scope of ECP demo application with RAP/EMFStore [message #1242919] |
Mon, 10 February 2014 04:03  |
I was wondering if EMFStore integration in the demo application with RAP is within scope for ECP 1.2? Or if it will be in future. It is already well integrated into the RCP version of the demo application.
I noted the following from a previous post (http://www.eclipse.org/forums/index.php/t/632837/)
"- There might be some parts of the default EMFStore UI, which are not
fully compatible with RAP, probably minor things and fixable, please report.
- You should test what happens, if there are two or more users at the
same time. RAP uses one VM for all user sessions. If there is a
singleton within the EMFStore framework, which should be user specific,
but is currently not, then this leads to unexpected behavior. RAP
provides so called "Session singletons" for this purpose, so these
problems are usually easy to fix. I am currently not aware any concrete
ocurrences and I would be very interested to know, if there are any."
Neil
Re: scope of ECP demo application with RAP/EMFStore [message #1243064 is a reply to message #1242919] |
Mon, 10 February 2014 08:18   |
the scope for 1.2 is to make the ECP demo application in general
available on RAP. However, as stted in the news group, there are most
likely open issues for the EMFStore integration (for other data
providers, too). We consider to put this on the road map of 1.3. It
would help us a lot to have a list of open issues from a pilot user.
Jonas
Am 10.02.2014 10:03, schrieb Neil Mackenzie:
> Hello,
> report.
> Neil
FUDForum. Page generated in 0.04120 seconds
