Home » Eclipse Projects » Target Management » SSH Public Key Access Connection Failure(Infinitely prompting for private key passphrase)
SSH Public Key Access Connection Failure [message #816427] Thu, 08 March 2012 16:14 Go to next message
I'm unsuccessfully attempting to connect with SSH public key as the only authentication method, using a private DSA key towards an embedded Linux target. This combination works fine outside of Eclipse. However, when I attempt to connect w/ RSE, I'm continuously prompted for the private key passphrase, which I've confirmed is correct. The log indicates nothing more than the Informational message about beginning the connection.
Any ideas about how to proceed? I saw bug 357354 which appears to describe a somewhat similar problem, and hasn't been resolved.
Version: Indigo Service Release 1
Build id: 20110916-0149
RSE Version: 3.3.1.R33
Host: Mac OSX 10.7
Tim
Re: SSH Public Key Access Connection Failure [message #1233939 is a reply to message #816427] Mon, 20 January 2014 17:05 Go to previous message
I have the exact same issue.
Did someone found a solution?
Jérôme.
Previous Topic:Change mouse pointer when attempting to drop into a read-only folder
Next Topic:Viewing Local Filesystem in RSE
Current Time: Sat Jul 19 06:27:46 EDT 2025
Powered by FUDForum. Page generated in 0.03810 seconds
