Error: Cannot run program "echo" [message #1232465] |
Thu, 16 January 2014 20:43  |
Having used eclipse-based Codewarrior for years, I'm now trying to use eclipse CDT (Kepler) as an IDE for programming a BeagleBone Black. With much reading and help from folks on the Internet, I've installed a toolchain into eclipse and gotten to the point where I can compile a C program on a Windows 7 PC and debug "Hello World" on the BBB.
However, every time I compile the program, it generates
Error: Program "echo" not found in PATH
Location: Project Properties, C++ Preprocessor Include.../Providers, [CDT GCC Built-in Compiler Settings Cross ARM] options
Type: C/C++ Scanner Discovery Problem
I've looked in the log, and here's a sample of what goes with that error:
!ENTRY org.eclipse.cdt.core 4 0 2014-01-16 01:39:55.104
!MESSAGE Error: Cannot run program "echo": Launching failed
!STACK 0
java.io.IOException: Cannot run program "echo": Launching failed
at org.eclipse.cdt.utils.spawner.Spawner.exec(Spawner.java:347)
at org.eclipse.cdt.utils.spawner.Spawner.<init>(Spawner.java:89)
at org.eclipse.cdt.utils.spawner.ProcessFactory.exec(ProcessFactory.java:89)
at org.eclipse.cdt.core.CommandLauncher.execute(CommandLauncher.java:194)
at org.eclipse.cdt.internal.core.BuildRunnerHelper.build(BuildRunnerHelper.java:238)
at org.eclipse.cdt.managedbuilder.language.settings.providers.AbstractBuiltinSpecsDetector.runProgramForLanguage(AbstractBuiltinSpecsDetector.java:704)
at org.eclipse.cdt.managedbuilder.language.settings.providers.AbstractBuiltinSpecsDetector.runForLanguage(AbstractBuiltinSpecsDetector.java:634)
at org.eclipse.cdt.managedbuilder.language.settings.providers.AbstractBuiltinSpecsDetector.runForEachLanguage(AbstractBuiltinSpecsDetector.java:507)
at org.eclipse.cdt.managedbuilder.language.settings.providers.AbstractBuiltinSpecsDetector$1.runInWorkspace(AbstractBuiltinSpecsDetector.java:441)
at org.eclipse.core.internal.resources.InternalWorkspaceJob.run(InternalWorkspaceJob.java:38)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:53)
I've put echo.exe into several directories on the path (e.g., the directory that has the gcc compiler), but that hasn't done any good.
I've run eclipse -clean and done a clean compile with no progress.
Please help!
Re: Error: Cannot run program "echo" [message #1232710 is a reply to message #1232465] |
Fri, 17 January 2014 09:40   |
Have you considered this sticky post at the forum's top?
http://www.eclipse.org/forums/index.php/t/161206/
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> Please help!
Re: Error: Cannot run program &quot;echo&quot; [message #1232838 is a reply to message #1232763] |
Fri, 17 January 2014 16:53  |
> Yes, I did think about it. It could have gone either way, but I decided
> that the question was really a newbie question, since it was the first
> program -- and a canned one at that -- that I'd ever run on a
> self-installed eclipse. I figured that if it doesn't get a response in
> this forum after a couple of days, I can try again in the CDT forum,
> with apologies for cross-posting.
> - R
True, it's a bit of a judgment call. From my point of view, it appears
strongly to be something that the guys in that forum would know about.
FUDForum. Page generated in 0.08666 seconds
