Home » Eclipse Projects » Nebula » change the background color of column headers in the Grid widget
change the background color of column headers in the Grid widget [message #1027449] Tue, 26 March 2013 21:17 Go to next message
Hi, all, I'm using the Nebula Grid Widget and I want to change the background color of the column headers, how can I achieve this?
Thanks in advance!
Re: change the background color of column headers in the Grid widget [message #1057845 is a reply to message #1027449] Thu, 09 May 2013 05:44 Go to previous messageGo to next message
Is there a solution for changing the background color of the headers?
I am also looking for similar behavior
Re: change the background color of column headers in the Grid widget [message #1059028 is a reply to message #1057845] Thu, 16 May 2013 05:54 Go to previous messageGo to next message
No, I have not found it.
Re: change the background color of column headers in the Grid widget [message #1060050 is a reply to message #1059028] Wed, 22 May 2013 13:03 Go to previous messageGo to next message
Write your own renderer - look at DefaultColumnHeaderRenderer
Re: change the background color of column headers in the Grid widget [message #1227792 is a reply to message #1060050] Sun, 05 January 2014 10:55 Go to previous message
Below is an example. Does anybody know, how I can set the color of the header region, right to the actual headers?
	 * Renders the table headers
	class HeaderRenderer extends GridHeaderRenderer {
		HeaderRenderer(){
		public boolean notify(int event, Point point, Object value) {
			// TODO Auto-generated method stub
			return false;
		public void paint(GC gc, Object value) {
			Color backgroundColor = getDisplay().getSystemColor(SWT.COLOR_WIDGET_BACKGROUND);
			Color foregroundColor = new Color(getDisplay(), 255,255,255);
			Color selectionColor = new Color(getDisplay(), 153,204,255);
			//get column
			GridColumn column = (GridColumn)value;
			//get selection state
			boolean selected = this.isSelected();
			//get coordinates
			int x = getBounds().x;
			int y = getBounds().y;
			int width = getBounds().width;
            int height = getBounds().height;
            //set background color and draw rectangle
			Color oldBackground = gc.getBackground();
			Color oldForeground = gc.getForeground();
			if (selected) {
				gc.setBackground(selectionColor);
				gc.setForeground(foregroundColor);
				gc.fillGradientRectangle(x, y, width, height, true);
				gc.setForeground(selectionColor);
				gc.drawRectangle(x,y,width-1,height-1);
			} else {
				gc.setBackground(backgroundColor);
				//gc.setForeground(oldForeground);
				//gc.drawRectangle(x,y,width,height);
			gc.setBackground(oldBackground);
			//draw text
			String text = column.getText();
			int textOffset = 3;
	        gc.drawString(text, x+textOffset, y+textOffset, true);
		public Point computeSize(GC gc, int wHint, int hHint, Object value) {
			//define text offset
			int textOffset = 3;
			//get text size
			Point p = gc.stringExtent(text);
			int width = p.x + 3*textOffset;
			int height = p.y;
			return new Point(width, height);
Previous Topic:IntensityGraph, when the axis are updated?
Next Topic:[SOLVED] TableComboViewer Scrollbars?
Current Time: Sat Jul 19 21:38:24 EDT 2025
Powered by FUDForum. Page generated in 0.04460 seconds
