Home » Newcomers » Newcomers » OpenSuse Linux 12.1 (64-Bit): A fatal error has been detected by the JRE(A fatal error has been detected by the JRE)
OpenSuse Linux 12.1 (64-Bit): A fatal error has been detected by the JRE [message #1234671] Wed, 22 January 2014 09:30 Go to next message
Dear Forum
Following message appears in the Eclipse Console:
# A fatal error has been detected by the Java Runtime Environment:
# SIGSEGV (0xb) at pc=0x00007fd5944ef462, pid=8497, tid=140555291883264
# JRE version: 6.0_27-b27
# Java VM: OpenJDK 64-Bit Server VM (20.0-b12 mixed mode linux-amd64 compressed oops)
# Derivative: IcedTea6 1.12.5
# Distribution: Dummy Product (x86_64), package suse-36.2-x86_64
# Problematic frame:
# C [librxtxSerial.so+0x6462] read_byte_array+0x52
I already have installed JRE version: 6.0_27-b27. Should I install JRE V1.7 or is that a bug of Eclipse?
If I have to install JRE V1.7 - first, do I have to deinstall JRE V1.6 or can I install JRE V1.7 parallel. What I have care about?
Best regards
Joerg
Re: OpenSuse Linux 12.1 (64-Bit): A fatal error has been detected by the JRE [message #1234777 is a reply to message #1234671] Wed, 22 January 2014 14:30 Go to previous message
On 01/22/2014 07:44 AM, Joerg Kuehne wrote:
> Dear Forum
> compressed oops)
> Best regards
> Joerg
This really isn't an Eclipse question though it is one that plagues some
Linux users of Eclipse. I abandoned SuSE a few years back for Ubuntu so
I can't speak directly to that Linux distro. For that, you'd have to
visit a SuSE forum. (This is the responsible answer; for less compelling
musings, read on...)
My opinion is that, yes, you do want to run Java 7 and you can and
should be able to run OpenJDK.
However, I found this page which seems to suggest that, in some cases,
you'll want a proper Sun JDK. For what it's worth:
http://www.ciselant.de/projects/jdk/index.html
Previous Topic:Eclipse: Javadoc Hyperlink Color
Next Topic:Scope of Eclipse
Current Time: Sun Jul 20 15:52:40 EDT 2025
Powered by FUDForum. Page generated in 0.06497 seconds
