Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Hibernate Settings in Teneo
Hibernate Settings in Teneo [message #122233] Fri, 09 May 2008 10:26 Go to next message
I am using Teneo 0.8. I am trying to turn off Hibernates schema generation
by setting hmb2ddl.auto = "off" or "validate" but it seems Teneo is not
passing that setting to Hibernate. Pls let me know how can I turn this off.
Also let me know if there is a way to turn OFF constraints creation during
schema update. We plan to enforce constraints through business apps so
that we can save data to relational DB in batches without worrying abt
order of SQL inserts/updates.
Any help is appreciated.
Re: Hibernate Settings in Teneo [message #122244 is a reply to message #122233] Fri, 09 May 2008 17:04 Go to previous message
Hi Vaibhav,
Which version of Teneo are you using? Older versions used a Teneo specific option. The newest
versions should work using the hibernate option.
Can you post the exact code/property you use to set the hibernate option?
I don't know if it is possible to disable constraint creation during schema update.I checked but I
could not find such an option. You can dive into the hibernate source code maybe they have a hidden
feature somewhere.
gr. Martin
Vaibhav Kulkarni
> generation by setting hmb2ddl.auto = "off" or "validate" but it seems
> Teneo is not passing that setting to Hibernate. Pls let me know how can
> I turn this off.
> during schema update. We plan to enforce constraints through business
> apps so that we can save data to relational DB in batches without
> worrying abt order of SQL inserts/updates.
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Hibernate Settings in Teneo [message #618022 is a reply to message #122233] Fri, 09 May 2008 17:04 Go to previous message
Hi Vaibhav,
feature somewhere.
gr. Martin
Vaibhav Kulkarni
> I turn this off.
The Netherlands
Previous Topic:Hibernate Settings in Teneo
Next Topic:jet editor java syntax coloring
Current Time: Sat Jul 19 12:14:58 EDT 2025
Powered by FUDForum. Page generated in 0.03186 seconds
