Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [CDO] Does CDO fit in our scenario?
[CDO] Does CDO fit in our scenario? [message #124001] Fri, 30 May 2008 02:21 Go to next message
I just made my first steps with CDO and now I am asking myself if it
fits in our current development scenario or not. Maybe a more
experienced CDO user can provide some feedback? The scenario is as
follows..
We already developed an Eclipes/EMF based application, whose main
purpose is to let the user capture some data, apply some processing
and generate a report. Currently, we use the generated EMF Editors to
let the user capture data (the input is modeled with EMF), and we use
BiRT to generate the reports (the output is also modeled with EMF).
Beside that, we plan to use CDO to enable multiple users capturing
data at the same time in the future, but this is not our priority
right now.
Furthermore, we now need to develop a Web based application in the
very same context. Due to some constraints, we cannot integrate it
with our Eclipse/EMF based application right now, but we plan to do
this in the near future. This Webapplication has a normal GUI and
stores data in a MySQL database.
Now I wonder if it is possible (and especially if it makes sense) to
use CDO to generate the database based on the already existing EMF
models? If the Webapplication stores data in this database, could we
then use CDO to "export" this data into a normal EMF resource like we
have it in our Eclipse/EMF based application?
Many thanks for your help!
Best,
Marc
Re: [CDO] Does CDO fit in our scenario? [message #124105 is a reply to message #124001] Fri, 30 May 2008 08:44 Go to previous messageGo to next message
Hi Marc,
Eike can really answer this question better than I can but Eike is away for 2 days. So I will do my
best. Reading your requirement I would use the cdo-hibernate-teneo integration to create the
database. The database and tables are then very common hibernate-like tables (so with a version
column and a dtype column if single-class inheritance). From the web app you could then also also
use hibernate to talk to the same database.
Although the web and cdo application then don't use the same hibernate instance the database should
at least take care of concurrency (through transactions etc.).
If the webapp does not use hibernate then the main thing which you should take care of is increment
the version number in the version column when storing/updating an instance (through the webapp).
Then cdo-hibernate should work fine on the same database.
gr. Martin
Marc Moser wrote:
> follows..
> right now.
> Best,
> Marc
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [CDO] Does CDO fit in our scenario? [message #124414 is a reply to message #124001] Sat, 31 May 2008 13:42 Go to previous message
Originally posted by: stepper.sympedia.de
--------------090503010600060901020308
Marc,
Apart from the fact that it is possible to to export the data that is
already in the database, why might you want to do that? In case this
exported data is further modified, how would you get it back
synchronized with the database?
If I understood correctly, you will have Eclipse/EMF based rich clients,
as well as a web application and you want both to operate on the same
central data instances, right? With CDO and Net4j you can setup
different network connection types for a single repository. For example
you can configure a TCP Acceptor that accepts connections from your rich
client and in addition a JVMAcceptor to accept in process connections
from your web application. Look at the following diagram Is that what
you asked for?
TwoTransports
Cheers
/Eike
Marc Moser schrieb:
> follows..
> right now.
> Best,
> Marc
Content-Type: multipart/related;
boundary="------------060602050505010208070304"
--------------060602050505010208070304
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Marc,<br>
<br>
synchronized with the database?<br>
<br>
clients, as well as a web application and you want both to operate on
the same central data instances, right? With CDO and Net4j you can
setup different network connection types for a single repository. For
example you can configure a TCP Acceptor that accepts connections from
your rich client and in addition a JVMAcceptor to accept in process
connections from your web application. Look at the following diagram Is
that what you asked for?<br>
<br>
<img alt="TwoTransports" src="cid:part1.03000005.06040203@sympedia.de"
height="720" width="960"><br>
<br>
Cheers<br>
/Eike<br>
<br>
<br>
Marc Moser schrieb:
<blockquote cite="mid:m55v34l4veeqcf8csm635vi2l0ho0jiqg9@4ax.com"
type="cite">
<pre wrap="">Hi,
follows..
right now.
Best,
Marc
</pre>
</blockquote>
</body>
</html>
Content-Type: image/jpeg;
name="TwoTransports.jpg"
Content-ID: <part1.03000005.06040203@sympedia.de>
Content-Disposition: inline;
filename="TwoTransports.jpg"
/9j/4AAQSkZJRgABAQEAYABgAAD/2wBDAAoHBwgHBgoICAgLCgoLDhgQDg0N Dh0VFhEYIx8l
JCIfIiEmKzcvJik0KSEiMEExNDk7Pj4+JS5ESUM8SDc9Pjv/2wBDAQoLCw4N DhwQEBw7KCIo
Ozs7Ozs7Ozs7Ozs7Ozs7Ozs7Ozs7Ozs7Ozs7Ozs7Ozs7Ozs7Ozs7Ozs7Ozs7 Ozs7Ozv/wAAR
CALQA8ADASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcI CQoL/8QAtRAA
AgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS 0fAkM2JyggkK
FhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1 dnd4eXqDhIWG
h4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW 19jZ2uHi4+Tl
5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcI CQoL/8QAtREA
AgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMz UvAVYnLRChYk
NOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0 dXZ3eHl6goOE
hYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU 1dbX2Nna4uPk
5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwD2aiiigAooooAKKKKACiii gAooooAKKKKA
CiiigAorL8Ra1H4f0S41GRQ5jACRlsb2JwB/nsDXBP4j8a6xEJIZbXToZRld ijO0+5yf5VrT
oynqjOdSMNGeh6hrWmaSB9vv4LYsMhZHAY/QdTWNL8RfCsfH9plyOyQSH9du K4y38NW3mNca
hLJf3L8tJKxOT/X8avJpenp92xtx7+Uv+FdKw0erMHXl0RvP8TvDCkYuJ3/3 YG/rUTfFTw4r
EAXjD1EI/wAaylsrRfu2sI+kYp4giUYESAegUVX1emL20y8/xY8PqRi3v3/3 Yk/q1CfFjw82
cwX6f70S8/k1VFVV+6oH0FIyK33lB+op/V6YvbTNJPij4bYZLXS+xh/wNSr8 S/C5AJvJR7GB
uP0rFa2gY5aGMn3UU02NmxybSAn1MYpfVoD9vM6e18eeGLuURRatGGPTzUeM fmwArfV1dA6M
GVhkEHIIrzG40PTLlCr2US5/iRdp/MVRh0G+0uQy6LrFxat12E8N9ccH8Qai WFX2WUq76o9e
orzOPxT46tl2tbWF2RxvYYJ9+GX+VSjx34sQ5k0C2Yf7LH/4o1l9Wmae2gej 1n6rrul6JEJN
SvY7cN90HJZvooyT+VcBN4i8b6lkxta6ZG3ZVBbH47jn8qqW3hyHzzdalM+o XTHLPMSRn6Hr
+NXHDP7TJlXX2Tob34paeJfK0nT7nUnHcDYp+nBP6VVPxI1hzmPwrKo9GlbP /oApIoYoE2Qx
JGv91FAH6U+t1QproYurPuR/8LA8SHkeHEA7Zc03/hOfF3/QCtf++j/8VU1F P2NPsL2k+5D/
AMJz4u/6AVr/AN9H/wCKoHjrxaDltBtiB1AY5/8AQqmop+yp9g9pPuR/8LA8 S/8AQuR/99ml
HxE19RiTwyWPqsjY/kafRS9jT7B7WfcQfEnV0/1nhSZs9Nkrf/EGpI/iiYmB 1Lw9eWsX99W3
foVX+dMpCARgjINL2FPsP2s+51GleL9B1jatpqMQkP8AyylOx8+mD1/DNbVe V3nh7TLzJa2E
bn+KL5T/AIVBbLr/AIZljuNKv5ryBW+ezlOVK+wz+owaxlhv5WaRr90et0Vx mifESC/1FNO1
Swk0y4k4jLtlGPYZIGM12dcsoSg7M6IyUldBRRRUlBRRRQAUUUUAFFFFABRR RQAUUUUAFFFF
ABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAU
UUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFF
ABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAVS1fV ING0q41G5z5c
CbiB1Y9AB9SQKu1xPxVmZPDEECHme7RSPUAMf5gVdOPNJImb5YtnMMdT8YXE epazLttFO6C0
Thcev/1+p9hW2AAAAMAdBSRoIokjXhUUKPwp1eokkrI89tvVhRRVTUtSg0u1 +0XG8qWCgIMk
n/IpgW6K57/hNNN/54XX/fC//FUf8Jppv/PC6/74X/4qiwjoaK57/hNNN/54 XX/fC/8AxVH/
AAmmm/8APC6/74X/AOKosB0NFc9/wmmm/wDPC6/74X/4qj/hNNN/54XX/fC/ /FUWA6Giue/4
TTTf+eF1/wB8L/8AFUf8Jppv/PC6/wC+F/8AiqLAdDRXPf8ACaab/wA8Lr/v hf8A4qj/AITT
Tf8Anhdf98L/APFUWA6Giue/4TTTf+eF1/3wv/xVH/Caab/zwuv++F/+KosB 0NFc9/wmmm/8
8Lr/AL4X/wCKo/4TTTf+eF1/3wv/AMVRYDoaK57/AITTTf8Anhdf98L/APFU f8Jppv8Azwuv
++F/+KosB0NFc9/wmmm/88Lr/vhf/iqP+E003/nhdf8AfC//ABVFgOhornv+ E003/nhdf98L
/wDFUf8ACaab/wA8Lr/vhf8A4qiwHQ0Vz3/Caab/AM8Lr/vhf/iqP+E003/n hdf98L/8VRYD
oaK57/hNNN/54XX/AHwv/wAVR/wmmm/88Lr/AL4X/wCKosBq6npdtqtv5Vwp yvKOvVTVJdU8
U+FrcTxamt9Zw4BinGeOg9x+Bq9pupQarbG4tw4UMVIcYIP+TU88EdzA8Eoy kilWHtSaT0aG
m1sd5p17HqWnW19D/q7iJZFGc4yM4/CrNeaeEPEE/hrUE8PaqxazmfFpcdlJ PQ+xJ/An0Nel
15lSm4Ssd8JqSuFFFFZlhRRWJ4k8V6d4Xjge+WdzcFgiQqCTjGTyQO4/Omk5 OyE2krs26K4b
/hbWgf8APnqP/fuP/wCLo/4W1oH/AD56j/37j/8Ai609jU7Ee0h3O5orhv8A hbWgf8+eo/8A
fuP/AOLo/wCFtaB/z56j/wB+4/8A4uj2NTsHtIdzuaK4b/hbWgf8+eo/9+4/ /i6P+FtaB/z5
6j/37j/+Lo9jU7B7SHc7miuG/wCFtaB/z56j/wB+4/8A4uj/AIW1oH/PnqP/ AH7j/wDi6PY1
Owe0h3O5orhv+FtaB/z56j/37j/+Lo/4W1oH/PnqP/fuP/4uj2NTsHtIdzua K4b/AIW1oH/P
nqP/AH7j/wDi6P8AhbWgf8+eo/8AfuP/AOLo9jU7B7SHc7miuG/4W1oH/Pnq P/fuP/4uj/hb
Wgf8+eo/9+4//i6PY1Owe0h3O5orhv8AhbWgf8+eo/8AfuP/AOLo/wCFtaB/ z56j/wB+4/8A
4uj2NTsHtIdzuaK4b/hbWgf8+eo/9+4//i6P+FtaB/z56j/37j/+Lo9jU7B7 SHc7miuG/wCF
taB/z56j/wB+4/8A4uj/AIW1oH/PnqP/AH7j/wDi6PY1Owe0h3O5orhv+Fta B/z56j/37j/+
Lo/4W1oH/PnqP/fuP/4uj2NTsHtIdzuaK4b/AIW1oH/PnqP/AH7j/wDi6P8A hbWgf8+eo/8A
fuP/AOLo9jU7B7SHc7misvw/4gsvEmnG+sRKsayGNllUBgwAPYkdCK1Kzaad mWmmroKKKKQw
ooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACi iigAooooAKKK
KACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoooo AKKKKACiiigA
rgvii25dFh/v3ZP8h/Wu9rgPicT9u8PL2Nyx/VK2ofxEZVfgY2iiivSOIK57 xp/yB4v+vgf+
gtXQ1z3jT/kDxf8AXwP/AEFqBHplFFFeadwUUUUAFFFU9W1OHR9Mmv7hXaKE DIQZJyQBj8TT
SvoBcorJj8QRrdQ297ZXVg1w2yJp1Xa7f3cqTg+xxmr4uHN+bb7NKEEe/wA/ jYTnG3rnPfpT
aaFdE9FFUk1Avrcum+VgR26zeZu65YjGPwpWGXaKKq6hqVvpsKyTliZGCRxo u55G9AKNwLVF
ZtrrDT3SW8+m3to0mdjSoCrYGSMqSBx64pbPVXu7G6uVtWZreaWIRRnLPsJH GccnFPlYro0a
KZC5lhSRo2jZ1BKNjK5HQ470+kMKKKhu7uCxtZLq5fy4Yl3O2CcD6DmgCaig EEZHQ0UgCiii
gAooooA8z8F/8geX/r4P/oK10Nc94L/5A8v/AF8H/wBBWuhr02cJkeJbGW90 v9wpaaFxIuOv
vj/PavQPC2vxeI9DivkUo4Plyof4XAGfw5B/GuWqH4f3H9meKNT0VjiOcefC O2R2H4H/AMdr
nxEOaF+xtRlaVu56PRRRXnHaFcH8Qv8AkY/Cn/X4f/Q4q7yuD+IX/Ix+FP8A r8P/AKHFWtH4
1/XQzq/CdNRRRTEFFFRXM32a1ln8tpPKQvsT7zYGcD3pgS0VVi1G3l0pdSDF bdofOy3GFxnn
8KbpOpwaxpsV/bBhHLnAcYIIOCD+VFmF0XKKqaZqMOq2Yu7cN5TOyqTj5trF cjHbirTHapPo
M0WsAtFU9Ivzqmk218Y/KM6btmc4/GrlDVgCisibxAF1O5sLfTry7ktdnmmE JhdwyPvMM8Vd
07UbfVLQXNsW27irK6lWVgcEEHoRTaaFdFqiiipGFFFFABRRRQAUUUUAFFFF ABRRRQBznwl/
5Fa5/wCv5/8A0BK7muG+Ev8AyK1z/wBfz/8AoCV3NKt/EY6fwIKKKKyNAooo oAKKKKACiiig
AooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAC iiigAooooAKK
KKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigArz7 4mE/2t4bHb7Q
/wD6FHXoNee/Ek517w6uekrnH/AkrfD/AMRGVb4GLRRRXonEFc940/5A8X/X wP8A0Fq6Gue8
af8AIHi/6+B/6C1Aj0yiiivNO4KKKKACuf8AHf8AyJt//wBs/wD0YtdBWfr2 lf23o0+ned5H
nbf3m3djDBumR6VUXaSbFJXTMi8+2X+s6bZ6zDDbQrL9ohMDlxLKg4UsQNvB JxjnHtWhFNKf
F9xCZHMQsY2CbjtB3tzj1qxq+mnU7WNI5hBNDKksUuzdsZT6ZHUZHXvTk07Z rcupebnzLdYf
L29MMTnOff0qrqwrO5kaTbt4gsW1We9vIpJpH8kRTMghVWKqNvQnjJ3A5pZr N7zxnNGbmWKI
WEfmCJtrP874G4cgfSrSaLe2ryxWGqfZ7SV2fyzAGeMscnYxOBz6g4q5Hp2z WpNR87PmW6w+
Xt6YYnOc+/pTctXYVijoMrRalq2lmeWZLOWNozKxdlV0DY3Hk8560l2qP410 4SgHy7SZosjo
2VBx74q5Z6ULTWNR1Hzi5vvK+TbjZsXb175o1XSI9T8mQTPb3VsxaC4jxuQn g9eCD3FK6uOz
saFcrbyPF4S12SJ2R0mvCrKcEHc3INbNpY6ktwkt9qnniPOI4YRGrcYy3JJ/ MCol0Pbo2oad
9p/4/XmbzNn3PMJPTPOM0KyB3ZU1S+lW30eyWSdft3EskIJk2qm4gHsScc9c ZxUlhHPa6zGl
qt8bKWJvNF0zMEcY2kFiTyMjHTgVcu9JFza2qLO0U9mQ0MygHBAxyD1BBORU llBqUcpe+vop
l24VIrfyxn1JLEn9KLqwrO5jaXYzatb3rXWoXmEvJ44VimZPLAc85ByevfgA Diql5OdZ+Gov
p5ZWlW3JYqxXcykqcgdRweOldJpenf2bDNH5vmebcSTZ24xubOOvaqdp4cit /Cv9gvcNIhjd
DKF2n5iTnHPc0+ZX+YcrsX9Oso7G28uKSZwx3EzStIeg7sTxVqqunw3kFvsv bqO5kB4ZIvLA
GPTJ5q1Wb3LQUUUUgCiiigDzPwX/AMgeX/r4P/oK10Nc94L/AOQPL/18H/0F a6GvTZwhWbbt
5HxG0WYcFwyH3yGH9a0qybs+X4y8PP63IX/x5f8AGol8LKjuj1eiiivJPRCu D+IX/Ix+FP8A
r8P/AKHFXeVwfxC/5GPwp/1+H/0OKtaPxr+uhnV+E6aiiimIKCARgjINFFAH HxbovD0+gAne
t/8AYlBbJMTNu4/7Zk/lU7XR0OHxBaxggx/6Rar1yZRgAD/roDx71pPoCt4k XV/tBCBQTb7e
GkClQ+c/3TjpRqWgLqGr2l+bgxrBgSxBM+cAwZQTnjDDPetuZGdmZ0ym1udN 8PB7pbeKz8yX
7NuDyFSFA3LyBnJOParulrcwXt3AouzYGJXia6JLK/IZQW5I6HmreoaY91cw 3lrcm2u4FZVf
buVlOMqy9xkDuKltIL5Fk+23kc7Pwojh8tV/Uk/nUuWg0tTm9F0mW48H29x/ aV1HOIN0DRyF
Eix0G0HDdOc5z7V0WjXcl/o1ndygeZNCrvgYGSOay4PDd9baUmlway62pTZJ mEF/fY2flB56
5xnit23gjtbaO3hXbHEgRF9ABgUTaYRVjmLVtSXxj4h/s+K1kJ+zbvtErJj9 3xjCnPf0pltM
bXw3r9v80OpQCWa6ZG6yOu4OpHQenfitOTQ7+PWL3UbDVEt/tvl+Yj23mY2L tGDuFSf2An9m
6hbm5d7jUVYTXLqCSSu0cDAwB0FVzL8hWZSuGm0Xw9Prb3c9xeG2BO92MYZs YwnQYOOeuM5P
JpNU02bS9Gl1K21G8N7bJ5zPJOzpLjlgUztweegGOK25dPhuNLOn3HzxNF5T Y4yMYz7VmvoV
/dQLZX2redZKRuRYAkkqg8KzZPHrgDNJSQ2h01xLb+JLCZpJPs19btCYy3yL IPnU47EjcPwq
ho+r3EV7f3F/MWtbmJ7y1yeFjRipA/4Dsb/gVbGt6SdWsFgiuDayxyLJFMqb jGw9sjtkfjVX
UfDMV7ZWNpFObdLRfKOF3GSLADJnPGcDn2oTjbUGnfQpNFqS6Dpsk/2ydZHM 18tu5EuGBYAY
OcAkDA5wKfeanBa+H4zpV1cOJ7pLcSMWkkiLNhh83IIGcA98VtXsF5J5bWN2 luyZBV4t6N06
jIPGOx71SXw9G9hcQXFy7z3MwnedFCFZBjaVHOANo9ffNCkuoWfQqxQTWmo2 baeNSaN5Nlyt
y7upTB+b5icEHHT1NJBaTaprurRT310ltBMnlxQysmCY15yDnHt0ySTmtO1t tVS4VrrUoZYV
z8kdtsZ/TJ3H9AKfZ6d9kv76683f9skV9u3GzChcZzz0pcwWLtFFFZlhRRRQ Bznwl/5Fa5/6
/n/9ASu5rhvhL/yK1z/1/P8A+gJXc0q38Rjp/AgooorI0CiiigAooooAKKKK ACiiigAooooA
KKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAo oooAKKKKACii
igAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACvO/iId3inQE9Nx /Uf4V6JXnPj4
58a6IvpGT+p/wrfD/wARGVb4CWiiivROIK57xp/yB4v+vgf+gtXQ1l6/pcur WCwQuiOsgf58
4PBHb60CO/orz77R43/6DNr/AN+1/wDjdH2jxv8A9Bm1/wC/a/8AxuuT2Eu5 0+1ieg0V599o
8b/9Bm1/79r/APG6PtHjf/oM2v8A37X/AON0ewl3D2sT0GivPvtHjf8A6DNr /wB+1/8AjdH2
jxv/ANBm1/79r/8AG6PYS7h7WJ6DRXn32jxv/wBBm1/79r/8bo+0eN/+gza/ 9+1/+N0ewl3D
2sT0GivPvtHjf/oM2v8A37X/AON0faPG/wD0GbX/AL9r/wDG6PYS7h7WJ6DR Xn32jxv/ANBm
1/79r/8AG6jnvvGdtA88ut2qpGpZj5a9P+/dHsJdw9rE9ForzTT9Y8Yanai5 t9Zt9pJBDRIC
D6H5KtfaPG//AEGbX/v2v/xun7CXcPaxPQaK8++0eN/+gza/9+1/+N0faPG/ /QZtf+/a/wDx
ul7CXcPaxPQaK8++0eN/+gza/wDftf8A43R9o8b/APQZtf8Av2v/AMbo9hLu HtYnoNFeffaP
G/8A0GbX/v2v/wAbo+0eN/8AoM2v/ftf/jdHsJdw9rE9Borz77R43/6DNr/3 7X/43R9o8b/9
Bm1/79r/APG6PYS7h7WJ6DRXn32jxv8A9Bm1/wC/a/8Axuj7R43/AOgza/8A ftf/AI3R7CXc
PaxKngv/AJA8v/Xwf/QVroay/D+lzaTYPBO6O7SF/kzgcAd/pWpXWcwVkagN /ivw4g6i8Vvw
Dp/hWvWZGvnfELQ4v7u5/wAgT/7LUy0iyo7o9UoooryT0Qrg/iF/yMfhT/r8 P/ocVd5XK+Nf
DOpa/NplzpdzBBPYSM4M2cZO0gjAPQr0IrWk0ppsiom46GpRXL/2B8RP+g9p 3/fA/wDjVH9g
fET/AKD2nf8AfA/+NVpyr+ZGd32Z1FFcv/YHxE/6D2nf98D/AONUf2B8RP8A oPad/wB8D/41
Ryr+ZBd9mdRRXL/2B8RP+g9p3/fA/wDjVH9gfET/AKD2nf8AfA/+NUcq/mQX fZnUUVy/9gfE
T/oPad/3wP8A41R/YHxE/wCg9p3/AHwP/jVHKv5kF32Z1FFcv/YHxE/6D2nf 98D/AONUf2B8
RP8AoPad/wB8D/41Ryr+ZBd9mdRRXL/2B8RP+g9p3/fA/wDjVUdYt/HWhaZL qF7r+niKLHCo
CzE9AB5fWmopuyaBya6HbUVxmmWPjzVtOgv7TxBpzQzruXKDI9Qf3XUHirf9 gfET/oPad/3w
P/jVJxS+0g5n2Z1FFcv/AGB8RP8AoPad/wB8D/41R/YHxE/6D2nf98D/AONU cq/mQXfZnUUV
y/8AYHxE/wCg9p3/AHwP/jVH9gfET/oPad/3wP8A41Ryr+ZBd9mdRRXL/wBg fET/AKD2nf8A
fA/+NUf2B8RP+g9p3/fA/wDjVHKv5kF32Z1FFcv/AGB8RP8AoPad/wB8D/41 R/YHxE/6D2nf
98D/AONUcq/mQXfZnUUVy/8AYHxE/wCg9p3/AHwP/jVH9gfET/oPad/3wP8A 41Ryr+ZBd9mS
/CX/AJFa5/6/n/8AQErua5zwR4duvDOiSWV5LDJLJcNLmEkqAVUY5A/u10dZ VWnNtGlNNRSY
UUUVmWFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAB RRRQAUUUUAFF
FFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUU UAFFFFABRRRQ
AUUUUAFebeM2E3xF02Nf+WVpub25f/63516TXl2oyfa/iXqcnVYIVjHscL/X NdOGXvmFd+6a
FFFFd5yBRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABXMeJ7qW8nGlW38CGWc+g AyB/X8q6eql/
DEtndyiNBI0DBnCjJGD3oEcn4cupdMuIDL/x632VB7Bgcf5+tdvWJ4Yhil0C 382NH2OzLuUH
B3HkVt02AUUUUhhRRRQAUUUUAFFFFABRRRQAUUUUAFUdFXzvifZn/njasf8A x1h/7NV6q3hJ
fN+Jd4f+eVl/8R/jUVPgZUPiR6VRRRXlHoBRRRQAUUUUAFFFFABRRRQAUUUU AFFFFABXlHxB
1K51/ULqys8/YdGTfO3YyEhfzBOB/wACr1euY8cWtvb+DdXkht4onmVWkZEA LncvJI6mtaMl
GaM6ivE5n4dalc6NfxaHfZ8jUYVubRu2SMkfjg/ivvXptYXhW1tpfDOjXElv E80NqnlyMgLJ
lecHqK3aKslKVwpq0QooorI0CiiigAooooAKKKKACiiigAooooAKKKKACiii gAooooAKKKKA
CiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAK KKKACiiigAoo
ooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACvKL RvN8Y+IZf7ty
U/JmH9K9XryPQm83U9ZuP+el4x/Vj/WuvC7s56+yNuiiiu05QooooAKKKKAC iiigAooooAKK
KKACiiigAqtqRxpd2R2hf/0E1ZrB1XV2hurvTp4gkclsxhkz947Tx/Mfh70C JvCox4fg9y//
AKEa2K5TRdYa2stO0+3iE0srsXGfuLuP/wBc/hXV02AUUUUhhRRRQAUUUUAF FFFABRRRQAUU
UUAFReBF8zxzrMv92FU/Vf8A4mpaPhsvma54hn9JUQH8X/wFZVv4bLpfGj0G iiivMO8KKKKA
CiiigAooooAKKKKACiiigAooooAK57x7/wAiTqX+4v8A6GtdDXPePf8AkSdS /wBxf/Q1q6fx
omfwss+Ef+RR0r/r1T+VbFY/hH/kUdK/69U/lWxSn8TCPwoKKKKkoKKKKACi iigAooooAKKK
KACiiigAooooASvIPCTebZ3U/wDz0uWP6A/1r1u5LC1lKglghwB3OK8g8Fhv 7MnYk7TNgD8B
Xbhepy4jodHRRRXWc4UyWaKCMyTSJGg6s7AAfiafXP8AjT/kDxf9fA/9BagR q/2rpv8A0ELX
/v8AL/jR/aum/wDQQtf+/wAv+Na3/CCeGv8AoG/+R5P/AIqj/hBPDX/QN/8A I8n/AMVWPt4m
vspGT/aum/8AQQtf+/y/40f2rpv/AEELX/v8v+Na3/CCeGv+gb/5Hk/+Ko/4 QTw1/wBA3/yP
J/8AFUe3iHspGT/aum/9BC1/7/L/AI0f2rpv/QQtf+/y/wCNa3/CCeGv+gb/ AOR5P/iqP+EE
8Nf9A3/yPJ/8VR7eIeykZP8Aaum/9BC1/wC/y/40f2rpv/QQtf8Av8v+Na3/ AAgnhr/oG/8A
keT/AOKo/wCEE8Nf9A3/AMjyf/FUe3iHspGT/aum/wDQQtf+/wAv+NH9q6b/ ANBC1/7/AC/4
1rf8IJ4a/wCgb/5Hk/8AiqP+EE8Nf9A3/wAjyf8AxVHt4h7KRk/2rpv/AEEL X/v8v+NZHiM6
dqWnlo761M8PzJiZcn1HWut/4QTw1/0Df/I8n/xVH/CCeGv+gb/5Hk/+Ko9v EPZSOH8KJYWc
T3lzd26TSfKqtKoKr9M966L+1dN/6CFr/wB/l/xrW/4QTw1/0Df/ACPJ/wDF Uf8ACCeGv+gb
/wCR5P8A4qj28Q9lIyf7V03/AKCFr/3+X/Gj+1dN/wCgha/9/l/xrW/4QTw1 /wBA3/yPJ/8A
FUf8IJ4a/wCgb/5Hk/8AiqPbxD2UjJ/tXTf+gha/9/l/xo/tXTf+gha/9/l/ xrW/4QTw1/0D
f/I8n/xVH/CCeGv+gb/5Hk/+Ko9vEPZSMn+1dN/6CFr/AN/l/wAaP7V03/oI Wv8A3+X/ABrW
/wCEE8Nf9A3/AMjyf/FUf8IJ4a/6Bv8A5Hk/+Ko9vEPZSMn+1dN/6CFr/wB/ l/xo/tXTf+gh
a/8Af5f8a1v+EE8Nf9A3/wAjyf8AxVH/AAgnhr/oG/8AkeT/AOKo9vEPZSMn +1dN/wCgha/9
/l/xo/tXTf8AoIWv/f5f8a1v+EE8Nf8AQN/8jyf/ABVH/CCeGv8AoG/+R5P/ AIqj28Q9lIox
TRTxiSGRJEPRkYEfmKfXPeC/+QPL/wBfB/8AQVroa2MgqX4VrvstVuv+et3j P0Gf/ZqrXEnl
W0sn9xC35CtT4WweV4PD4/11w7/Xov8A7LWGIf7s2or3zsaKKK847QooooAK KKKACiiigAoo
ooAKKKKACiiigArnvHv/ACJOpf7i/wDoa10Nc74/bb4I1I/7CD/x9aun8a9S Z/Cy14R/5FHS
v+vVP5VsVkeE12+EtKH/AE6Rn/x0Vr0pfEwjsjiP+Eo1n7Jj7Fd4/t77J9ux B5XlfbfL27d2
/wC58mdmc8571e0m31W61DW7SbxLqLLZ3CQQt5VqGUGKKQt/qcE5Zh0xg9M8 1tf2Lp/2X7L9
n/c/avte3e3+t83zd2c/3+cdO2McVPBZW9rPczwx7ZLuQSzNuJ3sEVAeenyo o49Kko4lNW1W
Pwj4ZvbjW9RMurTxtczQWkUsqq1vI+xEWI8blB+6TjPOK7DRpL6XS4X1FAly d24YwSu47SR2
JXBI7Emki0XT4LbT7aO32xaYQbRd7HyyEZBznn5WYc56+tX6ACiiigAooooA KKKKACiiigAo
oooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACii igAooooAKKKK
ACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA KKKKACiiigAo
oooAhuyy2c5X7wjYj64ryfweANE47ytn9K9ZuATbSgdSh/lXkvg8/wDElP8A 12b+QrtwuzOX
Ebo3qKKK6znCue8af8geL/r4H/oLV0Nc940/5A8X/XwP/QWoEemUUUV5p3BV O61jTLKbybrU
LaCTGdkkoU4+hq5WV4kijPh3UnMalvssnJHP3TVKzeonsWbXV9NvpfJtL+2n kxnZHKGOPXAp
brVdOsZBHd31vA5GQskqqf1pluI7bSI50iQMluG4GM4XNUfDFhD/AGHBdzKs 9zeIJ55XUFnZ
ufyGcYp2W4rs1bi+tLW3FxcXUMULEASO4CnPTmktL+zv1LWd3DcBeCYpA2Pr iuf8VQ2em2Oj
IkcVvaxarCxUAKij5ifoOppyzWWo+KLC40fZJ5KSC6uIV+TYR8qFhwTuwcds U+VWuLm1sbt3
qNjYBTeXkFvu+75sgXP51NDPFcxLNBKksbDKujAg/iKw/DdtHdx3Wq3Kia4u biQbnAOxFYqq
j0Ax+tXL+a30GweS0tIxJcTqqRoAgeVyFBP6Z+lJrW3UaelzTorDnvtY0qS2 lv2tbm2mlWGT
yImRoixwDyxyM8HvzT7nUdRfX5NLs44Aotkl86UEhMswPAPzdBgcd+e1LlY7 mzRWXpWoXU73
1peiI3NlIFZogQrgqGU4JJHB9e1ZkOs65ceHF1tY7ONI4fNaFlYtKAMsQQfl 6HHXtn0p8rFz
I6eisrUNXaG3shaiPz79gsJlPyINu4scdcAdO9MtNRu4tXj069mtrjz4mkil t1K4KkZUqSfU
EHPrS5WO6NiisO2v9X1VJLzTms47VZGSJJkYtLtJBJYH5ckHHBqpex6q3jOH 7PcWsZNk5TfC
zbV3JkHDDJz34p8ouY6eism5vr641V9N04wRtBGsk80yFwN2dqhQRzwTnNLp uo3b3d5p9/HG
Lm1CuJIgQkqNnBAJJB4IIpcrHc1aKw9Bv9X1a1tb+dbaC2kT5owpLucfeBzh RntzwPfjcpNW
dgTuFFFFIZ5n4L/5A8v/AF8H/wBBWuhrnvBf/IHl/wCvg/8AoK10NemzhKGu S+Tol2+cZiK/
nx/Wux8DW5tfBemRkY3RGT/vpi39a4DxfIV0cRDrLKq49ep/pXq9lbi0sbe2 UYWGJYwPoMVy
Yp+6kdFBatk9FFFcJ1hRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABXN/EH/kR9 S/3U/wDRi10l
c38Qf+RH1L/dT/0YtXT+NepM/hZe8K/8ippP/XnF/wCgitasnwr/AMippP8A 15xf+gitalL4
mOOyCiiipGFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFF FFABRRRQAUUU
UAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQ AUUUUAFFFFAB
RRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUANkBaNgOpBryDwYc6PJ 7Tt/Ja9hrx7w
eNlhcx9Ntw3HpwK7ML1ObEdDoKKKK7DmCue8af8AIHi/6+B/6C1dDXPeNP8A kDxf9fA/9Bag
R6ZRRRXmncFUdat5bvQ762gXfLLbuiLkDJKkAZNXqKadgILeHGnxQSr/AMsg jr+GCKxdPXWN
Dt1037AdQgiytvPHMinbngOGxjHqM9K6GimmKxg6xY6lqVtpJa3j86HUYp50 jcFUQFs8nGcA
j/Ct4AAYAwKKKG7gkc/bwanoM9xFbWR1CxmlaWMRyKjwljkrhsAjPfPepdQs dQ1bTFaWCGC7
t7lLi3j37gChyAzY6nkcdM1t0U+bqLl6GDcrqettbW8umtY28cySzvLKjFtp yFUKT3A5OOKt
x2c6+KJ70x/uHs0jV8jlgzEjHXoRWnRS5h2Maw0+6g8Q65eSRgQ3YgELbgd2 1CDx25PeorbT
buPwK2mPDi7Nk8Xl7h94qQBnOO/rW9RT5mHKjnZdFuP7L0RxbxTXWmRoHhkI w48vayg9M9D6
cVoaezyXBLaIbFVX/WOY8k+gCk/ritKik5XDlsc9p0WqaHbvplvpn2mJJHa3 mEyqgVmLYYHk
Yz2BqxqMN7BrlrqdtZtdqtu8DxxuqspJUg/MQMcVs0U+bW4uXSxhzW15puuX GpWlkbuK9jRZ
o43VXR0yAfmIBGDjrmpdNtLx7291O9iWCS5RY4oAwYoi5xuI4ySx6cD1rXop cw7Gb4etJ7HQ
LK1uU8uaKIK65BwfqOK0qKKTd3caVgooopAeZ+C/+QPL/wBfB/8AQVroa57w X/yB5f8Ar4P/
AKCtdDXps4THv4Re+KtCsX5ja4DOvqAR/QGvWa8stx5nxH0WP+6rN+jH+lep 1wYp+8kddDZj
Jpo7eF5ppFjjjUszscBQOpJrlbv4m+GrUkRzz3RH/PGE/wA2xVD4i61JKI/D Fiu64vAGmbPC
IDkD8cZPt9aoWWnW1lBHHFDGGRQC4QAsR3NOlQUo80gqVWnZGgfirYsP3OkX 7n3Cj+ppjfE+
Zs+T4ZvJOPlyxGfyU0yit/YU+xj7afca3xG1uUf6P4XeM/8ATWRj/wCyis26 1nxvq1yrGdNM
hxjbCR+fUkn8a1KKpUoLZCdSb3ZkGw8QyEGTxXfj1CO4/wDZqjOg3rjEuv37 jsDI3+NbdFXZ
diLswT4VRjl9SvGY9Tv60f8ACKRf9BC8/wC+xW9RTAwR4XCHMWqXiN6h6d/w jk//AEGr7/vs
/wCNblFAGINAvY/9Vr9+meuJDz+tL/Ympf8AQx3/AP38b/4qtqilZBdmMNK1 tBtj8Vaii+gk
f/4uqOt2OsQ6RPJc+Ir27iAG6GR3KtyOuWP16V09ZXiUg+H7vB6Bf/QhRZdg uyrptv4hbTbY
weI7mGIxLsjUthBjgdas/ZvE45Hii6yPUt/jVnSCP7HshnkwJ/IVdo5V2Hd9 zL/4q7/oZJPy
oDeMEO5fEbEjsw4/lWpRS5Y9g5pdzN+0eNf+hgT/AL4H/wATQLzxzHymvQsT /fjU/wA0NaVF
HJHsg5pdygut+PLVvMN9aXoH/LMxqM/kq/zq3H8QPElv/wAfnhxJcdfIcj/4 qpKKl0oPoUqk
11JE+KSJ/wAffh+9h9cHdj8wKtQfFPw5L/rPtcH/AF0hB/8AQSao1HJBDL/r Ykf/AHlBqHh6
bKVaZ1Vn4y8OX+PI1e2BPaVvLP5NitiOaKZd0UiSD1Vga8vn8P6Vcfes0U+s eU/lVNvB2m5B
SS5Qg5G1x/hUPCroy1XfVHr9FeQjwwYxiLVb1M9cP1qaOy8RWfFn4muto6LI WIH5kj9Kh4V9
GP6wux6xRXl41jx3AhjGoWs+RgOY1yP/AB0f1qMyeMZTuk8RlW9EUAfoBS+r S7le3j2PVKK8
q/4q7/oZJPypRceNU4TxCpx03ID+fy0fVZdxe3j2PVKK8uGqePUOf7YtZP8A ZMSf/ECnjX/H
acGeyk9yg/wFL6tPyH7eJ6dRXmo8XeOI+un6fLn1HT/x8VIPHfiuMkzaBbuo 6iNzn+ZpfV6g
/bQPRqK4rTPibps8wttVtZ9LmPGZBuT88Aj8Rj3rtAQyhlIIIyCO9YyhKPxI 0jJS2FoooqSg
KACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAK8g8MDb/aMfTbdN xXr9eU3do3hz
xvd2Tf8AHtqJM8B7Akk4/A5H5V14V6tHPXWiZq0UUV2nKFYfiy2nutKjW3he VlmDFUXJxgjp
+NblFAip/wAJ9qX/AEKt1/38b/4ij/hPtS/6FW6/7+N/8RVuis/ZQ7GntJdy p/wn2pf9Crdf
9/G/+Io/4T7Uv+hVuv8Av43/AMRVuij2UOwe0l3Kn/Cfal/0Kt1/38b/AOIo /wCE+1L/AKFW
6/7+N/8AEVboo9lDsHtJdyp/wn2pf9Crdf8Afxv/AIij/hPtS/6FW6/7+N/8 RVuij2UOwe0l
3Kn/AAn2pf8AQq3X/fxv/iKP+E+1L/oVbr/v43/xFW6KPZQ7B7SXcqf8J9qX /Qq3X/fxv/iK
D4/1EAk+FrkAdT5jf/EVbrA8Vak0FqLGDJmuAd2OoTv+f+NHsodg9pLuaUXx DvpoxJF4ZuJE
boyysQfx2U7/AIT7Uv8AoVbr/v43/wARXN+EdSaCX7BPkJNl4SfXuPxx+ldf R7KHYXtJdyp/
wn2pf9Crdf8Afxv/AIij/hPtS/6FW6/7+N/8RVuij2UOw/aS7lT/AIT7Uv8A oVbr/v43/wAR
R/wn2pf9Crdf9/G/+Iq3RR7KHYPaS7lT/hPtS/6FW6/7+N/8RR/wn2pf9Crd f9/G/wDiKt0U
eyh2D2ku5U/4T7Uv+hVuv+/jf/EUf8J9qX/Qq3X/AH8b/wCIq3RR7KHYPaS7 lT/hPtS/6FW6
/wC/jf8AxFH/AAn2pf8AQq3X/fxv/iKt0Ueyh2D2ku5h+Erae10qRLiF4maY sFdSDjCjp+Fb
lFZmp67aaYfKYmW4I+WJOT7Z9K0Mx+lDzPijp2OfKt3Jx2+V/wDEV6jXE+Af D15BNceINWjM
d3eLtiiIwY046jsTgceg967avOxElKeh20YtR1PLtUPmfFHU++y3Qf8Ajsf+ NaFZtwfM+I2t
P6Kq/ov+FaVd8PgXockviYUUVk61qd3ZTWdtYwRyz3chRA/TOQAOo6lvWqEa 1FZP2fxv/wBA
a1/7+L/8co+z+N/+gNa/9/F/+OVPNHuPll2Naisn7P43/wCgNa/9/F/+OUfZ /G//AEBrX/v4
v/xyjmj3Dll2Naisn7P43/6A1r/38X/45R9n8b/9Aa1/7+L/APHKOaPcOWXY 1qKyfs/jf/oD
Wv8A38X/AOOUfZ/G/wD0BrX/AL+L/wDHKOaPcOWXY1qKyfs/jf8A6A1r/wB/ F/8AjlH2fxv/
ANAa1/7+L/8AHKOaPcOWXY1q4vxBFNpdzdouWttQG7k9GBBP+fQ+1b32fxv/ ANAa1/7+L/8A
HKq6jo3jDVLX7PcaNbhcghllQEH2+enzx7hyy7FPw3FPqV5FeykrDZRCKIA9 TjB/x/EV1lYV
lpnjGwtEtoNFtgiDjMqZPufnqf7P43/6A1r/AN/F/wDjlHPHuHLLsa1FZP2f xv8A9Aa1/wC/
i/8Axyj7P43/AOgNa/8Afxf/AI5S5o9w5ZdjWorJ+z+N/wDoDWv/AH8X/wCO UfZ/G/8A0BrX
/v4v/wAco5o9w5ZdjWorJ+z+N/8AoDWv/fxf/jlH2fxv/wBAa1/7+L/8co5o 9w5ZdjWorJ+z
+N/+gNa/9/F/+OUfZ/G//QGtf+/i/wDxyjmj3Dll2Naisn7P43/6A1r/AN/F /wDjlH2fxv8A
9Aa1/wC/i/8Axyjmj3Dll2NaiszQNUl1awaeZER1kKHZnB4B7/WtOqEFFFFA BRRRQAUUUUAF
FFFAFa/sINRtWgnQEEcNjlT6ineEvFj6BL/YHiCXZCg/0W6bpt7KT6eh7dKn qC7sra+i8u5h
WVe2RyPoe1TOCmrMcZOLuj0WKWOeJZYZFkjcZV0OQR7Gn15v4E1R9D1ubw1e SEwTkyWbMeh9
Px/mPevSK82pBwlY7oT5lcKKKKzLCiiigAooooAKKKKACiiigAooooAKKKKA CiiigAooooAK
KKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoo ooAKKKKACuJ+
J2nSSaRbavbrmbTpgxI/uHGf1C/rXbVHPDFcwSQTIJIpFKujDhgeCKuEuWSZ Mo8yseeWtzHe
WsdxEcpIoI/wqas298O654Tu5v7Ps5NS0p2LoE5eP2IHP44wfaq9v4q0+WTy pxLayZwRKvAP
1/xr1IyUldHA04uzNqigHIyOlFMQUUUUAFFFFABRRRQAUUUUAFFFFABWXfaX bB7vUjuadrdl
GTwvy44rUqvqH/IOuf8Ari/8jQIw9C0u2v8ARrKWXcHt5WZGQ4P3uh9q6Ssf wp/yAIf95v8A
0I1sUMAooooGFFFFABRRRQAUUVBc31pZrm4uI4vZm5P4UAT0VizeLNKjB8uS SZuwRCMn8cVZ
07w1rvi2VZdQWTS9M6hOkkn4H+Z49jSlJRV2NJydkQXOp3d9qC6RoUX2i7b7 0g5WMdznpx61
2PhPwXBoCtd3jrd6lLy85GQnsuf59609C8NaX4dgMWnwbWb78rnLv9T/AEHF atcFWu5aR2Ou
nSUdXuFFFFc5seUWzed4z8Qy/wB24KfkxH9K1qxdHO7Xtfk/vXjf+hPW1Xrx 2R5r3CsTWP8A
kY/D3/X4P/Q0rbrE1j/kY/D3/X4P/Q0oewLc9Gooqlq98+maVPfJB55gXeU3 bcrnnn2GTXnp
X0O3Yu0VQ1XVE03R5dQCGYKoKIDy5YgKO/UkUsWqwyaEurkFYTb+eQeoG3JF OztcV0XqKrWF
091p1vdTReQ80auYyfuZGcUzVrt7HR7y8hCl4IHkTdyCQCRmlbWw76XLlFRW 0xmtoZGI3vGr
ED3FS0AFFY+u6/8A2M0AW2Nxvy8uGx5USkBn6c43DitcMCu4EYxnNFna4ri0 UmRnGRn0pe+K
QwopAQRkEH6Vl6dqN3e6feTCKJ5obiaKNM7VbaxAyefTrTsFzVopkLSNAjTK qSFQXVWyFOOQ
D3pwIIyCD9KAFopAwJwCCRVV9RgTVE05t3mvC0objaACBjr15osBboqASXP2 8xmGMWwjyJfM
+Ytnptx0x3zUxYA4JAJoAWijpSZGcZGfSkAtFFFAHmfgv/kDy/8AXwf/AEFa 6Gue8F/8geX/
AK+D/wCgrXQ16bOEKKKKQwooooAKKKKACiiigAooooAyPEVlLNax3toSt1Zt 5sbL1454/IH8
K9C8M67D4i0SG/jwHI2zIP4HHUf1HsRXKVT8HXg0DxncaXIdlrqQDQ+gccgf +hD8qwrw5o37
GtKXLK3c9NooorzjtCiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA KKKKACiiigAo
oooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACii igArO1jQtO12
ze2v7dXDDiQAB0Pqp7Vo0U02ndCavucE3wsgj/489cvoB2zg/wAsVC3w51qL /UeKXf8A66RM
P/ZjXodFaqvUXUz9lDsecN4F8Wp/qtetWx03qRn6/KaqSad43084m0uK9Qfx wsMn8Ac/pXqV
FUsTNbidCJ5M2pa7D/r/AAtfqB1ZUcj/ANBqNvEc0ZPm6NfJj72Yzx+leu0V f1p9iPq67nkM
fi7TGO2QTwkcEOnT8quR+INJl+7fRj/eyv8AOvS7iytLsYubWGYf9NIw386y 7jwZ4buc+Zo1
qM/8808v/wBBxVrFR6ol0H0ZyA1KxYZW9tyPUSr/AI0v9oWX/P5B/wB/B/jX QP8ADbwqxyNP
dPZbiT+ppv8AwrTwv/z5Sf8Af9/8ar6zDzF7CZzx1XTgcG/tQR/02X/GkbWN MXrf234Sg10w
+HPhQAA6WT7m4l5/8ep6fD7wrHnGkqc/3ppD/NqX1mHZh7CRyn9taZ/z/wAH /fYqG91jTXsL
hEvoGZomAAccnBrtP+EC8L/9AiP/AL7f/GqmreCPDVvo97PFpUayR28jo29+ CFJB601iYN7M
HQkcN4c1awtdGihnuo45AzZUnnqa1P7e0r/n+i/OtLwF4Z0TUvCdvdXumwzz M7gu4OThiBXR
f8IV4a/6A1t+R/xoliIptWCNGTVzi/7e0r/n+i/OmHxFpAOPtqfkf8K7f/hC vDX/AEBrb8j/
AI1IPCHhwAAaLZ8esQNL6zHsP2Eu5wJ8T6OM/wCmZI9I3/wqNvFmkjpLI30j NekJ4a0FMbdE
08Feh+ypn88VMmj6XGcpptopPdYFH9KX1qPYfsH3PLT4vsWbZBb3Mz9gqD/G rNvH4t1k7dP0
c2cZ/wCW1z8uB684z+ANeqJGkY2oiqPRRinVDxT6IaoLqzz2H4aahcqG1TxH MWP3o4FO0fQk
/wBK1LD4Z+HbNw80c964OczycZ+i4/XNddRWLrVH1NVSguhTttI0yyINrp1r AR0McKqf0FXK
KKzbuaWsFFFFIAooooA8m09Ps/inxBbnjF2zD6Fm/wARWxWfqKfZPiXqcfRb iFZB7nav9c1o
V60XeKZ50lZtBWJrH/Ix+Hv+vwf+hpW3WJrH/Ix+Hv8Ar8H/AKGlN7CW56NU c8KXNvJBKoaO
VCjA9wRg1JRXnnaclpsjXdpoulSEF7SdxOvqIMqP/HihqI5TSrnw4vDHUhbI qnpC5Eh+gCbh
+FdDa6HaWmsXWqRmQzXIwysRtXpnaMcZ2jP0obRLRtdXWCZPPWPYFyNncbsY 64JGc9DWnMrm
fKzKuIxqPia7tbnT/tlvZwReTE7LsBbOWwep4x7YPrST2VxY+GteieLybVop Gtot+7y1Kcj2
GckD3rYvNJjurkXcVxPaXIXZ50BGWXOcEEEH8RQdKWTS7iwuLu5nFwrK8sjD fgjHGBgflRzb
D5TC1PR7O18KHUYty31vAsyXZOZNwAPX07Y6Yrqo2LxIxGCVBIrIPhm0Iiha 4ums4mDLZmQe
VkHI7ZIz/DnHtWwRlSMkZHUdqmTuNKxyyahbXeqatJc215PC4+xx+VaSSKUU HfyARyxb8hSW
929z8Pr6GXd51pbS28gdSrfKpwSDyCVwefWui06wh0ywis4CxjiHDOcsxJyS T6knNZur6Ske
na3cW3nPNfWxDRA7gWCEAqPUjA98Cq5k3YVmZ+qaTaW3hVtSjyt/BCs6XhOZ d4wevoemOmDi
rOqQLfeI9HimLqj28xdFbbvHyHafbPUd6ltvDdvJaWsc090baNUf7Gz/ALsM OeeM4z/DnHtS
axpxv/EemFkmEccUx86PIMbfJg5HQ9evXmnfXfuK2g23tINK8Wx29ioggubR nlgjACBlZQGx
2OCRVOP/AJE7X/8ArrefzatzT9HisbiW6aee6upVCtNOwLbR0UAAAD6ChdFt l028sA8vlXjS
tIcjcC5Occe/FLmQ7MzNRJuDoGmSBvst3nzwDgOFj3BT7E9var8tlpOi2N3c CEWts0f74RZU
YHcAd+cZHJ4qa80m3vbKG2dpE8gqYpY2w8bAYBB9ajXRIXtLi3vLm5vRcpsk Mz9u2AAAOvYU
rodmYLRRWmraRLaaE+l77nyzJmNfMUo3ykKxPYHn0q1e6Rp1140hE9lDKJbK SR9yA7mDKAT7
44rQXQEaa2lub+8uXtZRJEZWXjgjBAUA9evX3qbUNIS+uYrlbm4tbiJSglgI BKnGQcgjsKfN
qLl0KsPHjW5A/wCgfF/6G9U9E0yx13TH1DU7RLi4uZZAxmGWjUOVCj+7gDtW 4mnxJqb6gGcy
vCsJBI24BJB6deapyeH4/Ola2v7y0jnYvLDA4Csx6kZBKk98EUuYLGHNJNL4 F2PcySNFeLEk
xILELcBVOe5wBVzVbGy0W90e7tIPLmkvkt5JATvkV1YHcTy3IB59K1pdFs5N Jj0xFaG2iKFR
GeRtYMOTnuOak1DTINSNr55cfZbhbhNhxllzjPtzT5kHKXKKKKyLPM/Bf/IH l/6+D/6CtdDX
PeC/+QPL/wBfB/8AQVroa9NnCFFFFIYUUUUAFFFFABRRRQAUUUUAFYXiMiG4 0u76GK6X5vTk
H+lbtYni2Ey6IXX/AJZSK/8AT+tAHrlFVNLvBqGk2l6P+XiFJPpkA1brx2rH pBRRRQAUUUUA
FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAU UUUAFFFFABRR
RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFF ABRRRQAUUUUA
FUdc/wCQBqP/AF6y/wDoJq9VHXP+QBqP/XrL/wCgmnHdCexhfDT/AJEm1/35 P/QzXV1ynw0/
5Em1/wB+T/0M11dXV+Nkw+FBRRRWZYUUUUAFFFFABRRRQAUUUUAFFFFABRRR QB5v44iNl470
u+x+7uofJPuwJH/sy1PS/E1SNR8OzfwpcOD+Jj/wpK9Oi700cFVWmwrE1j/k Y/D3/X4P/Q0r
brP1XRrbV1iFw0i+UTtMZA64z1B9BWpB3dFeZ/8ACF6b/wA97r/vtf8A4mj/ AIQvTf8Anvdf
99r/APE1z+w8zb23kemUV5n/AMIXpv8Az3uv++1/+Jo/4QvTf+e91/32v/xN HsPMPbeR6ZRX
mf8Awhem/wDPe6/77X/4mj/hC9N/573X/fa//E0ew8w9t5HplFeZ/wDCF6b/ AM97r/vtf/ia
P+EL03/nvdf99r/8TR7DzD23kemUV5n/AMIXpv8Az3uv++1/+Jo/4QvTf+e9 1/32v/xNHsPM
PbeR6ZRXmf8Awhem/wDPe6/77X/4mqWr+HdL0vT3uGmuS/SNS6/M3b+Gj6v5 h7byPWaK8q07
wzpWo2Md1HPdDePmG9flPcfdqz/whem/897r/vtf/iaPq/mHtvI9MorzP/hC 9N/573X/AH2v
/wATR/whem/897r/AL7X/wCJo9h5h7byPTKK8z/4QvTf+e91/wB9r/8AE0f8 IXpv/Pe6/wC+
1/8AiaPYeYe28j0yivM/+EL03/nvdf8Afa//ABNH/CF6b/z3uv8Avtf/AImj 2HmHtvI9Morz
P/hC9N/573X/AH2v/wATR/whem/897r/AL7X/wCJo9h5h7byPTKK8z/4QvTf +e91/wB9r/8A
E0f8IXpv/Pe6/wC+1/8AiaPYeYe28g8F/wDIHl/6+D/6CtdDVPTNMg0q2Nvb s7KXLkuQTngf
0q5XQYBRRRQMKKKKACiiigAooooAKKKKACs3xCN2g3Y/2M/qK0qoa2M6JeD/ AKZMaBHbeDW3
+D9LP/Tuo/Litquf8CNu8FaYT/zzI/JjXQV5U/iZ6MfhQUUUVBQUUUUAFFFF ABRRRQAUUUUA
RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFUdc /wCQBqP/AF6y
/wDoJq9VHXP+QBqP/XrL/wCgmnHdCexhfDT/AJEm1/35P/QzXV1ynw0/5Em1 /wB+T/0M11dX
V+Nkw+FBRRRWZYUUUUAFFFFABRRRQAUUUUAFFFFABRRRQBwvxVjZdGsLwDPk XYz7Ag/4VXVg
yhgcgjINbHxKTf4IvGx9x4z06fOB/Wuf05t2mWresKH/AMdFejh3emcVZe+W aKKK3MgooooA
KKKKACiiigAooooAKKKKACuM8QPPql1dsAyW2njHI+8xIH+fYe9dnWZ4j/5A F3/uj+YpoRi+
HHn0y9gtpAWgv4hJGQOjY5/w/Kutqjov/IFs/wDriv8AKr1IAooooGFFFFAB RRRQAUUUUAFF
FFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABVPVxnR73/rg//oJq5VPVzjR7 3/rg/wD6CaBH
UfDxt3gbTj7SD/yI1dLXNfDxdvgbTh7SH/yI1dLXlVPjfqejD4UFFFFQUFFF FABRRRQAUUUU
AFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQA UUUUAFFFFABR
RRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFF FABVHXP+QBqP
/XrL/wCgmr1Udc/5AGo/9esv/oJpx3QnsYXw0/5Em1/35P8A0M11dcp8NP8A kSbX/fk/9DNa
kuvrD4mfRnt8AWiTrPv4ZmMgCYxxxExzn/691fjZMPhRr0Vj2HiS0utK0u9u A1u+pW8UyxhW
kWPzFBAZwuFGTgFsAmorXxVbXOo6tZG2uY306YRBmgkCzEqhwGKhQxZ8Bckk YYcHNZlm7RWJ
p3iL7ZZWU08EdtLd3s1mIvNZ/mjaUHBC85ERPO0e+cZs3mpzpqI06wtUubkR CaTzJvLSNC20
ZIDHJw2BjHynJFAGlRWDYeJFl1bULG+At2guooIVCMcb4Y3w7DKg7nYDkZwA M1Yn8TaXam5F
zJcW4tVkaRprOaNSEBZijMoD4Ck/LnIGRQBrUVlt4k0mO1luZLopFC8aOXic EGRgqHBGSGJG
GHHvwalGt2Bsnu1eVkjcxsi28hlDAZ2+Xt35xzjGcc0AX6KyTrBk13TLS2Mc lrfWc9x5mDuy
jQhce2JDnI7DpWtQAUUUUAFFFFAHOfEBd/gfUh/sofydTXKaOd2jWZ/6YIP0 rsPG43eDNTH/
AExz+orjNCOdDtP+uYrvw3wP1OSv8RoUUUV0mAUUUUAFFFFABRRRQAUUUUAF FFFABWX4l/5F
+6+i/wDoQrUrktb1S4Ualpt6FAYBrcgYyu4cfl/I0IR0Gj/8gaz/AOuCfyq7 XNaLqlxdXNnZ
WoX7Nb26+exHU7e34/1rpaACiiigYUUUUAFFFFABRRRQAUUUUAFFFFABRRRQ AUUUUAFFFFAB
RRRQAUUUUAFUNcbbol4f+mRFX6yvE0nl6Bc/7QVR+LCgR2/gdPL8GaYvrFn8 yT/Wt+svwxCb
fwvpcR6i0jz9SoJrUryZu8mejH4UFFFFSUFFFFABRRRQAUUUUAFFFFABRRRQ AUUUUAFFFFAB
RRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFF FFABRRRQAUUU
UAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABWfr7bfDupN6Wkp/8cNaF Z3iH/kW9T/68
5f8A0A047oT2Mb4bDHgizPq0h/8AH2rRvvDy32oXt41yUNzawwIFTmJonkdX BzzzIOMfw+9Z
/wAN/wDkR7H/AHpP/RjVvz6jaW2/zZSpR0RgEYkFyAvQdMnr0HOcYNXU+N+p MPhRgJ4ItYTp
UiLYXE+n2kFoZb2xE5KRZwU+YeW2STkZ7cHAq5L4YiuNSvZ57mU213Mlz5cM kkEiTLGseRJG
6nbtUfKR15z0ATX/ABXa6Ha3M2w3D29tPP5Sh9zmLZkDCEYzIoLH7uc8gNiK HxdbNq8sM4eC
zFlDcI0ttKkilpJUYuGAKqPLXkgDnOcEVmWV7bwvLpUmj2lo09zDb6pcX888 0xYIrpKAvzsW
z+9XpwdrMcE87N5pk76gNQsLmK2uWiEMplg81ZEDEgYDKcjLYOcfMeDUup6i NOihxEZprmZY
YIgwXe5yep7BQzHvhTgHpWdPrWsQ6jY6cukWpurmKaWTdfMI1WMxg7WEZLZ8 3uF+6aAEk8MN
L9rL35ZrnUbW+LGIZBhEI28ED5vJ68Y3dDjnO1nwCmr3E07XkEckguAJzaBp tssMkewybslV
MmQvAwoHuNf/AISAXMFqNPgWa7uxLsgll8sIYztk3MA2NrYU4B5Iq5pmo/2h HMHi8me2lMM8
W7dscAHg9wVZSOBwRwKAM6/8Mfbbu5uPtmzzxYjb5Wdv2aZpfX+Ldj2xnnpU V/4Pt9QW9M7W
87T6gL6JLm282JHECw4ZNw3jAJ6jqPTNR6R4xN1pyX2q2SWEMmnHUleKZpws IAJ3fIuG56AH
ODjOK1m12wS0jui85jlYqmLaQs2DgkKF3Fe+7GMc5xzQBDbaH5F9pl15kEf2 C0ltvJt7fyoz
vMZyq7jtA8vpz168c69Ykfii0fxJNo/lTYitY7gXIhkMRDbzy23aAAgwxbBJ KjlSKuw6zYT2
01wsrpHB9/zYnjI9DhgCQexAwe2aAL1FZx12xWzjunF0iSsVVHs5lkODgnyy u8AeuMY56Uy2
1R7jxHc6evltbR2MFzG65yxkeUHnOMYjXHHc0AalFFFAHPePLhbbwXqLNg74 xGB7swH9a5HR
IjDotoh6+UD+fP8AWtX4p3ROk2OlxH99eXIIHqq//XZarRoI41ReigAV6GHV oXOOs7yHVQ1T
WLXSEja4EjGQnaEAJ469SPUVfrE1j/kY/D3/AF+D/wBDSugxIf8AhNNN/wCe F1/3wv8A8VR/
wmmm/wDPC6/74X/4qvTKK5/b+Rt7HzPM/wDhNNN/54XX/fC//FUf8Jppv/PC 6/74X/4qvTKK
Pb+Qex8zzP8A4TTTf+eF1/3wv/xVH/Caab/zwuv++F/+Kr0yij2/kHsfM8z/ AOE003/nhdf9
8L/8VR/wmmm/88Lr/vhf/iq9Moo9v5B7HzPM/wDhNNN/54XX/fC//FUf8Jpp v/PC6/74X/4q
vTKKPb+Qex8zzP8A4TTTf+eF1/3wv/xVZHiDWdO1eBDDFOk8Z+VnVQCO4ODX sdFH1jyD2Pme
RaHr2maTY+U0Nw0zndIyouCewHPStH/hNNN/54XX/fC//FV6ZRR9Y8g9j5nm f/Caab/zwuv+
+F/+Ko/4TTTf+eF1/wB8L/8AFV6ZRR7fyD2PmeZ/8Jppv/PC6/74X/4qj/hN NN/54XX/AHwv
/wAVXplFHt/IPY+Z5n/wmmm/88Lr/vhf/iqP+E003/nhdf8AfC//ABVemUUe 38g9j5nmf/Ca
ab/zwuv++F/+Ko/4TTTf+eF1/wB8L/8AFV6ZRR7fyD2PmeZ/8Jppv/PC6/74 X/4qj/hNNN/5
4XX/AHwv/wAVXplFHt/IPY+ZxOm6lBqtsbi3DhQxUhxgg/5NW657wX/yB5f+ vg/+grXQ10GA
UUUUDCiiigAooooAKKKKACiiigArC8U77iGz06LmW7uFVR+n8yK3aztPh/tD 4kabCRlLSMzN
7EAkfrtpSdk2NK7senwxLBBHCn3Y1Cj6AYp9FFeQeiFFFFABRRRQAUUUUAFF FFABRRRQAUUU
RRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAVneIf8A kW9T/wCvOX/0
A1o1neIf+Rb1P/rzl/8AQDVR3QnsY/w3/wCRHsf96T/0Y1a1/o4vb4TmbYjQ tFKgXl+GCHOe
Mb34xySORjnJ+G//ACI9j/vSf+jGrqaqp8b9SYfCjnr3wmmoRqlxeHDWN3aT FI8FzcFCzjk7
cFTgc9fbll34WuNQtdTS71GMz6jpa6e7xWxVU2mU7wpc/wDPXpn+Hrzx0lFZ llLUtPGoRwlZ
PKntpRNBLt3bHAI6dwVZgenBNZ0+i6vLqVhqQ1a1FzbRyxSbrElHWQxk7QJA VI8ruW+8a3qK
AMU+Hvs0No2nXCwXdoJdk0sPmB/MO6TcoK53MA3BHIq9puniwjmJcSz3Mpmn l27d7kAdOwAV
QOvAHJq5RQBzlp4NsrHwVP4dtRBA9xYtazXcVuFMjGPYZGUHk9+T+NaF9pUs 9xa3dpcpBdW0
bwiSSIyAxuULjG4YP7tcHtjoeladFAHPHwjbrut4Z9thNpaaZPbshZmiQOEK vuG0/vGzkHPH
TvJJ4ca7iuXv7tJbufyAJoojGqiGQyRfJuOcMSTzz7Dit2igDHk0rUZntbx9 QtRqNukkXnpa
MIzG7KWAQyEg/IuDuPI6YOKdpfh+HSb7zraQ+Smn29jHCRkqsRkIO7PORJj8 PetaigApk00V
vC800ixxxqWd2OAoHcmndOTXmfi/X28Uaiug6VITZQtuup0PyuR2HqB+p+ma 0p03OViJzUFc
q3mpL4r8Zf2jAj/YLKPy4WcYDNzzj8c/QCtaora2itLdIIECRoMACpa9NJRV kcDbbuwrE1j/
AJGPw9/1+D/0NK26xNY/5GPw9/1+D/0NKHsC3PRqKKK847Qqm+q2ca3jNKcW IzcYQnZ8u705
49KuViaUiya1r6OMq00YI9R5S1SW4mzYhljnhSaJw8cihkYdCDyDVOTW9Pis rm9efFvayGKV
9hwGBAIHHPJA4rJ0q/bSfDd9BNuaTSHeEbsZcDmPp6gqKq+IbE6d8NprZzuk VY2lb+87SqWP
5k1Sir2JctLnU2t1De2sdzbvvikGVbBH6HpUM2rWNvqUOnST4upxlIwpPr1P QdD19KoaUw03
V9Q0x22xE/bLfP8Acb74/Bsn/gQrKiU3N/perOpD6hfs6buoiETiMfl831Y0 KKuPmOnvtRtN
NjWS6mEYY4RQCzOfQAcn8KisdZsdQmaGCVhMi7jFJG0b7fXawBx71RgRbjxr dyS/MbS0jWEE
8LvLFiB68Dmte5ljtreW6kACwxszMewAyefwpNJaDuyWiudgXWr7Rl1aPVGh nmiE8dsIkMIB
GQpyNx46nPelu9YvrjTdEubEpDJfyorK43KA0bH6nBGe2cdqOUXMdDRWGk15 p3iG0srjUHuo
r6KQqJEVSjpg8bQOCCeD6UyGTU9R1jVLVb821tbSoEaONS/KKccggDqehJz2 xRyhzG/RXO2+
vy2vhq/vLp0nn06WWBm+75jK2Fz6E5Xp61FJfXdnHBdLrD30hkQTW3kqFKsQ DtwMjGc8k9Oa
ORhzI6emSzRQBTLKkYZgql2Ayx4A+prImuLrUtcudOtb1rSKyjRpXiVWdnfJ A+YEAADPTvVL
xHZ3v9nWCy6nIzrexKWSNBuzINrEYPI9uCe3ahR1swctDp6KxL+4u7IafpUN 6Xu72Rl+0you
5VUFmIUAAkDAHFIZNQ0nV7KGW+e9tb1miPnKivG4UsCCoGQcEEGjlHc3KK5+ N9V1LWdTtY9Q
NrbWsqBGjjVnOY1O3kEY6n157Y56Ck1YE7hRRRUjPM/Bf/IHl/6+D/6CtdDX PeC/+QPL/wBf
B/8AQVroa9NnCFFFFIYUUUUAFFFFABRRRQAUUUUAFVvCK+b8Sr1u0Vl/8R/j VmmfD5PP8W67
d9owsWfx/wDsKzqu1Nl0/jR6JRRRXlneFFFFABRRRQAUUUUAFFFFABRRRQAU UUUAFFFFABRR
FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAVneIf+Rb1P/rzl/8A QDWjWd4h/wCR
b1P/AK85f/QDVR3QnsY/w3/5Eex/3pP/AEY1dTXLfDf/AJEex/3pP/RjV1NV U+N+pMPhQUUU
VmWFFFFABRRRQAUUUUAFFFFABWPr3ijSvDkIe/n/AHjDKQR8yP8Ah2HucCsX xv40bRhHp2lP
FJqE52k5DeR06j1OeM1zFhoKxzm91KU3t653NJIdwB9s9frXTSocyvLYwqVe XRFjWfF2p+LY
103TLWbT7Rx/pE0nVl9OO3t3+mam0/T7fTbYQW64HVmPVj6mrVFdsYqKsjll Jyd2FFFFUIKx
NY/5GPw9/wBfg/8AQ0rbrE1j/kY/D3/X4P8A0NKT2Bbno1FFFecdpFdfaBbu bQRmYD5BKSFP
scciqOj2FzaveXV6YvtF5MJGWIkqgChQMkDPA9K06Kd9LBYwtQ0Ge616O7jk iFnL5Zu42zuc
xklMcepGc+lWfEumT6zoFzp9u0aSzbNpkJCjDg84B9K1KKfM9PIXKtTE8SaF NrK25trgQSKT
HK2fvQuMOo4PPAxVq+0157nTHg2JHZTb2U5Hy7GUAfmK0aKOZ7BZGTqOl3R1 JNV0yaOO6WPy
pI5gfLmTOQDjoQe9S28Op3PmDUzapC8ZTyIMtnPcscduwHetGijmYWOfi07X rbTRpME1mIET
yo7ti3mKmMD5MYLAcdcd/arM+ikQ6RBasoi0+ZWO8nJUIy8cdeRWvRT5mHKj Lv8AS5rrX9K1
BHQR2Pnb1Odzb1CjFSWFhLa6lqVy7IUu5UdApOQAgU5/EVoUUuZ2sFjCtfDr DTdYsrqVduo3
c0ymPnYr4x17jFWbb+3kaKGaOwaNSA84kfcw9QmOD/wKtSijmb3CxkXOn39v q8mpaZ9nkNxG
sc8M7FAdudrBgDzzjGKXUNOv7/SY43lg+2RTJOuARGSrbgvc4xxn9K1qKOZh YyLzT7++gtLs
/Z4NRs5DJGAxaM5BBUnAOCD1xwfWkisNSvdStrzUzbxR2m5ooIGZ9zkY3MxA 6AnAx361sUUc
zCxn2FhLa6lqVy7IUu5UdApOQAgU5/EVoUUUm7jSsFFFFIDzPwX/AMgeX/r4 P/oK10Nc94L/
AOQPL/18H/0Fa6GvTZwhRRRSGFFFFABRRRQAUUUUAFFFFAEN5dR2VpJcynCR rk+/tWn8MNPl
t/D81/OhWW/nMgJHVBwD+e7865fW4f7Q1bSNJYkRXVyBJj0yB/ImvWYoo4IU hiQJHGoVVUYC
gdAK5cTO0eXub0I3dx9FFFcJ1hRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFF
UUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFZ3iH/kW9T/685f/AEA1o1ne If8AkW9T/wCv
OX/0A1Ud0J7GP8N/+RHsf96T/wBGNXU1y3w3/wCRHsf96T/0Y1dTVVPjfqTD 4UFFFFZlhRRR
QAUUUUAFFYGs+NdC0RWE94s0w/5YwEO+ffsPxIrita8Ra14xhWyt7FtP09nD PIzfM4H5cd8D
25raFGU/QzlVjE77xH4htPDelveXPzv0jhDANI3oPb1NcBdav4q8STPJ9pbS LNlCiKMncR3O
eCT+VQweGLRbgXF1NNeSDoZmyP8A69bVdlOjGG+rOWdWUvIzdO0Gy00+YiGS bvLJyfw9K0qK
K2MwooooAKKKKACsnW9MvL2eyubGaOKa0cupk7HIIPQ9CK1qKAMn7R43/wCg za/9+1/+N0fa
PG//AEGbX/v2v/xutaip5Y9h80u5k/aPG/8A0GbX/v2v/wAbo+0eN/8AoM2v /ftf/jda1FHL
HsHNLuZP2jxv/wBBm1/79r/8bo+0eN/+gza/9+1/+N1rUUcsewc0u5k/aPG/ /QZtf+/a/wDx
uj7R43/6DNr/AN+1/wDjda1FHLHsHNLuZP2jxv8A9Bm1/wC/a/8Axuj7R43/ AOgza/8Aftf/
AI3WtRRyx7BzS7mT9o8b/wDQZtf+/a//ABuorrUfGVnayXE2tWoSMZP7pfy+ 5W3XI+K7+S7l
axt+Y7YeZOR0z0A/DP5n2p8kewc0u5qw33jO4gSaLW7VkdQyny16f9+6f9o8 b/8AQZtf+/a/
/G6zfCl+8J/sy543KJYM9wRkj+v51fufEC2x1YNbZOnIXX58ediNXI6cY3gd 6TUFuhpyezH/
AGjxv/0GbX/v2v8A8bo+0eN/+gza/wDftf8A43V5r23S7W1Z2Ej9PkbbnGcb sYBxzjOao2Wv
x39pNLFbyrIkzxJHIjpvIZgOWUdlJIGSvQ80rQ7ILy7h9o8b/wDQZtf+/a// ABuj7R43/wCg
za/9+1/+N1NY6qt5Fp7lFje+tftAjLElRhCQOMHG8en09HPfzPeS29pbLMLc gTM0oXBIztUY
OWxg84HzDmi0OwXl3K/2jxv/ANBm1/79r/8AG6PtHjf/AKDNr/37X/43T9N1 dLwvFMQswuJ4
lCowBCOwHPTO0AkZ98U/+3dPWNpJJJYQpUETW8kZOWCjAZQSMsBketFob2Qe 8Q/aPG//AEGb
X/v2v/xuj7R43/6DNr/37X/43VltYsUjSRpWAkl8lV8p92/aW27cZBwCen8x Tn1SzS1S5MjG
J84KxsxGDg5AGQB3z070Wh2QXkVPtHjf/oM2v/ftf/jdH2jxv/0GbX/v2v8A 8bqzFePJrU9n
hPKjtopVYdSWaQH8PkH61dpqMX0FeXcy/D+lzaTYPBO6O7SF/kzgcAd/pWpR RVCCiiigAooo
oAKKKKACiiigAooooAzLZftfxF0e3XnyQ0jY7YDH+g/OvVK88+G1sl3q2s6v IN0gl8mJj/Cu
ST+gWvQ68/EyvO3Y7KKtG4UUUVzmwUUUUAFFFFABRRRQAUUUUAFFFFABRRRQ AUUUUAFFFFAB
UAFZup+ItH0c7dQ1GCB8Z2Fsvj/dHP6VzXjPxdd296NA0PBvpFzLN/zxB7D3 xznt9enOWfhq
0izLe5vLlzueSUk5Pfjv+NdVPD8yvIwnW5XZG5ffEx7mbyPDumPeFfvSzAqv 5f4kfSq48eeK
U/1nh+Bs9NjH/E0+OOOJAkaKijoqjAFOrpVGmlsYOrN9Rg+IfiBP9Z4a3Z6b JD/gaUfEjWFO
ZPCsrL6LI2f/AEE06ij2NPsHtZ9wHxN1AHLeEroL3Pmtx/5Dp3/C0Jf+havP ++z/APE02il7
Cn2D2s+48fFHH+t8O3qDsQ2f6CpF+K2mL/x8aXqEWOuFU4/MioKKPYU+w/bT 7mhD8UvDcn32
uov9+HP8ia0bPx34ZvpBHFqsSOe0ytGPzYAfrXNPbwy/6yGN/wDeUGqlxomm XK4ksoh7ou0/
mKl4aA1XkemxTRTxiSGVJEPRkYEfmKfXkB8IWAcvFPcxHttccfpmnDw7PGQY dbvo8cLiQ8fk
az+q+Zf1jyPXazvEP/It6n/15y/+gGvNRpGsRnMXifUEPciR/wD4qob7TdZF hcNP4mv541iY
tG8j4YAHg5Y0LDNPcHXVtjuPhv8A8iPY/wC9J/6MauprxLRNHnvdJhmGq3UK EttijchV5Occ
1ebwnby58+/vJAeuXHJ/EVUsNzSbuKNeySserXOoWVnn7VeW8GOvmyqv8zWD qHxE8NWGQL43
Tj+G3Qv+vA/WuJi8I6VH95ZZf99/8MVoW2k6faYMFpEpH8W3J/M80LDR6sTr y6I0H+KkEn/H
hoV7c+m4hc/lu9qrv8QPEk//AB6eHEiz085yf/iakorRUKa6EOrN9SlJ4g8d 3f3ZbKyz/dQH
H57qpz6fruqDZqviCeSI9YoyQp/DgfpWzRWihFbIhyk92Z1joOnWBDRW4aQf xyfMf/rfhWjR
RVCCiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigArF1 yytrbRtQmhiC
ST4aRu7HcK2qy/Ehx4fuvov/AKEKBCaVZW02n6ddSRBpooQEfJ44qO/8PJfw ajG1y0ZvZN4d
U5j/AHSxkdecgH8/armjDGjWf/XFf5VMbyAOiFzueQxAbT94AnB9OB1PHT1F KST3Gm1sUjos
S60dTjjtC8jBpGlt98uQoUbHyNowBxg9/WmJoER8xZp5WTzZJYfKlkhZPMYs wYow3DJ44GB6
9aNR8RW9gCQjTYMI2xo5bEkhTOAp4+VsepGO4y601uKa9uoJSYwkyRw5idTh o0Ybsj5SSxGD
j061HuXK94h0/SJdPu9MhTfJBY2LwtM7ffZjH0BJI+4TjoAQB7XXsZku5Z7S 5SETkGZWi3Ek
DGVORg4AHORwOKfeXrwSw28EImuJwxRGfYoCjkk4JAyQOAeo4qq+qXov3tU0 +NvJt1mlP2jD
fMzgBRtw33M8kdafurQNXqLDo3lPbN9oz5F5Ndfc+95nmfL14x5nXvj3qifC am6S4+0xB1Ch
nW3w8u2WOQF2zlj+7xn/AGvwOkdTM7Rpp0cdy0kKz5eXYoRvunIBPODjjsea JdWRdCuNUSIs
IIpHMRbB3JncpPPdSKVoheRH/Y3+nfaftH/L99r27P8Apj5W3Ofxz+GO9V5v DMUtvErfZp5Y
ZJ3Q3Vt5sYEsm8jZuHI4Gc9vfFWI9aWJJ/7SjW1aDy95RmkT94cLhtoOc9eO MjtVl9StY1iL
tIvmgEAwuCo9WGPkH+9inaLC8kEVj5Wpy3vmD95bxw7AuANjOc9e+/p7VbrM ttct572/tnjl
i+xSbC7ROFb5VPUrjOWwBkkjkcGrP9pWv2T7TucJnG0xPvz6bMbs+2M0010E 0y1RVR9TtY1i
LtIvmjIBhcFR6sMfKP8AexSWV5Jc3uoQuFC2s6xoQOSDGj8/ixp3QrMuUUUU wCiiigAooooA
KKKKACmTSCGCSU9EUsfwFPrL8R3S2uiXBJw0o8tR656/pmgR0PwrtzH4Uedv vXFy759QAF/m
DXaVj+EtPbS/Cun2ki7XWEM6+jMdxH5mtivKqO82z0IK0UgoooqCwooooAKK KKACiiigAooo
oAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiig AooooAKKKKAC
iiigAooooAKKKKACiiigArk/iDr9zo+lQWthJsvL+Ty0YHlV7ke/IH411leT NcN4k8YXupzM
Xt7N/KtV7AAnB/r9TW9CHNK72RlVlyxJtJ0aLTFaQu01zL/rJWOST7VpUUV6 JxBRRTJZooIz
JNIkaDqzsAB+JoAfRVT+1dN/6CFr/wB/l/xo/tXTf+gha/8Af5f8aBFuiqn9 q6b/ANBC1/7/
AC/40f2rpv8A0ELX/v8AL/jQBboqp/aum/8AQQtf+/y/40f2rpv/AEELX/v8 v+NAFuiqn9q6
b/0ELX/v8v8AjR/aum/9BC1/7/L/AI0AW6Kqf2rpv/QQtf8Av8v+NH9q6b/0 ELX/AL/L/jQB
brE1LV1W4vdMmi8vNszRSE8P8p/+v+VaH9q6b/0ELX/v8v8AjWN4m/s/ULHz Yb62NxByoEy5
Ydx1oAi0TV1tNP02xjiM007tkA42LuPP8/yrqa5Dwoljaq97dXdukrfLGryq Co7nGe/+etdJ
/aum/wDQQtf+/wAv+NNgW6Kqf2rpv/QQtf8Av8v+NH9q6b/0ELX/AL/L/jSA t0VU/tXTf+gh
a/8Af5f8aP7V03/oIWv/AH+X/GgC3RVT+1dN/wCgha/9/l/xo/tXTf8AoIWv /f5f8aALdFVP
7V03/oIWv/f5f8aP7V03/oIWv/f5f8aALdFVP7V03/oIWv8A3+X/ABo/tXTf +gha/wDf5f8A
GgC3RTIpop4xJDIkiHoyMCPzFPoGFFFFABRRRQAUUVHNcQWyhp5o4lJwC7BR +tAElFVP7V03
/oIWv/f5f8aP7V03/oIWv/f5f8aBFuiqn9q6b/0ELX/v8v8AjR/aum/9BC1/ 7/L/AI0AW6Kq
f2rpv/QQtf8Av8v+NH9q6b/0ELX/AL/L/jQBboqp/aum/wDQQtf+/wAv+NH9 q6b/ANBC1/7/
AC/40AW6Kqf2rpv/AEELX/v8v+NH9q6b/wBBC1/7/L/jQBbrm9Z1aK70/U7L Y0ctuQMN/GNw
5H+e4rZ/tXTf+gha/wDf5f8AGua8VrZXGy9tLuB5PuSIkoJYdjgGmgNTS9Xi QadpixtJI1up
Zl6J8uef8+lXZtNaS5mmjnEfmAFRsztkBHzHnnhFGOOh554xfC4sLK1a6uL2 3W4m4w0q5RR0
HX/PFb39q6b/ANBC1/7/AC/40mrjTKdzoAmMhjuPLzDbxx5TdtMMhdSeeQSR kcdOvPDn0VpP
PL3I3z3cF0xWPABjEfAGe/l/hnvjm1/aum/9BC1/7/L/AI0f2rpv/QQtf+/y /wCNTyofMwvL
N55YriCVYrmEMEd03jDYyCMg44B4I6Cqr6VenUHul1BFE1usMo+z5bhnIKnd hfv9welWv7V0
3/oIWv8A3+X/ABo/tXTf+gha/wDf5f8AGm4phdkR0toJIpNOljtmSFYCHi3q Y1+6MAggjJxz
36UsulI+hXGlxyFBPDJGZCuTucHLEcc5YmpP7V03/oIWv/f5f8aP7V03/oIW v/f5f8aOVBdk
U2j2x05LK1SK1jWaKXEUQAykiv0GOu3H40l/pIvZZmEqol1CLe5UoSXjG7AU 5G0/O3PPWpv7
V03/AKCFr/3+X/Gj+1dN/wCgha/9/l/xo5UF2V5dHMk943nr5d1JHPtMeSkq bNpznlf3a8Y9
ee1IdIcx+b56fbftH2nzfLOzzPL8v7m7pt4xn8as/wBq6b/0ELX/AL/L/jR/ aum/9BC1/wC/
y/40cqDmZWudIku9/m3Eebm3Fvd7YiPMQbuF+b5Pvt69atWtl9mur2fzN32u YSYxjbhFTHv9
3P41PFNFPGJIZEkQ9GRgR+Yp9FkF2FFFFMQUUUUAFFFFABRRRQAVlwWg17x3 Y6dIN1tZr58y
+uOcH/x0fia0ZZUgheWRtqIpZj6AVN8MrGS4bUPEM6kNdv5cWf7gOT+GcD/g NZ1ZcsGy6cea
SR31FFFeWd4UUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAU UUUAFFFFABRR
RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUVQ1nWLP QtNkv72TbGg4
UdXbso9SaaTbsgbsUPF/iODw7o0khbN1MpS3jB5LY6/Qdf8A9dcP4csHsNIR JV2yyMXcHqM9
P0AqG1F34j1VvEGqjgn/AEWHsi9v89zzW3XpUqfs426nBUnzsKKKK1ICuf8A Gn/IHi/6+B/6
C1dBXPeNP+QPF/18D/0FqBHWf8IJ4a/6Bv8A5Hk/+Ko/4QTw1/0Df/I8n/xV dBRXBzy7nZyx
7HP/APCCeGv+gb/5Hk/+Ko/4QTw1/wBA3/yPJ/8AFV0FFHPLuHLHsc//AMIJ 4a/6Bv8A5Hk/
+Ko/4QTw1/0Df/I8n/xVb5dQcFgD7mgMrHAYH6Gjnl3Dlj2MD/hBPDX/AEDf /I8n/wAVR/wg
nhr/AKBv/keT/wCKrfLAdSBn1oJAGSQPrRzy7hyx7GB/wgnhr/oG/wDkeT/4 qj/hBPDX/QN/
8jyf/FV0AIIyDkUZGcZ59KOeXcOWPY5//hBPDX/QN/8AI8n/AMVR/wAIJ4a/ 6Bv/AJHk/wDi
q6Cijnl3Dlj2Of8A+EE8Nf8AQN/8jyf/ABVH/CCeGv8AoG/+R5P/AIqugoo5 5dw5Y9jn/wDh
BPDX/QN/8jyf/FUf8IJ4a/6Bv/keT/4qugoo55dw5Y9jn/8AhBPDX/QN/wDI 8n/xVH/CCeGv
+gb/AOR5P/iq6Cijnl3Dlj2Of/4QTw1/0Df/ACPJ/wDFUf8ACCeGv+gb/wCR 5P8A4qugoo55
dw5Y9jn/APhBPDX/AEDf/I8n/wAVR/wgnhr/AKBv/keT/wCKroKKOeXcOWPY 5/8A4QTw1/0D
f/I8n/xVH/CCeGv+gb/5Hk/+KroKKOeXcOWPY8z8F/8AIHl/6+D/AOgrXQ1z 3gv/AJA8v/Xw
f/QVroa9BnGFFFFIYUUUUAFYHiCCO61rQ7aZd0U1zsdckZBZARx7Gt+sTWP+ Rj8Pf9fg/wDQ
0oewLc6b/hBPDX/QN/8AI8n/AMVR/wAIJ4a/6Bv/AJHk/wDiq6CiuDnl3Ovl j2Of/wCEE8Nf
9A3/AMjyf/FUf8IJ4a/6Bv8A5Hk/+KroKKOeXcOWPY5//hBPDX/QN/8AI8n/ AMVR/wAIJ4a/
6Bv/AJHk/wDiq38j1HXFLRzy7hyx7HP/APCCeGv+gb/5Hk/+Ko/4QTw1/wBA 3/yPJ/8AFVv7
hjORj1zS0c8u4csexz//AAgnhr/oG/8AkeT/AOKo/wCEE8Nf9A3/AMjyf/FV 0GRnGefSgkAZ
JwKOeXcOWPY5/wD4QTw1/wBA3/yPJ/8AFUf8IJ4a/wCgb/5Hk/8Aiq6Cijnl 3Dlj2Of/AOEE
8Nf9A3/yPJ/8VR/wgnhr/oG/+R5P/iq6Cijnl3Dlj2Of/wCEE8Nf9A3/AMjy f/FUf8IJ4a/6
Bv8A5Hk/+KroKKOeXcOWPY5//hBPDX/QN/8AI8n/AMVR/wAIJ4a/6Bv/AJHk /wDiq6Cijnl3
Dlj2Of8A+EE8Nf8AQN/8jyf/ABVH/CCeGv8AoG/+R5P/AIqugoo55dw5Y9jn /wDhBPDX/QN/
8jyf/FUf8IJ4a/6Bv/keT/4qugoo55dw5Y9jn/8AhBPDX/QN/wDI8n/xVH/C CeGv+gb/AOR5
P/iq6Cijnl3Dlj2PM/Bf/IHl/wCvg/8AoK10Nc94L/5A8v8A18H/ANBWuhr0 GcYUUUUhhRRR
QAUUUUAFFFMlkWGF5XOFRSx+goAx78XHiDVYvDunHlzuuZO0ajrn6fzwK9T0 +xg0zT4LG2Xb
DAgRR9O596434W2bHTb7V5V/e3twQD/sr/8AXJ/Ku7rgxE7y5ex10YWjfuFF FFcxuFFFFABR
RRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFF FABRRRQAUUUU
AFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFea+PGGpeNtN0yT54IIDK6dskn/ AOJX869Kry7U
X+0fE3VGPIhhVF9vlT/69dOGV53Ma790vgAAADAHQCloorvOMKKKKACue8af 8geL/r4H/oLV
0Nc940/5A8X/AF8D/wBBagR6ZRRRXmncFFFFAGF4o0rT59H1C9ls4XuUtXKy sgLDCnHNTadp
mm6bYpfW9jDFKLcFnRAGI25PNT6/FJN4f1CKJGkke2kVUUZLHaeAKnt4d+lx QSAruhCMDwR8
uDV3fKTbUxNG0a11bS4dS1eFL26u180tIMhA3IVQegAxUXieyt7bTtGsfme2 OqQoyyuXyp3E
gk9R9am0q+utEso9L1Cwu5Htx5cU9vCZEmUfd6fdOMdaTxFBPq1jpHmadLg6 nE00DLvKx/MC
WxkAY69hmr15vInTlGrBZaf4psINH2x+akhu4IW+TYBwxXoDuwAaqGQrfx+K w58qS7+znnj7
MfkB+m8Bs+9bWpWq6ZolymjWCRzyjYi28QHzN8u44HQZzn2qs/hTOkHThq9+ YfK8sRny9uMc
D7mcfjQpLqDTNLU9R+wJCkcJnubiTy4Yg23c2MnJ7AAEk1GNSubW1ubjVbRL aO3TzN8UvmKw
5yBwDnjpjuKyCL+az0TV57K4Nxp7OtzAE+cgqUZgvfkAj2PFXNT3+JNCv7O3 trmHdGPLedDF
vYHOADz2HUY5qeVDuy1Z32qTSxNcaWkMEvIZbjc8fGRuXA+nBPJqH+2L+5E0 2naclxawuyb3
n2NIVOG2jaR1BHJGamsdZa7kih/s69ikP+t82EosXH948HnpjNY+n29vo9u9 jf2N87pLIY5I
UllWVSxIOVzg4POaLLsF/M07rxDFFY6deW9vJcx37hEVPvcqSOPXIx1A96dF q91FqkFjqNit
v9qDeRJHKZASoyVb5Rg45/A1Q1sCzttC+xWTAR3ilLbIUgbH+X0B/Gpnll1n W7Aw2lxDb2Tt
LLLPEY8ttKhVB5PUknpTsrBd3IrS91lvFV/D9niaFVhyjXRxGpLfMo29SOo4 6Dmr8uq3k19P
a6ZZR3H2YhZpJpjGoYjO0YUknB56VXDvYeKrmWW2uHivYoUikiiLqCpYEMR9 3qDzUdrK+gah
qMdxa3csN3cm5hlhhaUHcACp25III4z2oaT6BsWY9fD6LfXxtWjnsA4mt2bo 6jON2OQeMHHe
p9Nv7y/YTPYiC0dN0TvJ+8bpjKY4B5PXPTgdso2d5J4e124ltZI5tQErx2+N zgbNqggZ+Y4z
getdBZKyWNurAqwiUEEcg4pOyQ1dk1FFFZlBRRRQB5n4L/5A8v8A18H/ANBW uhrnvBf/ACB5
f+vg/wDoK10NemzhCiiikMKKKKACsTWP+Rj8Pf8AX4P/AENK26xNY/5GPw9/ 1+D/ANDSk9gW
56NRRRXnHaFFFV728WxgEzwzyruAIhjLsPfA5x9KYHO22ntqfhjVrWPIla9u GiIOCHEhKnI9
wK0Drgk8Irq8QBkkgGxQc/vT8oX/AL64qTw3BNFpkkk8TwtcXMswjcYZVZyR kdjisuGwu113
+ymt5Rp8d2b5ZSvyEEZCZ9RISce1aaNsz1SIde0qO18P6DpT/Mh1CCKbH8ZI bcfxJJra0C9d
tIMd4+J7FmgnZvVP4vxXB/GofFFvPcf2P5MMkvl6pBI+xSdqjOWOOgHrVLW9 Ovm1kwWcTG01
dVju3UHEWw/MT/vJle3Qc0/iVmGzuiHSFabxPa6pIT5moW80oBP3Y9yCMf8A fOD9Sa0dft01
q8t9DZiI3Rri42n+EfKg/Fjn/gJqxNbyDxRYyJE3kx2kqFwp2qcpgZ/D9KqW mmXeoalf6lLd
3tgXl8mJIwgzGnAJ3Kep3H8aV9bhboXPD981zocb3LATW26G4JPR0OGP6Z/G mWmraherFdQ6
YpsZmGxzPiUoT9/ZjGO+N2cflVO20u4tdR1PTGe5mttRtzILpwPlkI2MCVAA ONpHHapdG1Ga
1sLPS5tNvBdQIkL4hPl4GBv3/dxjnrn2oaWrQ031LMmq3k17Pb6ZZR3AtSFm klm8sbyM7Vwp
ycEZ6dafc6rPG1rbQWRe+uUMnkySBRGoxuLMM9CQOM5qhaSvoOoajFNZ3csV 3cm5hlgiaQHc
BlTjoQR34o1K3c6rZ6xPZXLwm2aKaKMkvESQwO1Tz3Bxnt1osrhdmjY6nLNc 3FneWy291Agk
KpJvV0OcEHAPUEcis+DxFf3ekJqlvo+63Ee+QNNhzgfNsG35sc9cZxVzThYy tPcWtlcRNsCG
WeN0Ljk4G/kgfTHNYmi6tcQ+ELa2TTLqW5aDbAI03JJnoS3RevOcdO9CS7Bf zLuv6ndvp2nX
WlgGG4nhYOZTGSGYYUgDoc4P8jWhc6pcWdnB59mrX1zJ5cVvFLlS3J+8QMDA yTj86oX2m3Fn
4X0+2SNp3sZLd5FjGSQjAtgd+9P1MyXUml63bW1zItnK5eAxlZCjKVJCHkkd QOuOlFkGpZi1
e6i1KCx1OyS3a5B8iWGUyIzAZKnKjBxyPWo21u8m1K8sLHTRNJaOoZ5JtibS oI5weck8e2cj
io2ml1vV9PeC0uIrWzdpZJp4jHltpUKobk/eJJxjirGlQyx6zrMjxOiSzxlG ZSAwEagkHvzS
skF2a1FFFZlhRRRQB5n4L/5A8v8A18H/ANBWuhrnvBf/ACB5f+vg/wDoK10N emzhCiiikMKK
KKACiiigArE8Q6gBAdLtlaa8usIscYyQD/jV/VNSh0uzaeUjd0RM8sfStj4f eHDa2h13UI91
/e/OhccxoemPQn+WBUVJqEbsqEHN2Oi8N6YdH8O2NgwAeGIbwP7x5b9Sa06K K8tu7uzvSsrB
RRRSGFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABR RRQAUUUUAFFF
FABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFeVE7/H+uP6MF/l /hXqteT2p3+M
/EL+lwV/8eb/AArqwvxM56+yNeiiiu45QooooAK57xp/yB4v+vgf+gtXQ1z/ AIzUnR4yASBO
pPt8rUCPS6K47/hZ2i/8+t//AN+0/wDi6P8AhZ2i/wDPrf8A/ftP/i64fZz7 HXzx7nY0Vx3/
AAs7Rf8An1v/APv2n/xdH/CztF/59b//AL9p/wDF0ezn2Dnj3Oxorjv+FnaL /wA+t/8A9+0/
+Lo/4Wdov/Prf/8AftP/AIuj2c+wc8e52NFcd/ws7Rf+fW//AO/af/F0f8LO 0X/n1v8A/v2n
/wAXR7OfYOePc7GiuO/4Wdov/Prf/wDftP8A4uj/AIWdov8Az63/AP37T/4u j2c+wc8e52NF
cd/ws7Rf+fW//wC/af8AxdH/AAs7Rf8An1v/APv2n/xdHs59g549zsaK47/h Z2i/8+t//wB+
0/8Ai6P+FnaL/wA+t/8A9+0/+Lo9nPsHPHudPeWEV7LaySM6m1mEybccnBGD 7c1arjv+FnaL
/wA+t/8A9+0/+Lo/4Wdov/Prf/8AftP/AIun7OfYOePc7GiuO/4Wdov/AD63 /wD37T/4uj/h
Z2i/8+t//wB+0/8Ai6Xs59g549zsaK47/hZ2i/8APrf/APftP/i6P+FnaL/z 63//AH7T/wCL
o9nPsHPHudjRXHf8LO0X/n1v/wDv2n/xdH/CztF/59b/AP79p/8AF0ezn2Dn j3Oxorjv+Fna
L/z63/8A37T/AOLo/wCFnaL/AM+t/wD9+0/+Lo9nPsHPHuYngv8A5A8v/Xwf /QVroa5/wYCN
HkJBGZ2x7/KtdBXczkCiiigYUUUUAFYmsf8AIx+Hv+vwf+hpW3XPeJLhbLVN GvZFZore48x9
oycBkOB78Gh7Aj0yiuO/4Wdov/Prf/8AftP/AIuj/hZ2i/8APrf/APftP/i6 4fZz7HVzx7nY
0Vx3/CztF/59b/8A79p/8XR/ws7Rf+fW/wD+/af/ABdHs59g549zsaK47/hZ 2i/8+t//AN+0
/wDi6P8AhZ2i/wDPrf8A/ftP/i6PZz7Bzx7nY0Vx3/CztF/59b//AL9p/wDF 0f8ACztF/wCf
W/8A+/af/F0ezn2Dnj3Oxorjv+FnaL/z63//AH7T/wCLo/4Wdov/AD63/wD3 7T/4uj2c+wc8
e52NFcd/ws7Rf+fW/wD+/af/ABdH/CztF/59b/8A79p/8XR7OfYOePc7GiuO /wCFnaL/AM+t
/wD9+0/+Lo/4Wdov/Prf/wDftP8A4uj2c+wc8e52BG5SD3GKr6dYx6Zp8FlC zNHAu1S/Uj3r
l/8AhZ2i/wDPrf8A/ftP/i6P+FnaL/z63/8A37T/AOLp+zn2Dnj3Oxorjv8A hZ2i/wDPrf8A
/ftP/i6P+FnaL/z63/8A37T/AOLpezn2Dnj3Oxorjv8AhZ2i/wDPrf8A/ftP /i6P+FnaL/z6
3/8A37T/AOLo9nPsHPHudjRXHf8ACztF/wCfW/8A+/af/F0f8LO0X/n1v/8A v2n/AMXR7OfY
OePc7GiuO/4Wdov/AD63/wD37T/4uj/hZ2i/8+t//wB+0/8Ai6PZz7Bzx7mJ 4L/5A8v/AF8H
/wBBWuhrn/BgI0eQkEZnbHv8q10FdzOQKKKKBhRRRQAVHcTx2tu88zBY4xlj UlY0to/ifxLb
6DC5W3j/AHt269gO38h9T7Um0ldgld2Re8H6C3ifUT4g1WLNlE220gYcOR3P qB+p+lemVFbW
8NpbR21vGI4olCoi9AB0qWvMqVHOVzvhBRVgooorMsKKKKACiiigAooooAKK KKACiiigAooo
iiigAooooAKKKKACvJdLO7xN4if1vW/9DevWq8j0M7tW1t/7143/AKE1deF3 ZzYjZG3RRRXa
cwUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQBBexefY3EOM +ZEy/mK8/wBL
uL2CdFtrs2wkOFLH5C3oe3/669HrBi8MINNubOWQNvlMkLAfc4wP/r00I0NL k1F4GGpQpHIr
YUoQQw9eDV6sLQdTlWVtJ1D5bqDhSf41/rx+YrdpAFFFFAwooooAKKKKACii igAooooAKKKK
ACiiigAooooAKKKKACiiigArN1eTVVVF02OLDZ8yV2Hyfgf/AK9aVc7rN7Nq V4NF09uW/wCP
iQdFHcf4/lQI5i5e7vrsLNcvcAyBFkydpPtXpCgKoUDAAwKxpPD0Yk04QOEi s3LsCOXPBz+l
bVNgFFFFIYUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQBU1 O9Gn6dNcnqi/
KPVug/Wt34c6INO0AahOpN3qB813brs/hH9fxrlrTTn8YeKv7PZiNOsMPcEf xt/d+p5H4GvV
lVUQIgCqowAOgFcmJnpyI6KEPtMdRRRXEdQUUUUAFFFFABRRRQAUUUUAFFFF ABRRRQAUUUUA
RQAUUUUAFFFFABXkPho75dTk/vXTV69Xj/hI7rS7f+9ctx+ArswvU5sR0N+i iiuw5gooooAK
KKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAyNe0hr6Nbq1Oy 8g5jYcFvb/Cp
NE1ddTtT5mEuIuJUPGPetInCk4JwOgrib7VbZdRGpWAkguVOJoJVwJB+H60x HY2t3b3sPnW0
okTJGR61NXN+C5g1lcxDgJLuA9AR/wDWrpKQBRRRQMKKKKACiiigAooooAKK KKACiiigAooo
oAKKKKACobi7t7TyxPKE81giZ7mpq5bxdd+Rfaf8u7yiZSvryMfyoEaOvas9 mi2doC95PwgH
VQe/+FTaJpKaVaYYh7iTmV/U+n0rntF1G1S/+1XXm3V/cvgbFyIwf89u1dnT AKKKKQwooooA
KKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigArN1jV106NY40aW6m4 hiUZJPY4+v51
bvLyCxtmuLhwiL+ZPoPen+A9Hn1XV5PE9/BsiC7LNG/IsPpz+JNTOahG7KjF ydkb3gLQJdC0
HddoVvLt/NmB6r6Kfw5+pNdPRRXlyk5O7O+KUVZBRRRUjCiiigAooooAKKKK ACiiigAooooA
igAooooAKKKKACiiigAooooAK8i8Nr5Mup23/PK7YY/T+leu15PZp9n8XeIL c97kuB7FmP8A
UV14V6tHNiNka9FFFdpzBRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUU UUAFFFFABWR4
l1C403TVltWCSPKE3EA4GCe/0rXrnvGn/IHi/wCvgf8AoLUCNH/hGfGf/QWs Py/+11Vu/A/i
a/GLq902Q/3iuG/MR5r0WiuP20zq9lE84sfAvifTS5tNQsI/Mxu+ZjnHTqnv Vz/hGfGf/QWs
Py/+113dFHtph7KJwn/CM+M/+gtYfl/9ro/4Rnxn/wBBaw/L/wC113dFHtph 7KJwn/CM+M/+
gtYfl/8Aa6P+EZ8Z/wDQWsPy/wDtdd3RR7aYeyicJ/wjPjP/AKC1h+X/ANro /wCEZ8Z/9Baw
/L/7XXd0Ue2mHsonCf8ACM+M/wDoLWH5f/a6P+EZ8Z/9Baw/L/7XXd0Ue2mH sonCf8Iz4z/6
C1h+X/2uj/hGfGf/AEFrD8v/ALXXd0Ue2mHsonCf8Iz4z/6C1h+X/wBro/4R nxn/ANBaw/L/
AO113dFHtph7KJwn/CM+M/8AoLWH5f8A2uj/AIRnxn/0FrD8v/tdd3RR7aYe yicJ/wAIz4z/
AOgtYfl/9ro/4Rnxn/0FrD8v/tdd3RR7aYeyicJ/wjPjP/oLWH5f/a6o3vgD xJqMwlur+wkd
V2g7mHH4J716TRR7aYeyieeWvgvxTYpttr/TYh3KryfqfLyasf8ACM+M/wDo LWH5f/a67uij
20w9lE898Nahc6lpry3Th3WUpuCgZGAe31rXrnvBf/IHl/6+D/6CtdDXYzlC iiigYUUUUAFF
FFABRRRQAUUUUAFFFFABRRRQAUUUUAFNd1jjaRzhVBJPoKdWJq8lxql/B4e0 7m4uWHmt2Rev
P4cn2+tAFnwxoZ8aanJqeobv7LtX2wwdPMb3/TP1xXqKIsaKiKFRRhVUYAHo Kq6Tplvo2lwa
fbDEcCbc92Pcn3J5q5XmVajnK/Q7qcOVBRRRWRoFFFFABRRRQAUUUUAFFFFA BRRRQAUUUUAF
FFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUU UUAFFFFABRRR
QAUUUUAFFFFABRRRQAUUUUAFeX6qn2X4m6gvRbmBXH12r/ga9Qrzfxonk/EP TJhwJrUqfcgv
/iK6cM/fMK690nooorvOQKKKKACiiigAooooAKKKKACiiigAooooAKKKKACi iigAooooAK57
xp/yB4v+vgf+gtXQ1z3jT/kDxf8AXwP/AEFqBHplFFFeadxX1C8j07T572UE pBGXIHU4HQVl
21prd7apdzaq1nNIocW8cKNHHnkA5GT78irfiG0lvvD99bQLulkhYIv94+lN 0/XdPu9MS6N1
FEFQeasjhTE2OQwPQirW10S99Sjq9xqQ1XRNNS9Nu12sv2iSGNeSiA8BgcDO akmuNS0S6tTd
XQvrGeQQu7xhJImY4U/LgFc8dAear6vcwt4p8NXIkUQutywdjgYMYx1qTXbu DU5LXSLOVLid
7iOSXyzuESKQxLEdOgAz1zV220J7lm9vLy71n+ybGX7OI4RNcXO0MVBJCqoP GTgnJFQXMuo6
DPbTS30l/ZTTLDKJkQPEWOAwKgZGcZBFDXCaZ4vna7YRQ39vGIpXICl0JBTP r82aTxFcQ35t
NItpFluJriN2VGBMcasGLH0HGPqaSWqXQbC+mv7rxculwahLaQCw+0HykQkt 5m3+IHtU2iX9
7JqWpabeSC4Ni6BLkJt3hlzggcZHt+QqhfWMOofEAQzmUKNK3DypWjOfNI6q Qe9TaVHJZw6r
okZAuIA0kMhXmVXB2s2PvEHIJ6nFNpWFrc0G8RaWspQzvtD+WZvKfyg2cY34 29eOvWrF5qll
YSpHdTiJpFLKCDyAQDj3yw46nNYOlwrfeD4bWTU4YoGthDKvlgGM4wwJJ4I5 61LqT2tn4l0L
7VIu1IZkSSTpuwgBz2z6+9LlV7D5na5sWOrWeovJHbu/mRY3xyRtGwB6HDAH HvUNz4g060mk
hkkldof9aYoHkEf+8VBAPtVMSQ3PjdGtirtBYstw6c43MCik+vBOKZ4YuoLX RZo7yeKO4gnm
N1vIXDbycnPbGKXKtx3ZsS6lZw2AvmnU27AFXX5t2emMdSfQVWl1S2udLu50 nntVhjYvI9uy
tGMZ3BWHP5VkaVZW114VghknNkkt001mwwpX94zpgHjoM49KW9v7qbR9e0+7 eGeS1tCfPgGF
bcrcEZOG46Z7inyq4uZlzVtdGj2NiVZ7h5niUyNCzbkJAZvlGAxByB69qvnV rJNO+3ySNFAT
gGSNlYnOMBSM5z0GOay9aIXQNMdjhVubUsT0A3LyafrsqrqmiXMkifY47lxI x6ByhCEntzml
ZOwXZoWes2N9cG2ieRJwu7y5oXjYr6gMBkfSmXOv6bazSQyTMZY32NHHEzsD tDZwATjBHPTm
qWqSQXPiPRooGSS5ikklbaQSkewgk+gJIHvTtGjT/hItdl2DeZol3Y5x5a8U cq3Hd7GraXtv
fRu9vJvEcjRPwQVZTgjmizvLe/txcW0nmRFmUNgjJBIPX3BrmtVu5NC1O/ih J3atGrWq8YE+
RGf/AEJG/A10tjaR2FhBZxfcgjCD3wKTVlcE7snoooqCjzPwX/yB5f8Ar4P/ AKCtdDXPeC/+
QPL/ANfB/wDQVroa9NnCFFFFIYUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUU VW1C5+x6fPcj
GY0JXPTPb9aAK2r6zBpcRUkPcsP3cQ5JPbPtXR+AvDMml2smq6ipOpXvzNu6 xoedvsT1P4Dt
VX4f+GYPscfiLUP9JvrrLxlxkRDOAR7nHXsOBXdVxV61/cR1UqdveYUUUVyH QFFFFABRRRQA
UUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABR RRQAUUUUAFFF
FABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABXn/xMtp7e 60rW0iMkFq5S
Yr1XJGP6/p616BUN5aQ39nNaXCB4ZkKOp7g1dOfJJMiceaNjgIJo7mBJomDR uMqR3FSViaEk
mm32oaHMxLWUx2E91z1/kfxrbr1TgCiiigAooooAKKKKACiiigAooooAKKKK ACiiigAooooA
KKKKACue8af8geL/AK+B/wCgtXQ1z3jT/kDxf9fA/wDQWoEemUVn/wDCQaL/ ANBiw/8AAlP8
aP8AhINF/wCgxYf+BKf415/K+x23RoVVk0vTprkXUljbPOOkjRKW/PFQ/wDC QaL/ANBiw/8A
AlP8aP8AhINF/wCgxYf+BKf40WkF0WLqws75VW7tILgJ90Sxh9v0zT7e1t7S Py7aCOFP7saB
R+Qqp/wkGi/9Biw/8CU/xo/4SDRf+gxYf+BKf40WkF0XJ7eC6iMNxDHNG3VJ FDA/gajtLCzs
FK2dpDbhuSIowufriq//AAkGi/8AQYsP/AlP8aP+Eg0X/oMWH/gSn+NFpBdF z7PB9p+0+TH5
+zy/N2jdtznbnrjPOKPs8H2n7T5Mfn7Nnm7Ru25zjPXGe1U/+Eg0X/oMWH/g Sn+NH/CQaL/0
GLD/AMCU/wAaLMLokl0jTZ7kXMun20k4OfMaJS2friobzTXutas7thG0EMMs ciPzu3bccYwR
wad/wkGi/wDQYsP/AAJT/Gj/AISDRf8AoMWH/gSn+NP3haFq1s7Wxi8q0t4o EznbGgUZ/Co7
jStPurhbi4sbeaZcYkeJWYY6ckVD/wAJBov/AEGLD/wJT/Gj/hINF/6DFh/4 Ep/jStId0XJ7
aC6hMNxDHLEeqOoYH8DUcVhZwWrWkVpCluwIaJYwFIPXI6VX/wCEg0X/AKDF h/4Ep/jR/wAJ
Bov/AEGLD/wJT/Gi0gui5Jbwy25t5IUeErtMbKCpHpimJY2cdn9jS1hW2wR5 IjGzB68dKrf8
JBov/QYsP/AlP8aP+Eg0X/oMWH/gSn+NFpBdFi00+zsFZbO0htwxyRFGFz+V SpDFHJJIkSI8
pBdlUAsQMAk9+Kpf8JBov/QYsP8AwJT/ABo/4SDRf+gxYf8AgSn+NFpBdDb3 T5bzWbC4fZ9m
s98mP4mkIwO3QAk/XFaVZ/8AwkGi/wDQYsP/AAJT/Gj/AISDRf8AoMWH/gSn +NFn2C6NCis/
/hINF/6DFh/4Ep/jR/wkGi/9Biw/8CU/xo5X2C6OD8F/8geX/r4P/oK10Nc9 4L/5A8v/AF8H
/wBBWuhr0WcQUUUUhhRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABWLb2Wo+NtQ lsLPbBptvIBP
OTy309enA/Optf1E2FgViybif93Eo65Pf8P8K7jwboR8P+HILSRQLh/3s+P7 57fgMD8KxrVO
SOm5pThzvU17S1isrOG0gXbFAgjQegAwKmoorzTuCiiigAooooAKKKKACiii gAooooAKKKKA
ooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAPMvGVs+g+M49ZZf9D1BB HIw/gYADn8gf
zq2CGAZSCDyCO9dlrmlW+taRcWNxGHEiHZnqrY4I9wa8z8JztNowjcktC5TB 6gdf616NCfNG
3Y4q0eWV+5t0UUVuZBRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FV7yxttQg8m6
iEked2Mkc/hViigDJ/4RfRv+fP8A8iv/AI0f8Ivo3/Pn/wCRX/xrWooEZP8A wi+jf8+f/kV/
8aP+EX0b/nz/APIr/wCNa1FAGT/wi+jf8+f/AJFf/Gj/AIRfRv8Anz/8iv8A 41rUUAZP/CL6
N/z5/wDkV/8AGj/hF9G/58//ACK/+Na1FAGT/wAIvo3/AD5/+RX/AMaP+EX0 b/nz/wDIr/41
rUUAZP8Awi+jf8+f/kV/8ayPEWnaPpdiBDagXEpwn7xjgdz1rra5PW9Nupm1 DUb0AJEoW2UN
njI5/wA9zTQEmg6Xo2qacsj2g85PllHmP19evetL/hF9G/58/wDyK/8AjWdo em3VpdWd5agG
2uYB54LfdOOv5/1rp6AMn/hF9G/58/8AyK/+NH/CL6N/z5/+RX/xrWopAZP/ AAi+jf8APn/5
Ff8Axo/4RfRv+fP/AMiv/jWtRQBk/wDCL6N/z5/+RX/xo/4RfRv+fP8A8iv/ AI1rUUAZP/CL
6N/z5/8AkV/8aP8AhF9G/wCfP/yK/wDjWtRQBk/8Ivo3/Pn/AORX/wAaP+EX 0b/nz/8AIr/4
1rUUAV7OxttPhMNrEI0LbiMk8/jViiigYUUUUAFFFFABRRRQAUUUUAFFFFAB RRRQAUUVV1K/
i02ye5l/hGFX+8ewoAqwIt58RNHt8bxDmVh/dIBYf+gj9K9Vrifh5oE0MMvi DUV/0y+GYww+
5H/TPH4AV21efiJqU9Oh2UYtR1Ciiiuc2CiiigAooooAKKKKACiiigAooooA KKKKACiiigAo
ACiiigAooooAKKKKACiiigAooooAKKKKACvKbu1PhvxtdWLD/RdRPnQN6Ekn H55H5V6tXG/E
zSjdaAmpwgi406QSKw67SQD+uD+Fb0J8s7dzKtG8fQoUV
Re: [CDO] Does CDO fit in our scenario? [message #619100 is a reply to message #124001] Fri, 30 May 2008 08:44 Go to previous message
Hi Marc,
gr. Martin
Marc Moser wrote:
> follows..
> right now.
> Best,
> Marc
The Netherlands
Re: [CDO] Does CDO fit in our scenario? [message #619121 is a reply to message #124001] Sat, 31 May 2008 13:42 Go to previous message
Marc,
you asked for?
TwoTransports
Cheers
/Eike
Marc Moser schrieb:
> follows..
> right now.
> Best,
> Marc
<html>
<head>
</head>
Marc,<br>
<br>
<br>
<br>
<br>
Cheers<br>
/Eike<br>
<br>
<br>
type="cite">
<pre wrap="">Hi,
follows..
right now.
Best,
Marc
</pre>
</blockquote>
</body>
</html>
zSjdaAmpwgi406QSKw67SQD+uD+Fb0J8s7dzKtG8fQoUVBY3S3tlDcr0kQNj 0PcfnU9eicQU
Previous Topic:[CDO] Export to an EMF resource?
Next Topic:Are CDO Transactions transparent?
Current Time: Sat Jul 19 19:45:18 EDT 2025
Powered by FUDForum. Page generated in 0.06218 seconds
