How can i change loaded resource uri ? [message #1222326] |
Fri, 20 December 2013 01:52  |
Hi all,
I want to ask, how can i change loaded resource uri ?
when i load resource and used it on file,
loaded as;
<types href="../../../plugin/com.mdd4cca.msf.content/model/Types.xmi#/"/>
but i need to store uri as absolute path cause when i move file its failing can i change this behavior?
Re: How can i change loaded resource uri ? [message #1222412 is a reply to message #1222326] |
Fri, 20 December 2013 05:44   |
You could use org.eclipse.emf.ecore.xmi.XMLResource.OPTION_URI_HANDLER.
You could use an instance of
org.eclipse.emf.ecore.xmi.impl.URIHandlerImpl.PlatformSchemeAware as the
value to avoid relative paths between platform:/resource and
platform:/plugin URIs, e.g., like we do for *.ecore resources:
public class EcoreResourceFactoryImpl extends ResourceFactoryImpl
* Constructor for EcoreResourceFactoryImpl.
public EcoreResourceFactoryImpl()
super();
public Resource createResource(URI uri)
XMLResource result =
new XMIResourceImpl(uri)
protected boolean useIDs()
return eObjectToIDMap != null || idToEObjectMap != null;
result.setEncoding("UTF-8");
result.getDefaultSaveOptions().put(XMLResource.OPTION_USE_ENCODED_ATTRIBUTE_STYLE,
Boolean.TRUE);
result.getDefaultSaveOptions().put(XMLResource.OPTION_LINE_WIDTH, 80);
result.getDefaultSaveOptions().put(XMLResource.OPTION_URI_HANDLER, new
URIHandlerImpl.PlatformSchemeAware());
return result;
On 20/12/2013 7:52 AM, serhat gezgin wrote:
> Hi all,
> loaded as;
> Regards
FUDForum. Page generated in 0.36944 seconds
