Home » Archived » Buckminster » inconsistent xtext version ranges for binary dependencies during materialization
inconsistent xtext version ranges for binary dependencies during materialization [message #1225713] |
Mon, 30 December 2013 10:18  |
I materialize the target platform for my xtext projects using a .cquery
and a .cspec containing all the target platform dependencies (I have a
cquery for the tp and one for the projects, as created by the Xtext
Buckminster wizard).
The cspec for the tp is as follows:
<cs:cspec xmlns:cs="http://www.eclipse.org/buckminster/CSpec-1.0"
name="org.example.releng" componentType="buckminster" version="1.0.0">
<cs:dependencies>
<cs:dependency name="org.eclipse.platform"
componentType="eclipse.feature"/>
<cs:dependency name="org.eclipse.xtext.sdk"
componentType="eclipse.feature" versionDesignator="[2.4.3,2.5.0)"/>
</cs:dependencies>
</cs:cspec>
I use the versionDesignator because I want to build with Xtext 2.4.3
(and not with the recently released 2.5.0 version).
The Xtext features in the TP are materialized with the correct version
2.4.3, but some Xtext bundles are materialized twice: with version 2.4.3
and 2.5.0.
Indeed I get some warnings of the shape
[java] WARNING [0042] : Component request
org.eclipse.xtext.xbase.lib:osgi.bundle/[2.4.3.v201309030823,2.4.3.v201309030823]
is in conflict with request org.eclipse.xtext.xbase.lib:osgi.bundle/2.5.0
[java] INFO: TAG-ID 0042 = Query for org.example.releng:buckminster,
path: org.example.releng:buckminster$1.0.0 ->
org.eclipse.xtext.sdk:eclipse.feature$2.4.3.v201309030823 ->
org.eclipse.xtext.xbase:eclipse.feature$2.4.3.v201309030823 ->
org.eclipse.xtext.xbase.lib:eclipse.feature$2.4.3.v201309030823
am I doing anything wrong? Or is the way Xtext features are deployed?
I know that by using advisor nodes in the cquery I could force the
versions, but I thought that specifying the version range in the .cspec
would be enough...
thanks in advance
Lorenzo
HOME: http://www.lorenzobettini.it
Xtext Book:
http://www.packtpub.com/implementing-domain-specific-languages-with-xtext-and-xtend/book
Re: inconsistent xtext version ranges for binary dependencies during materialization [message #1226790 is a reply to message #1226701] |
Thu, 02 January 2014 13:15   |
On 02/01/2014 13:48, Thomas Hallgren wrote:
> Hi Lorenzo,
> The reason you get this warning and multiple xtext versions is that
> something in your TP still requires
> org.eclipse.xtext.xbase.lib:osgi.bundle/2.5.0. You'll have to figure out
> what feature or bundle that does that and then remove it from the equation.
Hi Thomas
the cspec of my TP is the one I wrote in the original message, thus
basically only
no other deps (besides org.eclipse.platform which surely do not have
deps on any xtext bundle).
Thus, can it be that this is due to some Xtext feature that has an
"open" version range? And then the resolution will pull in more recent
versions of xtext bundles?
thanks in advance
Lorenzo
> - thomas
> On 2013-12-30 16:18, Lorenzo Bettini wrote:
>> Hi
>> <?xml version="1.0" encoding="UTF-8"?>
>> <cs:dependencies>
>> </cs:dependencies>
>> </cs:cspec>
>> and 2.5.0.
>> would be enough...
>> thanks in advance
>> Lorenzo
Xtext Book:
Re: inconsistent xtext version ranges for binary dependencies during materialization [message #1232102 is a reply to message #1227009] |
Thu, 16 January 2014 03:42  |
On 03/01/2014 10:25, Thomas Hallgren wrote:
>>> Hi Lorenzo,
>>> equation.
>> Hi Thomas
>> basically only
> It's possible yes. Buckminster will not retrace individual resolution
> threads up to the root so if some dependency is open ended and that in
> turn has a dependency that requires >= 2.5.0, then the conflict would
> occur.
> You should be able to avoid this by introducing an explicit dependency
> to a 2.4.x version of the ones that resolve to 2.5.0. I usually use the
> cspec editor and the resolve wizard to find out what goes on.
I guess you mean the cquery editor; I've just used that wizard, cool! :)
and I think I tracked down the problem to this chain of deps (see also
the screenshot http://imageshack.com/a/img89/3310/04d8.png )
org.eclipse.xtext.sdk 2.4.3
org.eclipse.xtend.sdk 2.4.3
org.eclipse.xtend.core 2.4.3
org.eclipse.emf.mwe2.launch 2.4.1
org.eclipse.xtext 2.5.0
but it's not that it requires >= 2.5.0: it's just that it does have some
deps of the shape [2.4.0,3.0.0)
at this point I should go back to advisor nodes for all xtext bundles
with a regular expression I guess... or did you suggest to specify
single explicit deps on xtext bundles?
cheers
Lorenzo
Xtext Book:
Current Time: Sun Jul 20 16:11:17 EDT 2025
Powered by FUDForum. Page generated in 0.05131 seconds
