Home » Modeling » EMF » [EMF] [CDO] [Compare] [Bug?] Compare will not work with certan implementation of EStore
[EMF] [CDO] [Compare] [Bug?] Compare will not work with certan implementation of EStore [message #1221331] |
Tue, 17 December 2013 07:49  |
As there is no responce in compare forum, i'm cross-posting it here:
This code (in ManyStructuralFeatureAccessorImpl) may not work if valueOfDiff is a FeatureMap.Entry.
private Diff getDiffWithValue(Object value) {
Diff ret = null;
for (Diff diff : getDifferences()) {
Object valueOfDiff = getValueFromDiff(diff, getSide());
if (valueOfDiff == value) {
ret = diff;
break;
return ret;
Consider an CDO implementation of EStoreEObjectImpl.EStoreFeatureMap which returns a new set of wrappers each time it's delegateToArray is called.
Wrappers are perfectly equal, and their wrapped objects are same (theis Values and Feature are same). However, wrappers are not same, and comparison by reference
(valueOfDiff == value) fails. I suggest changit this to equals (and EObject's can not override equals by it's contract, so it will not affect them)
Should I open a bugzilla for it, or is it intended behavior?
Re: [EMF] [CDO] [Compare] [Bug?] Compare will not work with certan implementation of EStore [message #1221342 is a reply to message #1221331] |
Tue, 17 December 2013 08:24   |
Hi Leonid,
I'm confused as to how CDO is related. Can you elaborate? What's the fully qualified name of
ManyStructuralFeatureAccessorImpl?
Cheers
/Eike
http://www.esc-net.de
Am 17.12.2013 13:49, schrieb Leonid Ripeynih:
> Diff ret = null;
> ret = diff;
> break;
> return ret;
> wrappers are not same, and comparison by reference (valueOfDiff == value) fails. I suggest changit this to equals (and
Re: [EMF] [CDO] [Compare] [Bug?] Compare will not work with certan implementation of EStore [message #1221813 is a reply to message #1221763] |
Wed, 18 December 2013 08:25   |
Hi, Eike, Leonid,
I suspect that the majority use case for FeatureMaps is to impose an
ordering of intermingled elements in the XML serialization that are
modeled in multiple EStructuralFeatures in the Ecore model. For this
purpose, UML provides a fairly elegant solution in the superset/subset
relationship between properties (although it does add some additional
"weight" in the persisted model, because of the additional references
to objects) that transcends XML.
A superset property can automatically aggregate (and impose an ordering
on) the objects in the properties that are its subsets. Optionally, a
superset can also have objects that are not in any of its subsets.
There are numerous examples of both (plus "derived unions", which
aren't so interesting in this case) in the UML Metamodel.
Since the Kepler release, CDO supports models generated with
superset/subset properties from UML (as an alternative to generating
from Ecore). However, this does require leveraging CDO's "legacy
model" support as CDO Native models don't implement these UML-isms.
Something to think about, at least.
Christian
On 2013-12-18 11:26:20 +0000, Eike Stepper said:
> Am 18.12.2013 10:47, schrieb Leonid Ripeynih:
>> Eike Stepper wrote on Wed, 18 December 2013 03:52
>>> Am 18.12.2013 06:21, That depends on how and for what purpose you're
>>> using feature maps ;)
>> They have originated from XSD -> Ecore transformation during initial
>> model generation. Mostly they're used for representation of
>> <xs:sequence>
>> <xs:choice maxOccures="unbounded"/>
>> </xs:sequence>
>> So, ordered structures without strict type bounds.
> You can probably use EList<EObject>, but it strikes me that it would be
> good to refactor the model to allow for stricter bounds. Hard to tell
> without knowing the model ;-)
> Cheers
> /Eike
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
Current Time: Sun Jul 20 11:06:47 EDT 2025
Powered by FUDForum. Page generated in 0.04469 seconds
