Home » Archived » Jubula » Component with text should not contain certain string
Component with text should not contain certain string [message #1220072] Mon, 09 December 2013 08:55 Go to next message
Hey to all,
I tried to check a text field not containing a spezified String. At the Documentation is a hint to use a special regex: To check that a specific string is not in a text, use: ^.*[^(STRING)].*\$
So I use the test case ub_ctx_checkText with the following arguments:
TEXT = ^.*[^(exception)].*\$
OPERATOR = matches
the component type is org.eclipse.swt.custom.StyledText
When I execute the test case, it will passing when "exception" is not contained, but it will also passing when "exeption" is contained in the text.
So what is my error?
regards,
Sascha
Re: Component with text should not contain certain string [message #1220158 is a reply to message #1220072] Tue, 10 December 2013 02:13 Go to previous messageGo to next message
I'm not the regex genius, I'll happily admit. I seem to remember someone correcting the regex, but I can't find the place, and the docs aren't changed at the moment. Either it got forgot, or it is already changed. Google might be your friend unless someone else is better in regex than I am. If you find something that works, let us know. Then we can update the docs.
Alex
Re: Component with text should not contain certain string [message #1220547 is a reply to message #1220158] Thu, 12 December 2013 09:01 Go to previous messageGo to next message
Hey Alex,
I found a regex matching for my needs, but now i have a problem converting it to "jubula-regex". The regex is
^((?!hede)[\s\S])*$
I thought that i had to escape the '?' and the '!', but this will ending in an syntax error while the test execution. If I do not escaping anything I can not set the regex at the testcase.
Re: Component with text should not contain certain string [message #1220558 is a reply to message #1220547] Thu, 12 December 2013 09:32 Go to previous messageGo to next message
Hi there,
Thanks for the update! To escape a whole string, just use single quotes around the string, so: '^((?!hede)[\s\S])*$'
I tested it and it works. I'll update the docs - thanks for your help Smile
Alex
Re: Component with text should not contain certain string [message #1220563 is a reply to message #1220558] Thu, 12 December 2013 09:39 Go to previous message
Thanks for your help, too.
single quotes - that was too easy Very Happy
[Updated on: Thu, 12 December 2013 09:40] by Moderator
Previous Topic:Poll: Do you test Java 1.4 AUT's?
Next Topic:HTML AUT will not start
Current Time: Sat Jul 19 23:40:05 EDT 2025
Powered by FUDForum. Page generated in 0.05725 seconds
