Tue, 11 February 2014 09:30 Go to previous messageGo to next message
why is this not enabled by default?
Re: Custom Code Overridden - Generator Model [message #1243849 is a reply to message #1243848] Tue, 11 February 2014 09:32 Go to previous message
cause the component is made for generation gap and not protected regions
Previous Topic:different instances of editor were given
Next Topic:Generated ecore models refer to Xbase using relative paths
Current Time: Sun Jul 20 14:17:35 EDT 2025
Powered by FUDForum. Page generated in 0.05949 seconds
