Home » Archived » BIRT » how to run rptdesign file from a plugin?
how to run rptdesign file from a plugin? [message #122645] Wed, 01 February 2006 08:45
Hi all,
I have implemented a plugin which uses BIRT API’s in order to run BIRT
rptdesign file. In the rptdesign file I try to call my DynamicFields
Object (my stuff) as follow:
new Packages.nl.fields.OMXDynamicFields();
If I run it as a standalone it works fine. But when it runs as Eclipse
plugin gives the following error:
Script engine error: TypeError: [JavaPackage nl.fields.DynamicFields] is
not a function. (DataSet:Set.open#12)
Any idea how to solve this?
Said
Previous Topic:Null Pointer Exception
Next Topic:scripted datasource for chart?
Current Time: Sat Jul 19 16:47:22 EDT 2025
Powered by FUDForum. Page generated in 0.24687 seconds
