Home » Eclipse Projects » EGit / JGit » How to check status of local branch with respect to remote branch in a lightweight way?
How to check status of local branch with respect to remote branch in a lightweight way? [message #1219939] Fri, 06 December 2013 18:43 Go to next message
I am trying to implement a polling of remote branch to discover that my local branch need to be updated.
I am initializing git repo this way:
    val cloneCmd = Git.cloneRepository()
    cloneCmd.setDirectory(repoDir)
      .setURI(gitLocation)
      .setNoCheckout(false)
      .setBranch("live")
      .call()
and then I can manually update it:
    git.pull().call()
I am planning to implement polling remote repo (lets say every 15s), but I don't want to call pull() that often, because pull() is blocking other parts of app that use local branch. I'd like to check (often) somehow that local branch is behind and only then call pull().
How can I do that?
BTW, I want to use this mechanism to serve HTTP "directly from git repo". Obviously I have to "lock" traffic for a time of pull(). It is ok for my use case if this happens occasionally, but doing this every 15s is not acceptable.
Any help would be appreciated.
Re: How to check status of local branch with respect to remote branch in a lightweight way? [message #1220223 is a reply to message #1219939] Tue, 10 December 2013 08:16 Go to previous messageGo to next message
pull actually does two things: it fetches commits from a remote and then
merges them into the current branch.
What you likely want is use
git.fetch().call()
to obtain changes from the remote (if any).
Then you can compare the local/current branch with its remote tacking
branch. BranchTrackingStatus.of() is there to help you with this.
HTH
Rüdiger
On 07.12.2013 20:02, Jarek Odzga wrote:
> .setBranch("live")
> .call()
> git.pull().call()
> How can I do that?
> is not acceptable.
Rüdiger Herrmann
http://codeaffine.com
Re: How to check status of local branch with respect to remote branch in a lightweight way? [message #1220270 is a reply to message #1220223] Tue, 10 December 2013 13:32 Go to previous messageGo to next message
Thanks!
This is exactly what I was looking for.
Re: How to check status of local branch with respect to remote branch in a lightweight way? [message #1220653 is a reply to message #1220223] Thu, 12 December 2013 16:48 Go to previous messageGo to next message
Rüdiger Herrmann wrote on Tue, 10 December 2013 14:16
git.fetch().call()
While pull does two things isn't the fetch part the costly one? After all I thought fetch not only updates the local "remote" refs but also downloads the data as well. Eventually that's what you get using the CLI.
Re: How to check status of local branch with respect to remote branch in a lightweight way? [message #1220787 is a reply to message #1220653] Fri, 13 December 2013 10:22 Go to previous messageGo to next message
you might be right. Depending on how far your local repository is
behind, fetch might be costly.
If you aren't interested in the details, you can dry-run the fetch
command. IIRC, that would give you the object-id of the remote commit
and you could compare that to your local object-id.
>> then merges them into the current branch.
>> git.fetch().call()
Rüdiger Herrmann
Re: How to check status of local branch with respect to remote branch in a lightweight way? [message #1221521 is a reply to message #1220787] Tue, 17 December 2013 16:57 Go to previous message
Rüdiger Herrmann wrote on Fri, 13 December 2013 16:22
I totally forgot about the dry-run option...Wink
Previous Topic:Could Not Initialize NSS
Next Topic:Compare With/Replace With bug in nightly build?
Current Time: Sat Jul 19 21:19:11 EDT 2025
Powered by FUDForum. Page generated in 0.31430 seconds
