emtl files not created when the imported projects are not copied in the workspace [message #1234414] |
Tue, 21 January 2014 18:16  |
it seems there is an issue with the ant script when the files are not copied in the workspace because emtl files are not generated leading to this error below. This error does not exist if files are copied.
here follows the complete error stack
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException: org.eclipse.core.internal.resources.ResourceException: Resource '/org.eclipse.robotml.generators.acceleo.athena/bin/org/eclipse/robotml/generators/acceleo/athena/mmqueries/MMSpecificQueries.emtl' does not exist.
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDemandLoadException(ResourceSetImpl.java:319)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:278)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResource(ResourceSetImpl.java:406)
at org.eclipse.acceleo.common.utils.ModelUtils.load(ModelUtils.java:361)
at org.eclipse.acceleo.internal.parser.compiler.AcceleoParser.doBuild(AcceleoParser.java:627)
at org.eclipse.acceleo.internal.parser.compiler.AcceleoParser.build(AcceleoParser.java:431)
at org.eclipse.acceleo.internal.parser.compiler.AcceleoParser.build(AcceleoParser.java:319)
at org.eclipse.acceleo.internal.parser.compiler.AcceleoParser.computeModuleFileDependency(AcceleoParser.java:468)
at org.eclipse.acceleo.internal.parser.compiler.AcceleoParser.build(AcceleoParser.java:399)
at org.eclipse.acceleo.internal.parser.compiler.AcceleoParser.buildImpactedModules(AcceleoParser.java:763)
at org.eclipse.acceleo.internal.parser.compiler.AcceleoParser.build(AcceleoParser.java:436)
at org.eclipse.acceleo.internal.parser.compiler.AcceleoParser.buildAll(AcceleoParser.java:262)
at org.eclipse.acceleo.internal.ide.ui.builders.AcceleoBuilder.buildAll(AcceleoBuilder.java:278)
at org.eclipse.acceleo.internal.ide.ui.builders.AcceleoBuilder.build(AcceleoBuilder.java:180)
at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:726)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:199)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:239)
at org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:292)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:295)
at org.eclipse.core.internal.events.BuildManager.basicBuildLoop(BuildManager.java:351)
at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:374)
at org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBuildJob.java:143)
at org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJob.java:241)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:53)
Caused by: org.eclipse.core.internal.resources.ResourceException: Resource '/org.eclipse.robotml.generators.acceleo.athena/bin/org/eclipse/robotml/generators/acceleo/athena/mmqueries/MMSpecificQueries.emtl' does not exist.
at org.eclipse.core.internal.resources.Resource.checkExists(Resource.java:341)
at org.eclipse.core.internal.resources.Resource.checkAccessible(Resource.java:215)
at org.eclipse.core.internal.resources.File.getContents(File.java:287)
at org.eclipse.core.internal.resources.File.getContents(File.java:278)
at org.eclipse.emf.ecore.resource.impl.PlatformResourceURIHandlerImpl$WorkbenchHelper.createPlatformResourceInputStream(PlatformResourceURIHandlerImpl.java:207)
at org.eclipse.emf.ecore.resource.impl.PlatformResourceURIHandlerImpl.createInputStream(PlatformResourceURIHandlerImpl.java:525)
at org.eclipse.emf.ecore.resource.impl.ExtensibleURIConverterImpl.createInputStream(ExtensibleURIConverterImpl.java:360)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1269)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoad(ResourceSetImpl.java:259)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:274)
... 32 more
FUDForum. Page generated in 0.04690 seconds
