[EMF] XML Serialization sequentially [message #1225141] |
Sat, 28 December 2013 17:05  |
Hello EMF Community,
I tried to search for similiar questions on the forum - but surprisingly I couldnt find any. (If I was just unable to figure out the right keywords, I apologize)
My goal is to serialize an Ecore-Model instance sequentially. I created my Ecore-Model out of a bigger XSD (around 2500 lines) and this results ofc into different java classes with relational dependencies. To avoid representing the whole model into the memory, I want to serialize each of these java classes step by step. But this results naturally in invalid opening and enclosing XML-Tags, since each java class is serialized as if it is an own XML document.
So: Is there any possibility with EMF to achieve this?
Any links or hints are appreciated!
Ben
Re: [EMF] XML Serialization sequentially [message #1225249 is a reply to message #1225141] |
Sun, 29 December 2013 01:41   |
Benjamin,
Comments below.
How many in-memory instances are we talking about? How much memory do
they consume? Do you plan to compose these pieces into a single document?
If the schema only allows certain root elements (has only certain global
element declarations) only those can be directly serialized in a way
that conforms to the schema. A document root is generally needed as
the root object in the resource in order to specify the namespace/name
of the root element. You can use
org.eclipse.emf.ecore.util.ExtendedMetaData.demandFeature(String,
String, boolean) to create an element with the desired namespace/name;
the getEContainingClass of that element will be a document root class
and you can make your object a child of that feature of and instance of
that document root class and serialize that document root to produce a
serialization with the desired root element.
This article is likely to be helpful:
http://www.theserverside.com/news/1364302/Binding-XML-to-Java
> Cheers,
> Ben
Re: [EMF] XML Serialization sequentially [message #1225268 is a reply to message #1225249] |
Sun, 29 December 2013 03:14  |
Hello Ed,
Ed Merks wrote on Sun, 29 December 2013 01:41Benjamin,
they consume??
Its actually a requirement for my project. I know its a killer argument, but thats how it is. If you are rly interested in hearing more details, I will explain it in my next post.
Yes, my goal is to get the same result as if I filled up all the relational dependencies from the top (rootDocument) till the end, having one single XML document at the end.
Thanks for the late christmas gift, Ed. I will try it out. First step would be to override the automatically created namespace/name of XML-Elements (nested Java classes/document root classes) for the serialization with your given approach. The article is indeed helpful.
To clearify a bit the xml schema structure: At the beginning theres a whole block of meta data which I can serialize directly. After that its like this: A contains B, B contains C, C contains D1,D2...Dn. Thats why the enclosing xml tags of A,B,C are invalid.
Ben
[Updated on: Sun, 29 December 2013 03:33] by Moderator
FUDForum. Page generated in 0.05863 seconds
