Home » Modeling » TMF (Xtext) » Xtext OutputConfigurationProvider (Problem in Reading the statements inside //)
Xtext OutputConfigurationProvider [message #1225557] Mon, 30 December 2013 01:04 Go to next message
Hi All,
I am facing issues to read the statements inside // in xtext template using OutputConfiguration Provider class. I have written the grammar to read all statements that comes after // or /*.Any Help is appreciated.
Kunal
Re: Xtext OutputConfigurationProvider [message #1225692 is a reply to message #1225557] Mon, 30 December 2013 09:30 Go to previous messageGo to next message
Hi can you please give some more Context of what you exactly want todo
Where you you want Todo this
What do you want to do (example)
Re: Xtext OutputConfigurationProvider [message #1225910 is a reply to message #1225692] Tue, 31 December 2013 00:13 Go to previous messageGo to next message
I have a grammar file say AD.xtext,Below is the content of AD.xtext
Statement:
Note
Note:
('//' name = ID)
Now in the Template file whenever put any comments inside // I want to parse the content inside // into a txt file.
I am able to parse the content of other parts of template by creation custom OutputConfigurationProvider class but when comes to parse the content inside // or /*
*/, the xtext takes it as default comment and I am not able to see any thing in the Object for comment( ie Note in above case).
Is there any way to to parse this content?
Please let me know if you need further clarifications.
[Updated on: Fri, 03 January 2014 02:21] by Moderator
Re: Xtext OutputConfigurationProvider [message #1225971 is a reply to message #1225910] Tue, 31 December 2013 04:38 Go to previous messageGo to next message
Hi I assume you use the terminal grammar as a supergrammar.
There is a hidden SL comment rule that collides with your stuff
So what introducing a data type rule and use this one (you may need a value converter as well)
Note: name=NoteValue;
NoteValue hidden(): SL_COMMENT;
Re: Xtext OutputConfigurationProvider [message #1226607 is a reply to message #1225971] Thu, 02 January 2014 02:29 Go to previous messageGo to next message
Hi Chris,
Thanks for the reply.I tried with your code and below is the Grammar file and usage File :
Grammar File
Statement:
Note
Note:
('//' name = ID)
terminal SL_COMMENT : '//' !('\n'|'\r')* ('\r'? '\n')? ;
name hidden(): SL_COMMENT;
Xtend class for parsing
class AdlGenerator implements IGenerator {
override void doGenerate(Resource resource, IFileSystemAccess fsa) {
fsa.generateFile('parsed.txt', 'Content of Note is: ' +
resource.allContents
.filter(typeof(Note))
.map[name]
.join(', '))
================================Usage File=================================
hh.ad
Entity Action:{
//text
After saving the usage file.. I see the content of parsed.txt as empty.. Can u pls have a look. Appreciate your Help here...
[Updated on: Fri, 03 January 2014 03:32] by Moderator
Re: Xtext OutputConfigurationProvider [message #1226647 is a reply to message #1226607] Thu, 02 January 2014 04:54 Go to previous messageGo to next message
Hi Kunal,
I think you have not applied the example from Dietrich Correctly:
Your grammar reads:
Note:
('//' name = ID)
Think that makes the difference
Re: Xtext OutputConfigurationProvider [message #1226654 is a reply to message #1226647] Thu, 02 January 2014 05:20 Go to previous messageGo to next message
and of course you do not have to redefine sl_comment since you already inherit it from the supergrammar
Re: Xtext OutputConfigurationProvider [message #1226659 is a reply to message #1226654] Thu, 02 January 2014 05:38 Go to previous messageGo to next message
i had a look,
it is not enhough to switch it off on datatype rule level, you have to switch it off above
is there a reason to have comments as comments or shall they always be values?
if so you can unhide them on grammar level.
grammar org.xtext.example.mydsl.MyDsl with org.eclipse.xtext.common.Terminals
hidden (WS, ML_COMMENT)
Note:
name=NoteValue
NoteValue  : SL_COMMENT;
alternatively you could redefine the SL_COMMENT rule not to use // or do not
inherit from terminals and thus not having a SL_COMMENT rule at all.
Re: Xtext OutputConfigurationProvider [message #1226665 is a reply to message #1226647] Thu, 02 January 2014 05:47 Go to previous messageGo to next message
I changed the grammar below but still I am unable to parse the content:
AD.xtext
Note
Note:
name=NoteValue
Kunal
Re: Xtext OutputConfigurationProvider [message #1226666 is a reply to message #1226665] Thu, 02 January 2014 05:48 Go to previous messageGo to next message
have a look at my new posts
Re: Xtext OutputConfigurationProvider [message #1226686 is a reply to message #1226666] Thu, 02 January 2014 06:53 Go to previous messageGo to next message
url to elicpse xtext Terminal
hidden (WS, ML_COMMENT,SL_COMMENT)
Statement:
	Note
Note:
name=NoteValue
NoteValue  : '//';
	 (statements +=  Statement )*
Still same issue Sad
[Updated on: Fri, 03 January 2014 03:43] by Moderator
Re: Xtext OutputConfigurationProvider [message #1226688 is a reply to message #1226686] Thu, 02 January 2014 06:56 Go to previous messageGo to next message
I tried with :
Note:
name=NoteValue
Still no luck Sad
Re: Xtext OutputConfigurationProvider [message #1226695 is a reply to message #1226688] Thu, 02 January 2014 07:26 Go to previous messageGo to next message
Hi, seems you still did not do what i finallly told
this following works for me
generate myDsl "http://www.xtext.org/example/mydsl/MyDsl"
AD:
ActionDiagram
ActionDiagram:
'Action Diagram' name=ID
'Import:'
'Export:'
'Local:'
'Entity Action:'
Statement:
Note
Note:
name=NoteValue
Re: Xtext OutputConfigurationProvider [message #1227007 is a reply to message #1226695] Fri, 03 January 2014 04:24 Go to previous message
Yes, It worked for me !!!! Smile
Thanks a lot Chris...
Previous Topic:Xtext content assist
Next Topic:Xcore - Using annotations in IDE
Current Time: Sat Jul 19 18:45:16 EDT 2025
Powered by FUDForum. Page generated in 0.05420 seconds
