Home » Archived » Buckminster » Executing plugIn unit tests with buckminster headless
Executing plugIn unit tests with buckminster headless [message #1233845] Mon, 20 January 2014 11:29 Go to next message
I try to execute some plugIn tests with buckminster headlessly. However, when buckminster trys to execute the launch configuration with the junit command, the following error occurs:
[INFO] Launch configuration type id "org.eclipse.pde.ui.JunitLaunchConfig" does not exist.
[INFO] Possible causes:
[INFO]  Missing specification of a launch type (missing plug-in)
[INFO]  Incorrect launch configuration XML
My launch configuration looks like this:
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<launchConfiguration type="org.eclipse.pde.ui.JunitLaunchConfig">
<booleanAttribute key="append.args" value="true"/>
<booleanAttribute key="askclear" value="false"/>
<booleanAttribute key="automaticAdd" value="true"/>
<booleanAttribute key="automaticValidate" value="false"/>
<stringAttribute key="bootstrap" value=""/>
<stringAttribute key="checked" value="[NONE]"/>
<booleanAttribute key="clearConfig" value="true"/>
<booleanAttribute key="clearws" value="true"/>
<booleanAttribute key="clearwslog" value="false"/>
<stringAttribute key="configLocation" value="${workspace_loc}/.metadata/.plugins/org.eclipse.pde.core/pde-junit"/>
<booleanAttribute key="default" value="true"/>
<booleanAttribute key="includeOptional" value="true"/>
<stringAttribute key="location" value="${workspace_loc}/../junit-workspace"/>
<listAttribute key="org.eclipse.debug.core.MAPPED_RESOURCE_PATHS">
<listEntry value="/plugin.test"/>
</listAttribute>
<listAttribute key="org.eclipse.debug.core.MAPPED_RESOURCE_TYPES">
<listEntry value="4"/>
</listAttribute>
<stringAttribute key="org.eclipse.jdt.junit.CONTAINER" value="=plugin.test"/>
<booleanAttribute key="org.eclipse.jdt.junit.KEEPRUNNING_ATTR" value="false"/>
<stringAttribute key="org.eclipse.jdt.junit.TESTNAME" value=""/>
<stringAttribute key="org.eclipse.jdt.junit.TEST_KIND" value="org.eclipse.jdt.junit.loader.junit4"/>
<stringAttribute key="org.eclipse.jdt.launching.JRE_CONTAINER" value="org.eclipse.jdt.launching.JRE_CONTAINER/org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType/JavaSE-1.6"/>
<stringAttribute key="org.eclipse.jdt.launching.MAIN_TYPE" value=""/>
<stringAttribute key="org.eclipse.jdt.launching.PROGRAM_ARGUMENTS" value="-os ${target.os} -ws ${target.ws} -arch ${target.arch} -nl ${target.nl} -consoleLog"/>
<stringAttribute key="org.eclipse.jdt.launching.PROJECT_ATTR" value="plugin.test"/>
<stringAttribute key="org.eclipse.jdt.launching.SOURCE_PATH_PROVIDER" value="org.eclipse.pde.ui.workbenchClasspathProvider"/>
<stringAttribute key="pde.version" value="3.3"/>
<stringAttribute key="product" value="org.eclipse.sdk.ide"/>
<booleanAttribute key="run_in_ui_thread" value="true"/>
<booleanAttribute key="show_selected_only" value="false"/>
<booleanAttribute key="tracing" value="false"/>
<booleanAttribute key="useCustomFeatures" value="false"/>
<booleanAttribute key="useDefaultConfig" value="true"/>
<booleanAttribute key="useDefaultConfigArea" value="false"/>
<booleanAttribute key="useProduct" value="true"/>
</launchConfiguration>
Any help is appreciated! Thanks,
Felix
Re: Executing plugIn unit tests with buckminster headless [message #1233849 is a reply to message #1233845] Mon, 20 January 2014 11:40 Go to previous messageGo to next message
On 20/01/2014 17:29, Felix Feisst wrote:
> Hello,
Hi Felix
you must install org.eclipse.buckminster.pde.headless.feature in your
buckminster headless installation.
hope this helps
Lorenzo
HOME: http://www.lorenzobettini.it
Xtext Book:
http://www.packtpub.com/implementing-domain-specific-languages-with-xtext-and-xtend/book
Re: Executing plugIn unit tests with buckminster headless [message #1233925 is a reply to message #1233845] Mon, 20 January 2014 16:16 Go to previous messageGo to next message
Hi Felix,
What version are you using? IIRC, the ui dependency in the launch config has been removed for quite a while. It was
removed because you really want to be able to launch headlessly.
- thomas
On 2014-01-20 17:29, Felix Feisst wrote:
> Hello,
> </listAttribute>
> </listAttribute>
> Felix
Re: Executing plugIn unit tests with buckminster headless [message #1236841 is a reply to message #1233925] Tue, 28 January 2014 02:41 Go to previous message
Thank you so far, installing org.eclipse.buckminster.pde.headless.feature into my buckminster installation solved the problem so far.
However, I do get a follow up error now. When buckminster trys to run the launch configuration an error occurrs. In the corresponding log I found:
java.lang.RuntimeException: Application "org.eclipse.pde.junit.runtime.nonuithreadtestapplication" could not be found in the registry.
I have change the attribute "run_in_ui_thread" in the launch configuratin to false, having this attribute on true gives a similar error.
Previous Topic:Headless build for Java-8 applications
Next Topic:Cross-platform builds with buckminster 4.3
Current Time: Sat Jul 19 16:49:27 EDT 2025
Powered by FUDForum. Page generated in 0.28408 seconds
