Home » Modeling » TMF (Xtext) » antlr error with the workflow file
antlr error with the workflow file [message #1237269] Wed, 29 January 2014 04:19 Go to next message
Hi there,
i have recently installed the following eclipse:
DSL tools Eclipse DSL Tools
Version: Kepler Service Release 1
Build id: 20130919-0819
And i want to use my existing code using the generated code based on Xtext 1.0. But if i want to generate the code with new new Xtext Framework it yields this strange error:
[main] INFO lipse.emf.mwe.utils.StandaloneSetup - Registering platform uri 'H:\Tools\Java_tooling\cdsi_gen'
2765 [main] ERROR eclipse.emf.mwe.core.WorkflowEngine - [ERROR]:
ATTENTION!
The Antlr generator fragment couldn't be found on the classpath.
It is highly recommended to install the feature 'Xtext Antlr SDK' using the external updatesite:
(see http://www.eclipse.org/Xtext/download.html for details).
(Element: -UNKNOWN-; Reported by: -UNKNOWN-)
2765 [main] ERROR eclipse.emf.mwe.core.WorkflowEngine - Workflow interrupted because of configuration errors
The workflow file i use is enclosed in this thread. Do you know how to eliminate this error?
Re: antlr error with the workflow file [message #1237282 is a reply to message #1237269] Wed, 29 January 2014 04:44 Go to previous messageGo to next message
In your project directory, you will find something like: .antlr-generator-3.2.0.jar
Delete this file and rerun the MWE on your XTEXT file.
Then you will be prompted to reply "y" to download the antlr.
At least this worked for me
Re: antlr error with the workflow file [message #1237290 is a reply to message #1237282] Wed, 29 January 2014 05:08 Go to previous messageGo to next message
Thanks, i tried it but it didn't work. And the package de.itemis.xtext.antlr is dependent on this antlr version. If i remove this jar then the manifest cannot find the dependency. Du you have the same eclipse version as i posted?
[Updated on: Wed, 29 January 2014 05:08] by Moderator
Re: antlr error with the workflow file [message #1237305 is a reply to message #1237290] Wed, 29 January 2014 05:50 Go to previous messageGo to next message
I use Kepler, but if you run on XTEXT 1.0, perhaps you have to MIGRATE to xtext2 (see xtext documentation Chapter 13).
Or your XTEXT 1.0 is just looking for an older ANTLR fragment which is not part of the current delivery.
Whats about the site referenced in your "It is highly recommended to install the feature 'Xtext Antlr SDK' using the external updatesite:"
Re: antlr error with the workflow file [message #1237358 is a reply to message #1237305] Wed, 29 January 2014 08:53 Go to previous message
I already migrated to Xtext 2.0. But the reason was this fragment in the workflow file:
<fragment class="org.eclipse.xtext.generator.AntlrDelegatingFragment" />
After i replaced it with this line, it worked:
<fragment class="org.eclipse.xtext.generator.parser.antlr.XtextAntlrGeneratorFragment" />
Previous Topic:ERROR org.eclipse.xtext.builder.impl.XtextBuilder - java.lang.ClassCastException: org.eclipse.xtext
Next Topic:grammar for ecore metamodel
Current Time: Sat Jul 19 17:59:49 EDT 2025
Powered by FUDForum. Page generated in 0.03822 seconds
