Home » Archived » EPF » [SOLVED] RichText on Windows7 64bits issue(No richtext available so that it is not possible to enter any text)
[SOLVED] RichText on Windows7 64bits issue [message #1232298] Thu, 16 January 2014 11:24 Go to next message
I'm a new user of EPF and I've starting using it to build our internal processes.
My main drawback until now is that I still not managed to install the richtext pluggin.
What is the issue?
When on a page where I have the "main description" inputbox, it is not possible to enter any text.
What I've done?
I've downloaded the package "epf-richtext-1.5.1.5-win32" and copied the existing files and folders into my EPF folder.
What is my environment?
Windows 7 64bits
EPF 1.5.1.5
Error seen in EPF log:
!ENTRY org.eclipse.epf.richtext 4 0 2014-01-16 17:07:51.836
!MESSAGE
!STACK 0
at org.eclipse.epf.richtext.actions.PasteAction.copyLinkResources(PasteAction.java:147)
at org.eclipse.epf.richtext.actions.PasteAction.execute(PasteAction.java:100)
at org.eclipse.epf.richtext.RichText$5.widgetSelected(RichText.java:1207)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:234)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4066)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3657)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2640)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2438)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:664)
at org.eclipse.epf.rcp.ui.MainApplication.createWorkbenchAdvisor(MainApplication.java:116)
at org.eclipse.epf.rcp.ui.MainApplication.start(MainApplication.java:82)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:620)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:575)
at org.eclipse.equinox.launcher.Main.run(Main.java:1408)
So after hours of tries and searches on Internet, I don't really know what to do.
This tool is the one I would like to use, so that I feel quite sad to be blocked only on this point.
Many thanks to any one that could help me Wink
Greetings
Nils
[Updated on: Fri, 17 January 2014 09:26] by Moderator
Re: RichText on Windows7 64bits issue [message #1232561 is a reply to message #1232298] Fri, 17 January 2014 02:56 Go to previous messageGo to next message
One complement I've discovered in the log file at the very begining of the session start part, I can see this:
!SESSION 2014-01-17 08:47:07.740 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_39
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=fr_FR
Command-line arguments:  -os win32 -ws win32 -arch x86 -data @user.home/EPF/workspace.151
!ENTRY org.eclipse.epf.rcp.ui 1 0 2014-01-17 08:47:23.819
!MESSAGE INFO: Application start directory =C:\nils.laumaille\utils\EPF-composer-1.5.1.5-win32
!ENTRY org.eclipse.ui.workbench 2 0 2014-01-17 08:47:28.036
!MESSAGE A handler conflict occurred.  This may disable some commands.
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2014-01-17 08:47:28.036
!MESSAGE Conflict for 'AUTOGEN:::org.eclipse.ui.cheatsheets.actionSet/org.eclipse.ui.cheatsheets.actions.CheatSheetHelpMenuAction':
HandlerActivation(commandId=AUTOGEN:::org.eclipse.ui.cheatsheets.actionSet/org.eclipse.ui.cheatsheets.actions.CheatSheetHelpMenuAction,
	handler=ActionDelegateHandlerProxy(null,org.eclipse.ui.internal.cheatsheets.actions.CheatSheetHelpMenuAction),
	expression=AndExpression(ActionSetExpression(org.eclipse.ui.cheatsheets.actionSet,org.eclipse.ui.internal.WorkbenchWindow@3cbb4b),WorkbenchWindowExpression(org.eclipse.ui.internal.WorkbenchWindow@3cbb4b)),sourcePriority=16640)
	handler=ActionDelegateHandlerProxy(null,org.eclipse.ui.cheatsheets.CheatSheetExtensionFactory:helpMenuAction),
Perhaps this exception is the root cause.
Any ideas?
Re: RichText on Windows7 64bits issue [message #1232699 is a reply to message #1232561] Fri, 17 January 2014 09:25 Go to previous message
I finally solved my issue.
The cause was IE9 ... indeed I don't know how I found that but it seems that the RichText uses IE but on my computer the 32bits version of IE9 was not working.
So I reinstalled it and registered the ddl back ... and small miracle in my day, EPF richtext now works.
I hope this feedback could help some users in the same situation.
Greetings
Previous Topic:Plugins for EPF Composer
Next Topic:How do I install EPF in mac os X
Current Time: Sat Jul 19 11:31:15 EDT 2025
Powered by FUDForum. Page generated in 0.24318 seconds
