Home » Modeling » TMF (Xtext) » EMF Editor Runtime Exception
EMF Editor Runtime Exception [message #1242883] Mon, 10 February 2014 02:58
I have a Eclipse Rcp application,and a editor based on ecore model using xtext.Everything works fine in my application and the executable also works fine in my system.But when it is tested in another ubuntu machine(whenever a new editor is created using the tool) it gives the below exception.
15363 [main] ERROR org.eclipse.xtext.ui.editor.CompoundXtextEditorCallback - different instances of editor were given.
java.lang.IllegalStateException: different instances of editor were given.
at org.eclipse.xtext.ui.editor.AbstractDirtyStateAwareEditorCallback.beforeDispose(AbstractDirtyStateAwareEditorCallback.java:37)
at org.eclipse.xtext.ui.editor.CompoundXtextEditorCallback.beforeDispose(CompoundXtextEditorCallback.java:69)
at org.eclipse.xtext.ui.editor.XtextEditor.dispose(XtextEditor.java:501)
at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:705)
at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:465)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:595)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:313)
at org.eclipse.ui.internal.presentations.PresentablePart.setVisible(PresentablePart.java:180)
at org.eclipse.ui.internal.presentations.util.PresentablePartFolder.select(PresentablePartFolder.java:270)
at org.eclipse.ui.internal.presentations.util.LeftToRightTabOrder.select(LeftToRightTabOrder.java:65)
at org.eclipse.ui.internal.presentations.util.TabbedStackPresentation.selectPart(TabbedStackPresentation.java:473)
at org.eclipse.ui.internal.PartStack.refreshPresentationSelection(PartStack.java:1245)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.java:1198)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:1597)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:493)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:103)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:479)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:112)
at org.eclipse.ui.internal.EditorSashContainer.addEditor(EditorSashContainer.java:63)
at org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorAreaHelper.java:225)
at org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAreaHelper.java:213)
at org.eclipse.ui.internal.EditorManager.createEditorTab(EditorManager.java:808)
at org.eclipse.ui.internal.EditorManager.openEditorFromDescriptor(EditorManager.java:707)
at org.eclipse.ui.internal.EditorManager.openEditor(EditorManager.java:666)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched(WorkbenchPage.java:2942)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:2850)
at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPage.java:2842)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:2793)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2789)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2773)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2756)
at com.harmanbecker.mocca.core.actions.OpenFileAction.openEditor(OpenFileAction.java:218)
at com.harman.sys.oscar.hmood.sysd.ui.tools.handler.UIUtils.openInNewEditor(UIUtils.java:63)
at com.harman.sys.oscar.hmood.sysd.ui.tools.handler.UIUtils.openInNewEditor(UIUtils.java:51)
at com.harman.sys.oscar.hmood.sysd.ui.tools.handler.UIUtils.openInNewEditor(UIUtils.java:82)
at com.harman.sys.oscar.hmood.sysd.ui.tools.handler.NewFileHandler.run(NewFileHandler.java:107)
at com.harman.sys.oscar.hmood.sysd.ui.tools.handler.NewFileHandler.execute(NewFileHandler.java:77)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:293)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:476)
at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:508)
at org.eclipse.ui.internal.handlers.HandlerService.executeCommand(HandlerService.java:169)
at org.eclipse.ui.internal.handlers.SlaveHandlerService.executeCommand(SlaveHandlerService.java:241)
at org.eclipse.ui.menus.CommandContributionItem.handleWidgetSelection(CommandContributionItem.java:829)
at org.eclipse.ui.menus.CommandContributionItem.access$19(CommandContributionItem.java:815)
at org.eclipse.ui.menus.CommandContributionItem$5.handleEvent(CommandContributionItem.java:805)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1258)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3588)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3209)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2701)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2665)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2499)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:679)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:668)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
It couldn't figure out the problem as it works in some machines and in other it gives this problem.the required java version is also bundled with the application,so it shouldn't be a problem
Anudeep.
Previous Topic:Evicting cache based on a particular element value being modified
Next Topic:Version of dependencies when using xtext
Current Time: Sat Jul 19 23:26:15 EDT 2025
Powered by FUDForum. Page generated in 0.05143 seconds
