Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » CDO as ECP Model Repository(cannot commit or create resources)
CDO as ECP Model Repository [message #1228855] Wed, 08 January 2014 03:10 Go to next message
Hi there,
I try to run CDO as a Model Repository in ECP. First, I was not able to setup a resource therefor I added a resource with CDOExplorer, checked it in and proceeded on ECP site. Now I can check out my CDO resource and add EMF entities to it. When I try to commit my changes by right clicking the resource node, I receive the following error:
!ENTRY org.eclipse.ui 4 0 2014-01-08 09:02:12.038
!MESSAGE Unhandled event loop exception
!STACK 0
	at org.eclipse.emf.emfstore.internal.client.model.provider.ProjectSpaceItemProvider.setTarget(ProjectSpaceItemProvider.java:483)
	at org.eclipse.emf.common.notify.impl.BasicNotifierImpl$EAdapterList.didAdd(BasicNotifierImpl.java:121)
	at org.eclipse.emf.common.util.BasicEList.addUnique(BasicEList.java:419)
	at org.eclipse.emf.common.util.AbstractEList.add(AbstractEList.java:301)
	at org.eclipse.emf.common.notify.impl.BasicNotifierImpl$EAdapterList.add(BasicNotifierImpl.java:193)
	at org.eclipse.emf.common.notify.impl.AdapterFactoryImpl.associate(AdapterFactoryImpl.java:150)
	at org.eclipse.emf.common.notify.impl.AdapterFactoryImpl.adaptNew(AdapterFactoryImpl.java:102)
	at org.eclipse.emf.common.notify.impl.AdapterFactoryImpl.adapt(AdapterFactoryImpl.java:87)
	at org.eclipse.emf.emfstore.internal.client.model.provider.ModelItemProviderAdapterFactory.adapt(ModelItemProviderAdapterFactory.java:251)
	at org.eclipse.emf.edit.provider.ComposedAdapterFactory.adapt(ComposedAdapterFactory.java:294)
	at org.eclipse.emf.edit.provider.ComposedAdapterFactory.adapt(ComposedAdapterFactory.java:271)
	at org.eclipse.emf.edit.provider.ComposedAdapterFactory.adapt(ComposedAdapterFactory.java:258)
	at org.eclipse.emf.edit.ui.provider.AdapterFactoryLabelProvider.getImage(AdapterFactoryLabelProvider.java:326)
	at org.eclipse.emf.ecp.spi.ui.DefaultUIProvider.populateSubMenu(DefaultUIProvider.java:410)
	at org.eclipse.emf.ecp.spi.ui.DefaultUIProvider.populateSubMenu(DefaultUIProvider.java:364)
	at org.eclipse.emf.ecp.spi.ui.DefaultUIProvider.populateNewRoot(DefaultUIProvider.java:347)
	at org.eclipse.emf.ecp.spi.ui.DefaultUIProvider.fillContextMenuForProject(DefaultUIProvider.java:220)
	at org.eclipse.emf.ecp.spi.ui.DefaultUIProvider.fillContextMenu(DefaultUIProvider.java:212)
	at org.eclipse.emf.ecp.internal.ui.UIProviderRegistryImpl$UIProviderDescriptor.fillContextMenu(UIProviderRegistryImpl.java:172)
	at org.eclipse.emf.ecp.ui.views.ModelExplorerView.fillContextMenu(ModelExplorerView.java:191)
	at org.eclipse.emf.ecp.ui.views.TreeView$2.menuAboutToShow(TreeView.java:230)
	at org.eclipse.jface.action.MenuManager.fireAboutToShow(MenuManager.java:343)
	at org.eclipse.jface.action.MenuManager.handleAboutToShow(MenuManager.java:475)
	at org.eclipse.jface.action.MenuManager.access$1(MenuManager.java:470)
	at org.eclipse.jface.action.MenuManager$2.menuShown(MenuManager.java:500)
	at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:255)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1392)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1416)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1397)
	at org.eclipse.swt.widgets.Menu._setVisible(Menu.java:198)
	at org.eclipse.swt.widgets.Display.runPopups(Display.java:3784)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3353)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1113)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:997)
	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:138)
	at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:610)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:567)
	at org.eclipse.emf.ecp.application3x.Application.start(Application.java:30)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
	at java.lang.reflect.Method.invoke(Method.java:606)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1426)
Any ideas? Is the experimental ECP CDO Model Repository still in progress?
Re: CDO as ECP Model Repository [message #1228902 is a reply to message #1228855] Wed, 08 January 2014 05:06 Go to previous messageGo to next message
Am 08.01.2014 09:11, schrieb Phil Wim:
> Hi there,
> !STACK 0
> at
I wonder why EMFStore lurks through here. That seems wrong to me. Jonas, do you have an idea?
Cheers
/Eike
http://www.esc-net.de
> at
> at
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
> at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:150)
> at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
> at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
> at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
Re: CDO as ECP Model Repository [message #1228914 is a reply to message #1228855] Wed, 08 January 2014 05:43 Go to previous messageGo to next message
my first thought is the following:
When you right click on any object in a project, the context menu allows
to create possible children of this object. In case of a resource, this
is actually any EObject available. This includes the EMFStore class
"ProjectSpace", but the connection to EMFStore is actually arbitrary.
Probably EObjects with a missing edit bundle would fail, too.
We have changed and improved the way the children descriptors are
calculated over the last 3 month. Could you kindly tell me exactly which
version you are using?
As a quick fix, could you try to remove the EMFStore model from your run
configuration?
org.eclipse.emf.emfstore.client.model
In general, I am not aware of a "heavy user" of the CDO provider, that`s
why it is still marked experimental. I believe there might be a few
other glitches like the one you just discovered. However, as Eike
heavily participated in the initial design of the core framework, I
think, that there are only minor things to fix, mostly in the UI, until
we can mark the provider stable, too. An interesting new feature would
be a CDOProvider that uses an online connection instead of a local
checkout. As we are very interested in making all this happen, we are
happy for any feedback!
Best Regards
Jonas
> Hi there,
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: CDO as ECP Model Repository [message #1229812 is a reply to message #1228914] Fri, 10 January 2014 04:21 Go to previous messageGo to next message
thanks for the reply.
I tried it with Version 1.1.1 just by creating a launch configuration and selecting .ecp.application.e3.application as application. Also I checked out the sources. Same Error.
I can't find the bundle you mentioned. I see following bundles in my launch conf:
org.eclipse.emf.emfstore.client.model.edit
I installed EMFStore out of the repository (Version 1.1.0)
Finally I used a new emf modeling dist and installed ecp from marketplace. Same problem. In order to archive your quickfix here I check via osgi-console. Your mentioned bundle is not there:
197 ACTIVE org.eclipse.emf.ecp.emfstore.core_1.1.1.20131114-1613
198 ACTIVE org.eclipse.emf.ecp.emfstore.ui_1.1.1.20131114-1613
199 STARTING org.eclipse.emf.ecp.emfstore.ui.search_1.1.1.20131114-1613
257 ACTIVE org.eclipse.emf.emfstore.client_1.0.3.v20131115-1332
258 STARTING org.eclipse.emf.emfstore.client.model.edit_1.0.3.v20131115-1332
259 ACTIVE org.eclipse.emf.emfstore.client.ui_1.0.3.v20131115-1332
260 ACTIVE org.eclipse.emf.emfstore.common_1.0.3.v20131115-1332
261 ACTIVE org.eclipse.emf.emfstore.common.model_1.0.3.v20131115-1332
262 STARTING org.eclipse.emf.emfstore.common.model.edit_1.0.3.v20131115-1332
263 ACTIVE org.eclipse.emf.emfstore.migration_1.0.3.v20131115-1332
264 ACTIVE org.eclipse.emf.emfstore.server_1.0.3.v20131115-1332
265 ACTIVE org.eclipse.emf.emfstore.server.model_1.0.3.v20131115-1332
266 STARTING org.eclipse.emf.emfstore.server.model.edit_1.0.3.v20131115-1332
Can you reproduce it?
Thanks in advanced!
Philippe
[Updated on: Fri, 10 January 2014 04:22] by Moderator
Re: CDO as ECP Model Repository [message #1229845 is a reply to message #1229812] Fri, 10 January 2014 05:47 Go to previous message
I have created a Bug Report to track this, we will debug this asap:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=425273
In the meantime, could you try to remove all EMFStore bundle from the
run config?
Jonas
Am 10.01.2014 10:21, schrieb Phil Wim:
> launch conf:
> When I'm using the osgi console I have following emfstore related bundles:
> 199 STARTING
> 258 STARTING
> 261 ACTIVE
> 262 STARTING
> 265 ACTIVE
> 266 STARTING
> Thanks in advanced!
> Philippe
Previous Topic:[EMFStore] Running EMFStore Client in a web app
Next Topic:CDO OCLQuery
Current Time: Sat Jul 19 16:22:44 EDT 2025
Powered by FUDForum. Page generated in 0.05704 seconds
