Home » Eclipse Projects » Eclipse 4 » NoSuchFieldError: LOCALIZABLE___UPDATE_LOCALIZATION on Eclipse 4 model editor
NoSuchFieldError: LOCALIZABLE___UPDATE_LOCALIZATION on Eclipse 4 model editor [message #1238169] Fri, 31 January 2014 10:10 Go to next message
today I wanted to look at the latest version of Luna and the E4 framework.
For that I have used the Luna M5 developer build as well as the E4 tools
of Lars Vogellas repository ( http://download.vogella.com/luna/e4tools )
I now open a e4xmi file with the E4 model editor I get in the branch
"Windows and Dialogs" and deeper constantly following error.
Is it a known bug, or what am I doing wrong?
Greetings
Heiko
java.lang.NoSuchFieldError: LOCALIZABLE___UPDATE_LOCALIZATION
at
org.eclipse.e4.tools.emf.ui.internal.common.component.ControlFactory.getLocalizedLabel(ControlFactory.java:826)
at
org.eclipse.e4.tools.emf.ui.common.component.AbstractComponentEditor.getLocalizedLabel(AbstractComponentEditor.java:155)
at
org.eclipse.e4.tools.emf.ui.internal.common.component.PerspectiveEditor.getDetailLabel(PerspectiveEditor.java:148)
at
org.eclipse.e4.tools.emf.ui.internal.common.ComponentLabelProvider.update(ComponentLabelProvider.java:77)
at org.eclipse.jface.viewers.ViewerColumn.refresh(ViewerColumn.java:152)
at
org.eclipse.jface.viewers.AbstractTreeViewer.doUpdateItem(AbstractTreeViewer.java:959)
at
org.eclipse.jface.viewers.AbstractTreeViewer$UpdateItemSafeRunnable.run(AbstractTreeViewer.java:113)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:49)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:176)
at
org.eclipse.jface.viewers.AbstractTreeViewer.doUpdateItem(AbstractTreeViewer.java:1040)
at
org.eclipse.jface.viewers.StructuredViewer$UpdateItemSafeRunnable.run(StructuredViewer.java:489)
at
org.eclipse.jface.viewers.StructuredViewer.updateItem(StructuredViewer.java:2180)
at
org.eclipse.jface.viewers.AbstractTreeViewer.createTreeItem(AbstractTreeViewer.java:851)
at
org.eclipse.jface.viewers.AbstractTreeViewer$1.run(AbstractTreeViewer.java:826)
at
org.eclipse.jface.viewers.AbstractTreeViewer.createChildren(AbstractTreeViewer.java:800)
at org.eclipse.jface.viewers.TreeViewer.createChildren(TreeViewer.java:670)
at
org.eclipse.jface.viewers.AbstractTreeViewer.createChildren(AbstractTreeViewer.java:771)
at
org.eclipse.jface.viewers.AbstractTreeViewer.handleTreeExpand(AbstractTreeViewer.java:1510)
at
org.eclipse.jface.viewers.TreeViewer.handleTreeExpand(TreeViewer.java:985)
at
org.eclipse.jface.viewers.AbstractTreeViewer$4.treeExpanded(AbstractTreeViewer.java:1522)
at
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:132)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4353)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1061)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1085)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1070)
at org.eclipse.swt.widgets.Tree.wmNotifyChild(Tree.java:7633)
at org.eclipse.swt.widgets.Control.wmNotify(Control.java:5618)
at org.eclipse.swt.widgets.Composite.wmNotify(Composite.java:1935)
at org.eclipse.swt.widgets.Control.WM_NOTIFY(Control.java:5169)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4666)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:5020)
at org.eclipse.swt.internal.win32.OS.CallWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.CallWindowProc(OS.java:2443)
at org.eclipse.swt.widgets.Tree.callWindowProc(Tree.java:1553)
at org.eclipse.swt.widgets.Tree.WM_LBUTTONDOWN(Tree.java:6501)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4646)
at org.eclipse.swt.widgets.Tree.windowProc(Tree.java:6024)
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:2549)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3759)
at
org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1122)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
at
org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1006)
at
org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:146)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:615)
at
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:566)
at
org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:125)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:109)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:80)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:372)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:226)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
Re: NoSuchFieldError: LOCALIZABLE___UPDATE_LOCALIZATION on Eclipse 4 model editor [message #1238172 is a reply to message #1238169] Fri, 31 January 2014 10:17 Go to previous message
The latest tools require the latest Luna. They are in sync. Can you reproduce that with http://download.eclipse.org/eclipse/downloads/drops4/N20140130-2000/ ?
Previous Topic:How to implement a Job that can be canceled
Next Topic:own OSGI Service in Eclipse 4 Application
Current Time: Sun Jul 20 16:44:43 EDT 2025
Powered by FUDForum. Page generated in 0.02899 seconds
