Home » Eclipse Projects » Remote Application Platform (RAP) » Non-selectable nodes in tree
Non-selectable nodes in tree [message #123264] Thu, 26 February 2009 12:34 Go to next message
My application uses a tree to represent a workflow on the right half, that
when users click on a node in the tree, the left half changes to reflect
the selected node.
However some of the nodes aren't implemented yet, so they are disabled and
greyed-out for now. To prevent the user from selecting these nodes, I
added a selection listener to the tree. In widgetSelected, I check to see
if the selection is to a valid node. If not, I call tree.setSelection()
back to the previously selected node. Since this happens quickly in SWT,
so the illusion is that the user can't click on the disabled nodes.
Unfortunately in RWT standalone, the drawing is a bit slower so you can
easily tell the disabled node was clicked on briefly before re-selecting
the previous node, but I can live with it. But what's worst, is that if I
now select a third node, both the first and third nodes will be
highlighted!
If I then click back to first node, then click on another node the tree is
restored to normal where only 1 node is highlighted, so this seems like a
redrawing/refreshing thing. The Tree is single select of course. I tried
redrawing to no avail.
Question is, is this a bug? Also, is this the correct/standard way to
achieve my desired behavior, or is there a better/alternative way?
Keep up the good work guys!
Howard
Re: Non-selectable nodes in tree [message #123369 is a reply to message #123264] Fri, 27 February 2009 10:17 Go to previous messageGo to next message
Howard,
from reading your post, this appears to be a bug. Open a bugzilla if
you can provide self-contained code to reproduce the problem.
Rüdiger
> that when users click on a node in the tree, the left half changes to
> reflect the selected node.
> and greyed-out for now. To prevent the user from selecting these nodes,
> I added a selection listener to the tree. In widgetSelected, I check to
> see if the selection is to a valid node. If not, I call
> tree.setSelection() back to the previously selected node. Since this
> happens quickly in SWT, so the illusion is that the user can't click on
> the disabled nodes.
> I now select a third node, both the first and third nodes will be
> highlighted!
> is restored to normal where only 1 node is highlighted, so this seems
> like a redrawing/refreshing thing. The Tree is single select of course.
> I tried redrawing to no avail.
> Howard
Re: Non-selectable nodes in tree [message #123483 is a reply to message #123369] Mon, 02 March 2009 09:15 Go to previous message
see also 231523: [Tree] Selection Problem
https://bugs.eclipse.org/bugs/show_bug.cgi?id=231523
Cheers
Benny
Rüdiger Herrmann wrote:
> Howard,
> from reading your post, this appears to be a bug. Open a bugzilla if you
> Cheers,
> Rüdiger
>> nodes, I added a selection listener to the tree. In widgetSelected, I
>> check to see if the selection is to a valid node. If not, I call
>> can easily tell the disabled node was clicked on briefly before
>> re-selecting the previous node, but I can live with it. But what's
>> worst, is that if I now select a third node, both the first and third
>> nodes will be highlighted!
>> tree is restored to normal where only 1 node is highlighted, so this
>> seems like a redrawing/refreshing thing. The Tree is single select of
>> course. I tried redrawing to no avail.
>> Howard
Benjamin Muskalla | EclipseSource Karlsruhe
http://www.eclipsesource.com | http://twitter.com/eclipsesource
Previous Topic:Request to add a WebSite in RAP Demo List Page
Next Topic:conceptual question: "file download link"?
Current Time: Sun Jul 20 17:58:36 EDT 2025
Powered by FUDForum. Page generated in 0.04712 seconds
