Home » Modeling » EMF » [EMF] [CDO] [Compare] [Bug?] Compare will not work with certan implementation of EStore
[EMF] [CDO] [Compare] [Bug?] Compare will not work with certan implementation of EStore [message #1221331] Tue, 17 December 2013 07:49 Go to next message
As there is no responce in compare forum, i'm cross-posting it here:
This code (in ManyStructuralFeatureAccessorImpl) may not work if valueOfDiff is a FeatureMap.Entry.
private Diff getDiffWithValue(Object value) {
   Diff ret = null;
   for (Diff diff : getDifferences()) {
      Object valueOfDiff = getValueFromDiff(diff, getSide());
      if (valueOfDiff == value) {
        ret = diff;
        break;
   return ret;
Consider an CDO implementation of EStoreEObjectImpl.EStoreFeatureMap which returns a new set of wrappers each time it's delegateToArray is called.
Wrappers are perfectly equal, and their wrapped objects are same (theis Values and Feature are same). However, wrappers are not same, and comparison by reference
(valueOfDiff == value) fails. I suggest changit this to equals (and EObject's can not override equals by it's contract, so it will not affect them)
Should I open a bugzilla for it, or is it intended behavior?
Re: [EMF] [CDO] [Compare] [Bug?] Compare will not work with certan implementation of EStore [message #1221342 is a reply to message #1221331] Tue, 17 December 2013 08:24 Go to previous messageGo to next message
Hi Leonid,
I'm confused as to how CDO is related. Can you elaborate? What's the fully qualified name of
ManyStructuralFeatureAccessorImpl?
Cheers
/Eike
http://www.esc-net.de
Am 17.12.2013 13:49, schrieb Leonid Ripeynih:
> Diff ret = null;
> ret = diff;
> break;
> return ret;
> wrappers are not same, and comparison by reference (valueOfDiff == value) fails. I suggest changit this to equals (and
Re: [EMF] [CDO] [Compare] [Bug?] Compare will not work with certan implementation of EStore [message #1221357 is a reply to message #1221342] Tue, 17 December 2013 09:06 Go to previous messageGo to next message
Eike Stepper wrote on Tue, 17 December 2013 08:24
Hi Leonid,
It'related to CDO in a less direct way. Here:
org.eclipse.emf.internal.cdo.view.CDOStoreImpl.convertToCDO(InternalCDOObject, EStructuralFeature, Object)
it will return a new FeatureMapEntry each time it's called. That causes problems with compare, using '==' instead of 'equals' when comparing differences.
[Updated on: Tue, 17 December 2013 09:06] by Moderator
Re: [EMF] [CDO] [Compare] [Bug?] Compare will not work with certan implementation of EStore [message #1221447 is a reply to message #1221357] Tue, 17 December 2013 13:20 Go to previous messageGo to next message
Am 17.12.2013 15:06, schrieb Leonid Ripeynih:
> [quote title=Eike Stepper wrote on Tue, 17 December 2013 08:24]Hi Leonid,
I can currently not tell whether it's in line with the contract to create multiple instances but I know for sure that
CDO doesn't fully/properly support feature maps. Many years ago we tried to support them and there might be evidence
here and there in the code. But it turned out to be too much effort (and cross cutting impact) and we stopped it.
Cheers
/Eike
Re: [EMF] [CDO] [Compare] [Bug?] Compare will not work with certan implementation of EStore [message #1221629 is a reply to message #1221447] Wed, 18 December 2013 00:21 Go to previous messageGo to next message
Eike Stepper wrote on Tue, 17 December 2013 13:20
I see. With some patches to CDO common/emf we've got it to work quite well, but yeah, it causes us some trouble.
What is the 'recommended' replacement for FeatureMaps for use with the CDO?
Re: [EMF] [CDO] [Compare] [Bug?] Compare will not work with certan implementation of EStore [message #1221695 is a reply to message #1221629] Wed, 18 December 2013 03:52 Go to previous messageGo to next message
Am 18.12.2013 06:21, schrieb Leonid Ripeynih:
That depends on how and for what purpose you're using feature maps ;-)
Cheers
/Eike
Re: [EMF] [CDO] [Compare] [Bug?] Compare will not work with certan implementation of EStore [message #1221721 is a reply to message #1221695] Wed, 18 December 2013 04:46 Go to previous messageGo to next message
Eike Stepper wrote on Wed, 18 December 2013 03:52
That depends on how and for what purpose you're using feature maps Wink
They have originated from XSD -> Ecore transformation during initial model generation. Mostly they're used for representation of
<xs:sequence>
  <xs:choice maxOccures="unbounded"/>
</xs:sequence>
So, ordered structures without strict type bounds.
Re: [EMF] [CDO] [Compare] [Bug?] Compare will not work with certan implementation of EStore [message #1221763 is a reply to message #1221721] Wed, 18 December 2013 06:26 Go to previous messageGo to next message
Am 18.12.2013 10:47, schrieb Leonid Ripeynih:
>> Am 18.12.2013 06:21, That depends on how and for what purpose you're using feature maps ;)
> representation of
> <xs:sequence>
> </xs:sequence>
You can probably use EList<EObject>, but it strikes me that it would be good to refactor the model to allow for stricter
bounds. Hard to tell without knowing the model ;-)
Cheers
/Eike
Re: [EMF] [CDO] [Compare] [Bug?] Compare will not work with certan implementation of EStore [message #1221813 is a reply to message #1221763] Wed, 18 December 2013 08:25 Go to previous messageGo to next message
Hi, Eike, Leonid,
I suspect that the majority use case for FeatureMaps is to impose an
ordering of intermingled elements in the XML serialization that are
modeled in multiple EStructuralFeatures in the Ecore model. For this
purpose, UML provides a fairly elegant solution in the superset/subset
relationship between properties (although it does add some additional
"weight" in the persisted model, because of the additional references
to objects) that transcends XML.
A superset property can automatically aggregate (and impose an ordering
on) the objects in the properties that are its subsets. Optionally, a
superset can also have objects that are not in any of its subsets.
There are numerous examples of both (plus "derived unions", which
aren't so interesting in this case) in the UML Metamodel.
Since the Kepler release, CDO supports models generated with
superset/subset properties from UML (as an alternative to generating
from Ecore). However, this does require leveraging CDO's "legacy
model" support as CDO Native models don't implement these UML-isms.
Something to think about, at least.
Christian
>> <xs:sequence>
>> </xs:sequence>
> good to refactor the model to allow for stricter bounds. Hard to tell
> Cheers
> /Eike
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
Re: [EMF] [CDO] [Compare] [Bug?] Compare will not work with certan implementation of EStore [message #1222007 is a reply to message #1221813] Thu, 19 December 2013 05:54 Go to previous message
I replied to the original message in the emf compare forum http://www.eclipse.org/forums/index.php/t/628281/
Previous Topic:[CDO] CDOResource obtaining the connection aware URI
Next Topic:XML output unformatted with ecore:mixed
Current Time: Sat Jul 19 11:02:45 EDT 2025
Powered by FUDForum. Page generated in 0.29308 seconds
