Home » Modeling » TMF (Xtext) » Xcore - Using annotations in IDE
Xcore - Using annotations in IDE [message #1221899] Wed, 18 December 2013 11:44 Go to next message
i got the following issue:
If i am using Xcore to define a model and i would like to use the annotations defined in org.eclipse.emf.ecore.xcore.lib, i have to import the project into workspace. Otherwise i am getting following error message in the editor:
"Couldn't resolve reference to XAnnotationDirective 'GenModel'."
Is there a way to avoid importing the lib bundle into workspace?
Thanks, Florian
Re: Xcore - Using annotations in IDE [message #1221938 is a reply to message #1221899] Wed, 18 December 2013 13:45 Go to previous messageGo to next message
simply use a plugin project with a dependency doesnt work?
it works for the one created with the xcore wizard
@GenModel(copyrightText="Test")
package test
annotation "http://www.eclipse.org/emf/2002/GenModel" as genmodel
class Entity {
Re: Xcore - Using annotations in IDE [message #1221940 is a reply to message #1221938] Wed, 18 December 2013 13:47 Go to previous messageGo to next message
alternatively the following works as well
package test
import GenModel
class Entity {
@GenModel(copyrightText="Test2")
package test
class Entity {
Re: Xcore - Using annotations in IDE [message #1221941 is a reply to message #1221940] Wed, 18 December 2013 13:49 Go to previous messageGo to next message
Thanks, "import GenModel". That was the clou...
Thanks Florian
Re: Xcore - Using annotations in IDE [message #1221943 is a reply to message #1221941] Wed, 18 December 2013 13:52 Go to previous messageGo to next message
P.S:
seems you need at least a import yes.
the other one did not survive a clean build
Re: Xcore - Using annotations in IDE [message #1222153 is a reply to message #1221943] Thu, 19 December 2013 14:43 Go to previous messageGo to next message
It should be sufficient for the project to have a dependency on
org.eclipse.emf.ecore.xcore.lib and for that bundle to be in your target
platform.
On 18/12/2013 7:52 PM, Christian Dietrich wrote:
> P.S:
Re: Xcore - Using annotations in IDE [message #1222378 is a reply to message #1222153] Fri, 20 December 2013 04:17 Go to previous messageGo to next message
Hi Ed,
a simple dependency does not work. Without an import statement i have to import the xcore.lib bundle into the workspace.
Best, Florian
Re: Xcore - Using annotations in IDE [message #1222424 is a reply to message #1222378] Fri, 20 December 2013 06:25 Go to previous messageGo to next message
Florian,
I just tested this
@GenModel(prefix="Tester")
@Ecore(nsURI="http://www.example.org/test")
package org.example.test
class Test
and it works fine without imports and without xcore.lib in the workspace
(including the Ecore annotation). In general, I expect the things
declared in XcoreLang.xcore to be visible everywhere without imports.
package xcore.lang
annotation "http://www.eclipse.org/emf/2002/Ecore" as Ecore
annotation "http:///org/eclipse/emf/ecore/util/ExtendedMetaData" as
ExtendedMetaData
annotation "http://www.eclipse.org/emf/2002/GenModel" as GenModel
Via the properties view you can set GenModel properties and they're
converted to annotations with this basic assumption.
Which version of Xcore are you using?
On 20/12/2013 10:17 AM, Florian Pirchner wrote:
> Hi Ed,
> Best, Florian
Re: Xcore - Using annotations in IDE [message #1227385 is a reply to message #1222424] Sat, 04 January 2014 05:33 Go to previous message
Hi Ed,
interesting. I will do another try in the evening.
I am using the version shipped with Xtext 2.5.1.
Best Florian
Previous Topic:Xtext OutputConfigurationProvider
Next Topic:Content-assist grammar has warnings while the main one has no
Current Time: Sun Jul 20 13:13:42 EDT 2025
Powered by FUDForum. Page generated in 0.46596 seconds
