Home » Modeling » EMF » [EMF] [CDO] ConcurrentModificationException when setting setTrackingModification(true)(Problem with CDOResource)
[EMF] [CDO] ConcurrentModificationException when setting setTrackingModification(true) [message #1223430] Mon, 23 December 2013 06:04 Go to next message
When trying to use graphiti with CDO (4.2.0) i've run into a following problem: calling setTrackingModification(true) on diagram resource immediately results in java.util.ConcurrentModificationException.
Here is the stack trace:
 at java.util.HashMap$HashIterator.nextEntry(HashMap.java:793)
 at java.util.HashMap$EntryIterator.next(HashMap.java:834)
 at java.util.HashMap$EntryIterator.next(HashMap.java:832)
 at org.eclipse.net4j.util.ref.ReferenceValueMap2$EntrySetIterator.hasNext(ReferenceValueMap2.java:408)
 at java.util.AbstractMap$2$1.hasNext(AbstractMap.java:356)
 at java.util.Collections$UnmodifiableCollection$1.hasNext(Collections.java:1007)
 at org.eclipse.emf.cdo.util.CDOLazyContentAdapter.addCleanObjectHandler(CDOLazyContentAdapter.java:123)
 at org.eclipse.emf.cdo.util.CDOLazyContentAdapter.setTarget(CDOLazyContentAdapter.java:61)
 at org.eclipse.emf.ecore.util.EContentAdapter.setTarget(EContentAdapter.java:182)
 at org.eclipse.emf.ecore.impl.MinimalEObjectImpl$1ArrayDelegatingAdapterList.didAdd(MinimalEObjectImpl.java:489)
 at org.eclipse.emf.ecore.impl.MinimalEObjectImpl$1ArrayDelegatingAdapterList.didAdd(MinimalEObjectImpl.java:1)
 at org.eclipse.emf.common.util.ArrayDelegatingEList.addUnique(ArrayDelegatingEList.java:389)
 at org.eclipse.emf.common.util.AbstractEList.add(AbstractEList.java:301)
 at org.eclipse.emf.cdo.eresource.impl.CDOResourceImpl.setTrackingModification(CDOResourceImpl.java:499)
Is there anything im doing wrong?
Re: [EMF] [CDO] ConcurrentModificationException when setting setTrackingModification(true) [message #1226979 is a reply to message #1223430] Fri, 03 January 2014 02:59 Go to previous messageGo to next message
Hi Leonid,
I also experience this problem recently and I was about to commit a simple fix for it. But then I looked at
CDOLazyContentAdapter a little bit longer and thought it should be reimplemented from scratch without extending
EContentAdapter. If you want me to fix the ConcurrentModificationException separately, please submit a bugzilla and I'll
look at it.
Cheers
/Eike
http://www.esc-net.de
Am 23.12.2013 12:04, schrieb Leonid Ripeynih:
Re: [EMF] [CDO] ConcurrentModificationException when setting setTrackingModification(true) [message #1227050 is a reply to message #1226979] Fri, 03 January 2014 06:43 Go to previous messageGo to next message
On 03-01-14 08:59, Eike Stepper wrote:
> Hi Leonid,
> simple fix for it. But then I looked at CDOLazyContentAdapter a little
> extending EContentAdapter. If you want me to fix the
Yes this is a known issue with the CDOLazyContentAdapter.
I reported this bug here:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=399723
I spend quiet some time using the CDOLazyContentAdapter and trying
to change it so it can deal with anything else than a Resource as a
root. My conclusion, it's very broken..and indeed needs to be redone.
The root cause of the concurrentmod, is that walking an object (For
example to check containment, will trigger objects to be loaded, which
will update the ObjectHandler and fire concurrentmod exception.
> I'll look at it.
> Cheers
> /Eike
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
Re: [EMF] [CDO] ConcurrentModificationException when setting setTrackingModification(true) [message #1227372 is a reply to message #1227050] Sat, 04 January 2014 04:32 Go to previous messageGo to next message
Am 03.01.2014 12:43, schrieb Christophe Bouhier:
>> Hi Leonid,
That bug is more like an umbrella bug. I've now fixed the ConcurrentModificationException via:
424889: ConcurrentModificationException in CDOLazyContentAdapter
https://bugs.eclipse.org/bugs/show_bug.cgi?id=424889
Cheers
/Eike
> to change it so it can deal with anything else than a Resource as a root. My conclusion, it's very broken..and indeed
> needs to be redone.
> The root cause of the concurrentmod, is that walking an object (For example to check containment, will trigger objects
> to be loaded, which will update the ObjectHandler and fire concurrentmod exception.
>> I'll look at it.
>> Cheers
>> /Eike
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
Re: [EMF] [CDO] ConcurrentModificationException when setting setTrackingModification(true) [message #1230955 is a reply to message #1223430] Mon, 13 January 2014 07:57 Go to previous messageGo to next message
Eike, after applying the fix, error has changed to:
java.lang.IllegalStateException: Different object was registered for OID3693
 at org.eclipse.emf.internal.cdo.view.AbstractCDOView.registerObject(AbstractCDOView.java:1324)
 at org.eclipse.emf.internal.cdo.view.AbstractCDOView.getObject(AbstractCDOView.java:923)
 at org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl.getObject(CDOTransactionImpl.java:1150)
 at org.eclipse.emf.internal.cdo.view.AbstractCDOView.convertIDToObject(AbstractCDOView.java:1255)
 at org.eclipse.emf.internal.cdo.view.CDOStoreImpl.convertIDToObject(CDOStoreImpl.java:702)
 at org.eclipse.emf.internal.cdo.view.CDOStoreImpl.getContainer(CDOStoreImpl.java:129)
 at org.eclipse.emf.internal.cdo.CDOObjectImpl.eInternalContainer(CDOObjectImpl.java:707)
 at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eInternalResource(BasicEObjectImpl.java:929)
 at org.eclipse.emf.internal.cdo.CDOObjectImpl.eInternalResource(CDOObjectImpl.java:581)
 at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eResource(BasicEObjectImpl.java:920)
 at org.eclipse.emf.internal.cdo.CDOObjectImpl.cdoResource(CDOObjectImpl.java:166)
 at org.eclipse.emf.cdo.util.CDOLazyContentAdapter.isContained(CDOLazyContentAdapter.java:208)
 at org.eclipse.emf.cdo.util.CDOLazyContentAdapter.addCleanObjectHandler(CDOLazyContentAdapter.java:124)
 at org.eclipse.emf.cdo.util.CDOLazyContentAdapter.setTarget(CDOLazyContentAdapter.java:60)
Don't you know, what can it be?
Re: [EMF] [CDO] ConcurrentModificationException when setting setTrackingModification(true) [message #1242235 is a reply to message #1230955] Sun, 09 February 2014 02:35 Go to previous message
Am 13.01.2014 13:57, schrieb Leonid Ripeynih:
I've added this stacktrace to https://bugs.eclipse.org/bugs/show_bug.cgi?id=424889
Cheers
/Eike
Previous Topic:how to create a CDO repository
Next Topic:[CDO] Can different idGenerationLocations be used on a same server ?
Current Time: Sun Jul 20 16:20:05 EDT 2025
Powered by FUDForum. Page generated in 0.26161 seconds
