SWTBot not running on 'Eclipse 4 Application' [message #1243086] |
Mon, 10 February 2014 08:52 |
I am trying SWTBot 2.1.1 for the Application created using eclipse wizard "Eclipse 4 Application" in Juno. As standalone, my application is up and running.
When trying to test through SWTBot using "SWTBot test" (Run as option), following was observed,
1. My Application is running through "SWTBot Test"
2. My JUnit test code thread is not reached after the application got started. So SWTBot did not run.
3. Once i close the application manually, the main thread also closes completely.
Pls help me know, how to test the "Eclipse 4 Application" using SWTBot.
NOTE: I am able to test using SWTBot if the application is created using "Plugin development" wizard.
FUDForum. Page generated in 0.02984 seconds
