Drill down with engine API [message #122591] |
Wed, 01 February 2006 07:45  |
Originally posted by: jan.tanis.coas.com
I'm trying to implement the runtime engine into our company framework.
And now have the result of a report embedded into a JSP. The report
contains links to other reports, so called drill-down, but the links are
NOT displayed in my embedding. How do I set up the engine so it
generated the right links to the other reports? Do I have to use
IHTMLActionHandler or something like that and can you provide me with an
example? Thanks in advance.
Regards, Jan.
Re: Drill down with engine API [message #122671 is a reply to message #122621] |
Wed, 01 February 2006 09:02  |
rams wrote:
> hi jan,
> its not answer to ur query but its once again question
> as u told ur displaying reports in jsp.
> let me know which version of birt ur using for that.
2.0.0 release build
and aslo
> we are also integrated birt with our company framework and its working
> fine with birt 1.0.1 after that we replaced all the 1.0.1 jars with
> 2.0.0 but its showing NULL POINTER EXCEPTION when we executing the
> folloing statement.
> reportObj = engine.openReportDesign(reportname);
> here reportname is like this : e:\Reports\test.rptdesign
> which are created using birt 2.0.0 designer
> could help me regarding this plz.
Well, I did use the example code for generating report from Java code,
so you can just view that code from the BIRT website, at least it used
to be there:
public void run(OutputStream outputStream) {
EngineConfig config = new EngineConfig();
config.setEngineHome(engineHome);
if (tempDir != null) {
config.setTempDir(tempDir);
String format = HTMLRenderOption.OUTPUT_FORMAT_HTML;
if(formatType.equalsIgnoreCase("PDF")) {
format = HTMLRenderOption.OUTPUT_FORMAT_PDF;
HTMLEmitterConfig hc = new HTMLEmitterConfig();
HTMLCompleteImageHandler imageHandler
= new HTMLCompleteImageHandler();
hc.setImageHandler(imageHandler);
config.setEmitterConfiguration(
format
, hc);
ReportEngine engine = new ReportEngine(config);
IReportRunnable report = null;
try {
report = engine.openReportDesign(input);
} catch (EngineException e) {
System.err.println("Report not found!\n");
engine.destroy();
return;
if (format != null) {
parseParams(engine, report, parameters);
IRunAndRenderTask task =
engine.createRunAndRenderTask(report);
HTMLRenderOption options = new HTMLRenderOption();
options.setOutputFormat(format);
options.setOutputStream(outputStream);
options.setEmbeddable(embeddable);
task.setRenderOption(options);
task.setParameterValues(parameters);
// Run the report.
try {
task.run();
} catch (EngineException e1) {
System.err.println("Report run failed.\n");
System.err.println(e1.toString());
engine.destroy();
Good luck with the integration, it works fine here now:) Besides the
drill-down linking.
Regards, Jan.
FUDForum. Page generated in 0.24225 seconds
