Home » Eclipse Projects » Rich Client Platform (RCP) » Bundling web browser with RCP app
Bundling web browser with RCP app [message #1008448] Tue, 12 February 2013 09:31 Go to next message
I have a RCP application which utilizes the SWT Browser. I'm currently developing on Linux and I'm using libwebkitgtk as the browser. This works fine, but I want to target Windows as well. According to the SWT FAQ one can only use WebKit if Safari is installed, or an old version of Firefox/XULRunner. I can probably live with a legacy browser, but I dont want the user to have the hassle of installing a browser or other software to make it work.
I have a few questions relating to this:
Is it possible to bundle my RCP app with a proper version of FF/XULRunner/WebKit?
If so, how do I do this?
I think I read somewhere that I can get the 10.x series of XULRunner working using XPCOM directly, is this so?
Re: Bundling web browser with RCP app [message #1010817 is a reply to message #1008448] Mon, 18 February 2013 04:37 Go to previous messageGo to next message
AFAIK, the SWT browser uses IE on Windows by default, so there is no
(direct) need to bundle a browser. It may look/behave different than
Webkit, though.
Am 12.02.2013 15:31, schrieb navlelo Mising name:
Re: Bundling web browser with RCP app [message #1015471 is a reply to message #1008448] Thu, 28 February 2013 11:29 Go to previous messageGo to next message
If you don't really care which native browser renderer is used (webkit,
mozilla, etc.), then create all of your Browsers with style SWT.NONE,
and users will not need to install anything on any platforms, the
OS-provided renderer will always be used.
If you want a consistent native renderer across the platforms then
XULRunner is currently your only choice, in which case you would ship a
XULRunner binary on every supported platform, point at them at runtime
as described in http://www.eclipse.org/swt/faq.php#specifyxulrunner, and
set the org.eclipse.swt.browser.DefaultType property as described in
http://www.eclipse.org/swt/faq.php#browserspecifydefault .
Grant
Re: Bundling web browser with RCP app [message #1237879 is a reply to message #1015471] Thu, 30 January 2014 16:06 Go to previous messageGo to next message
Hi, I am having trouble instantiating a mozilla browser on my windows 7 64-bit machine. I tried using Eclipse kepler 4.3.1 with xulrunner 10.0.x, as well as Eclipse luna 4.4.0 with xulrunner 10.0.x & xulrunner 24. I get the same XPCOM error resulting from the same location - when stepping through the debugger, this error occurs in the Mozilla class:
int rc = XPCOM.XPCOMGlueStartup (path);
rc is 0x80004005 (or -2147467259).
I followed the guidance on the SWT FAQ page.
Windows (x86_64): (@since 4.3) Any XULRunner release with version 1.9.2.x - 3.6.x, 10.x or 24.x, and the Visual C++ 2010 runtime must be installed .
Been searching everywhere for a solution and tried pretty much everything I could find. I also tried downloading SWT 4.4 separately and including it as a dependency in my project, suggested by someone at this stackoverflow post (can't post link cuz I'm a newbie):
"Got it! It's an error on SWT wiki: xulrunner 24.x requires SWT 4.4. I've installed swt-4.4M5 and now I can embed xurlrunner 24 64bit"
but I'm not sure I did that correctly. Any help/advice would be much appreciated.
Thank you.
Re: Bundling web browser with RCP app [message #1237880 is a reply to message #1237879] Thu, 30 January 2014 16:09 Go to previous message
Btw, the XULRunnerPath is set: -Dorg.eclipse.swt.browser.XULRunnerPath=[absolute path to xulrunner]\xulrunner24win
Previous Topic:Problems with folding text in viewpart
Next Topic:Read file in fragment in junit test
Current Time: Sun Jul 20 13:06:21 EDT 2025
Powered by FUDForum. Page generated in 0.03773 seconds
