Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [CDO Hibernate] Problem with containingClass of CDOFeatures
[CDO Hibernate] Problem with containingClass of CDOFeatures [message #123872] Thu, 29 May 2008 15:17 Go to next message
Hi Eike, Martin,
I have an Ecore model composed of multiple packages and I have
cross-references between packages. For example:
Package pgk1:
Class A
Package pkg2:
Class B extends A
My problem arise when I read the packages from the database. I first
launch my server, populate the database with some data. Then I shutdown
the server, launch it again and I try to add data. When adding data, I
get an exception about cdoFeature.containingClass is null.
I've looked at the code and I know where the problem is, but I'm really
not sure what would be the ideal solution. The problem can be seen in
HibernatePackageHandler.readPackage(CDOPackage). This method first
loads the package, then goes through all the classes, then through all
the features and for each feature, its containingClass is set. The
problem I have is when pkg2 is read, the features contained in Class A
(also available in Class B by inheritance) and created by Hibernate, but
their containingClass attribute are never initialized. So the
features defined in Class B are fine, but not the ones in coming from
Class A. So when I try to persist an object of Class B, I get a
NullpointerException.
So what would be the ideal solution here? I was expecting to see each
CDOFeature being created only once (aren't they supposed to be unique?)
and not every time a package is read. Is it related only to
cross-package inheritance? If I put all of my classes under the same
package, everything works.
Eric
Re: [CDO Hibernate] Problem with containingClass of CDOFeatures [message #123885 is a reply to message #123872] Thu, 29 May 2008 15:31 Go to previous messageGo to next message
Originally posted by: stepper.sympedia.de
Hi Eric, Martin
I'm not sure why the containingClass is explicitely set here, because it
should already be set in
org.eclipse.emf.cdo.internal.protocol.model.CDOClassImpl.set Features(List <CDOFeature>)
whih should be called by Hibernate, if I see that correctly.
More important, which of the fields in CDOClassImpl do you mean:
- features
- allFeatures
I think only the first should be persisted by Hibernate and the second
is automatically created on demand.
Actually I don't know how exactly the Hibernate mapping looks like.
Martin, should Eric file a bug?
Cheers
/Eike
Eric schrieb:
> Hi Eike, Martin,
> Package pgk1:
> Class A
> Package pkg2:
> Class B extends A
> shutdown the server, launch it again and I try to add data. When
> adding data, I get an exception about cdoFeature.containingClass is null.
> really not sure what would be the ideal solution. The problem can be
> seen in HibernatePackageHandler.readPackage(CDOPackage). This method
> first loads the package, then goes through all the classes, then
> through all the features and for each feature, its containingClass is
> set. The problem I have is when pkg2 is read, the features contained
> in Class A (also available in Class B by inheritance) and created by
> Hibernate, but their containingClass attribute are never
> initialized. So the features defined in Class B are fine, but not the
> ones in coming from Class A. So when I try to persist an object of
> Class B, I get a NullpointerException.
> unique?) and not every time a package is read. Is it related only to
> Eric
Re: [CDO Hibernate] Problem with containingClass of CDOFeatures [message #123911 is a reply to message #123885] Thu, 29 May 2008 15:54 Go to previous messageGo to next message
Well, I can confirm that
is not being called.
Also of note, in CDOClassImpl, the features attribute is set, and
allFeatures is null (since as you pointed out, it is only created on
demand).
Eike Stepper wrote:
> Hi Eric, Martin
> - features
> - allFeatures
> Cheers
> /Eike
> Eric schrieb:
>> Hi Eike, Martin,
>> Package pgk1:
>> Class A
>> Package pkg2:
>> Class B extends A
>> Thanks,
>> Eric
Re: [CDO Hibernate] Problem with containingClass of CDOFeatures [message #123923 is a reply to message #123911] Thu, 29 May 2008 16:01 Go to previous messageGo to next message
I fear we have to ask Martin. He's currently absent but when he returns
it would be good to have a Bugzilla (hint) ;-)
> demand).
> Eike Stepper wrote:
>> Hi Eric, Martin
>> it should already be set in
>> - features
>> - allFeatures
>> second is automatically created on demand.
>> Cheers
>> /Eike
>> Eric schrieb:
>>> Hi Eike, Martin,
>>> Package pgk1:
>>> Class A
>>> Package pkg2:
>>> Class B extends A
>>> first launch my server, populate the database with some data. Then
>>> I shutdown the server, launch it again and I try to add data. When
>>> null.
>>> be seen in HibernatePackageHandler.readPackage(CDOPackage). This
>>> method first loads the package, then goes through all the classes,
>>> then through all the features and for each feature, its
>>> containingClass is set. The problem I have is when pkg2 is read,
>>> the features contained in Class A (also available in Class B by
>>> inheritance) and created by Hibernate, but their containingClass
>>> attribute are never initialized. So the features defined in Class B
>>> are fine, but not the ones in coming from Class A. So when I try to
>>> persist an object of Class B, I get a NullpointerException.
>>> each CDOFeature being created only once (aren't they supposed to be
>>> to cross-package inheritance? If I put all of my classes under the
>>> same package, everything works.
>>> Thanks,
>>> Eric
Re: [CDO Hibernate] Problem with containingClass of CDOFeatures [message #123949 is a reply to message #123923] Thu, 29 May 2008 17:44 Go to previous messageGo to next message
Hi Eric,
Can you enter a bugzilla for this? I hope to have time tomorrow to look at it.
gr. Martin
>> demand).
>> Eike Stepper wrote:
>>> Hi Eric, Martin
>>> - features
>>> - allFeatures
>>> Cheers
>>> /Eike
>>> Eric schrieb:
>>>> Hi Eike, Martin,
>>>> Package pgk1:
>>>> Class A
>>>> Package pkg2:
>>>> Class B extends A
>>>> null.
>>>> Thanks,
>>>> Eric
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [CDO Hibernate] Problem with containingClass of CDOFeatures [message #124137 is a reply to message #123949] Fri, 30 May 2008 09:09 Go to previous message
Bug entry: https://bugs.eclipse.org/bugs/show_bug.cgi?id=234829
Martin Taal wrote:
> Hi Eric,
> at it.
> gr. Martin
>> returns it would be good to have a Bugzilla (hint) ;-)
>>> demand).
>>> Eike Stepper wrote:
>>>> Hi Eric, Martin
>>>> because it should already be set in
>>>> - features
>>>> - allFeatures
>>>> Cheers
>>>> /Eike
>>>> Eric schrieb:
>>>>> Hi Eike, Martin,
>>>>> Package pgk1:
>>>>> Class A
>>>>> Package pkg2:
>>>>> Class B extends A
>>>>> null.
>>>>> B are fine, but not the ones in coming from Class A. So when I try
>>>>> to persist an object of Class B, I get a NullpointerException.
>>>>> Thanks,
>>>>> Eric
Re: [CDO Hibernate] Problem with containingClass of CDOFeatures [message #619083 is a reply to message #123872] Thu, 29 May 2008 15:31 Go to previous message
Hi Eric, Martin
- features
- allFeatures
Cheers
/Eike
Eric schrieb:
> Hi Eike, Martin,
> Package pgk1:
> Class A
> Package pkg2:
> Class B extends A
> Eric
Re: [CDO Hibernate] Problem with containingClass of CDOFeatures [message #619085 is a reply to message #123885] Thu, 29 May 2008 15:54 Go to previous message
demand).
Eike Stepper wrote:
> Hi Eric, Martin
> - features
> - allFeatures
> Cheers
> /Eike
> Eric schrieb:
>> Hi Eike, Martin,
>> Package pgk1:
>> Class A
>> Package pkg2:
>> Class B extends A
>> Thanks,
>> Eric
Re: [CDO Hibernate] Problem with containingClass of CDOFeatures [message #619086 is a reply to message #123911] Thu, 29 May 2008 16:01 Go to previous message
> demand).
> Eike Stepper wrote:
>> Hi Eric, Martin
>> - features
>> - allFeatures
>> Cheers
>> /Eike
>> Eric schrieb:
>>> Hi Eike, Martin,
>>> Package pgk1:
>>> Class A
>>> Package pkg2:
>>> Class B extends A
>>> null.
>>> Thanks,
>>> Eric
Re: [CDO Hibernate] Problem with containingClass of CDOFeatures [message #619088 is a reply to message #123923] Thu, 29 May 2008 17:44 Go to previous message
Hi Eric,
gr. Martin
>> demand).
>> Eike Stepper wrote:
>>> Hi Eric, Martin
>>> - features
>>> - allFeatures
>>> Cheers
>>> /Eike
>>> Eric schrieb:
>>>> Hi Eike, Martin,
>>>> Package pgk1:
>>>> Class A
>>>> Package pkg2:
>>>> Class B extends A
>>>> null.
>>>> Thanks,
>>>> Eric
The Netherlands
Re: [CDO Hibernate] Problem with containingClass of CDOFeatures [message #619102 is a reply to message #123949] Fri, 30 May 2008 09:09 Go to previous message
Martin Taal wrote:
> Hi Eric,
> at it.
> gr. Martin
>>> demand).
>>> Eike Stepper wrote:
>>>> Hi Eric, Martin
>>>> - features
>>>> - allFeatures
>>>> Cheers
>>>> /Eike
>>>> Eric schrieb:
>>>>> Hi Eike, Martin,
>>>>> Package pgk1:
>>>>> Class A
>>>>> Package pkg2:
>>>>> Class B extends A
>>>>> null.
>>>>> Thanks,
>>>>> Eric
Previous Topic:[CDO] Does CDO fit in our scenario?
Next Topic:[CDO] Exception when using ' in Strings
Current Time: Sun Jul 20 03:46:53 EDT 2025
Powered by FUDForum. Page generated in 0.04939 seconds
