Home » Modeling » EMF » Loading Enum from other ecore file
Loading Enum from other ecore file [message #1234706] Wed, 22 January 2014 11:25 Go to next message
i have one ecore with enums (states) and a other ecore uses the 1st ecore
so the enum in 1st ecore file is e.g.
State implements Enumerator
ACTIVE(0, "ACTIVE", "ACTIVE"),
INACTIVE(1, "INACTIVE", "INACTIVE");
the 2nd ecore file is e.g.
public class AImpl extends EObjectImpl implements A
State state;
Now i can save A, but i cannot load it:
public void saveModelWorks()
Resource resource = createResource();
A a = ...
a.setState(State.ACTIVE)
resource.getContents().add(a);
try
resource.save(Collections.EMPTY_MAP);
catch (IOException e)
public Master loadModelDoesntWork()
try
resource.load(Collections.EMPTY_MAP);
LOGGER.error("Error loading", e);
private Resource createResource()
final ResourceSet resourceSet = new ResourceSetImpl();
resourceSet.getPackageRegistry()
.put(StateModelPackage.eNS_URI, StateModelPackage.eINSTANCE);
resourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap()
.put("binary", new ResourceFactoryImpl()
public Resource createResource(URI uri)
return new BinaryResourceImpl(uri);
return resourceSet.createResource(URI.createFileURI("bla.binary"));
java.lang.IllegalArgumentException: The value 'ACTIVE' is invalid.
at org.eclipse.emf.ecore.impl.EFactoryImpl.createFromString(EFactoryImpl.java:471)
at AFactoryImpl.createEnumFromString(ModelFactoryImpl.java:227)
So what could i do?
Re: Loading Enum from other ecore file [message #1240939 is a reply to message #1234706] Fri, 07 February 2014 03:45 Go to previous messageGo to next message
Comments below.
On 22/01/2014 5:25 PM, Sir Wayne wrote:
> Hello,
> ACTIVE(0, "ACTIVE", "ACTIVE"), INACTIVE(1, "INACTIVE",
> "INACTIVE");
> State state;
> A a = ...
> try
> try
> @Override
> return
> at
> So what could i do?
Do you have an EDataType/EEnum called "Enum"? The method name
createEnumFromString appears to imply that's the case...
> Thanks
Re: Loading Enum from other ecore file [message #1274331 is a reply to message #1240939] Fri, 21 March 2014 06:01 Go to previous message
Thanks for reply, after debbuging is saw my case doesn't work
Previous Topic:Editing maps in property sheets
Next Topic:EMF filter EList
Current Time: Sat Jul 19 13:25:45 EDT 2025
Powered by FUDForum. Page generated in 0.05347 seconds
