Home » Language IDEs » PHP Development Tools (PDT) » Eclipse crashes
icon11.gif  Eclipse crashes [message #1220342] Wed, 11 December 2013 03:31 Go to next message
I work with eclipse for a while on my laptop
and for some reason it started crashing.
I asked in "stackoverflow" for a solution and they told me to raise the Xmx parameter from 384 to 512 M in the eclipse.ini file.
It started working for a longer time but still gets stuck again with an other error message:
!SESSION 2013-12-10 22:13:52.935 -----------------------------------------------
eclipse.buildId=I20100608-0911
java.version=1.7.0_45
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
Framework arguments:  -product org.eclipse.epp.package.php.product
Command-line arguments:  -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.php.product
!ENTRY org.eclipse.ui 4 0 2013-12-10 22:14:18.968
!MESSAGE Unhandled event loop exception
!STACK 0
org.eclipse.swt.SWTException: Widget is disposed
	at org.eclipse.swt.SWT.error(SWT.java:4083)
	at org.eclipse.swt.SWT.error(SWT.java:3998)
	at org.eclipse.swt.SWT.error(SWT.java:3969)
	at org.eclipse.swt.widgets.Widget.error(Widget.java:468)
	at org.eclipse.swt.widgets.Widget.checkWidget(Widget.java:340)
	at org.eclipse.swt.widgets.Label.setText(Label.java:387)
	at org.eclipse.jface.wizard.ProgressMonitorPart.done(ProgressMonitorPart.java:184)
	at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java:1015)
	at org.eclipse.php.internal.ui.wizards.PHPProjectWizardSecondPage.changeToNewProject(PHPProjectWizardSecondPage.java:145)
	at org.eclipse.php.internal.ui.wizards.PHPProjectWizardSecondPage.initPage(PHPProjectWizardSecondPage.java:658)
	at org.eclipse.php.internal.ui.wizards.PHPProjectWizardFirstPage.setVisible(PHPProjectWizardFirstPage.java:971)
	at org.eclipse.jface.wizard.WizardDialog.updateForPage(WizardDialog.java:1241)
	at org.eclipse.jface.wizard.WizardDialog.access$4(WizardDialog.java:1218)
	at org.eclipse.jface.wizard.WizardDialog$6.run(WizardDialog.java:1207)
	at org.eclipse.jface.wizard.WizardDialog.showPage(WizardDialog.java:1205)
	at org.eclipse.jface.wizard.WizardDialog.nextPressed(WizardDialog.java:894)
	at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDialog.java:426)
	at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:624)
	at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:234)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
	at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4066)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3657)
	at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
	at org.eclipse.jface.window.Window.open(Window.java:801)
	at org.eclipse.ui.internal.actions.NewWizardShortcutAction.run(NewWizardShortcutAction.java:135)
	at org.eclipse.jface.action.Action.runWithEvent(Action.java:498)
	at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
	at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
	at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
	at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2629)
	at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2593)
	at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2427)
	at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:670)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:663)
	at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:115)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:619)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1383)
!ENTRY org.eclipse.ui 4 0 2013-12-10 22:23:50.956
!STACK 0
java.lang.OutOfMemoryError: PermGen space
	at java.lang.ClassLoader.defineClass1(Native Method)
	at java.lang.ClassLoader.defineClass(Unknown Source)
	at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.defineClass(DefaultClassLoader.java:188)
	at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineClass(ClasspathManager.java:580)
	at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findClassImpl(ClasspathManager.java:550)
	at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClassImpl(ClasspathManager.java:481)
	at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass_LockClassName(ClasspathManager.java:460)
	at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:447)
	at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:216)
	at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:393)
	at org.eclipse.osgi.internal.loader.SingleSourcePackage.loadClass(SingleSourcePackage.java:33)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:466)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:422)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:410)
	at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
	at org.eclipse.wst.jsdt.internal.ui.javaeditor.SemanticHighlightingReconciler.<init>(SemanticHighlightingReconciler.java:176)
	at org.eclipse.wst.jsdt.internal.ui.javaeditor.SemanticHighlightingManager.enable(SemanticHighlightingManager.java:328)
	at org.eclipse.wst.jsdt.internal.ui.javaeditor.SemanticHighlightingManager.install(SemanticHighlightingManager.java:302)
	at org.eclipse.wst.jsdt.internal.ui.javaeditor.JavaEditor.installSemanticHighlighting(JavaEditor.java:3080)
	at org.eclipse.wst.jsdt.internal.ui.javaeditor.JavaEditor.createPartControl(JavaEditor.java:2624)
	at org.eclipse.wst.jsdt.internal.ui.javaeditor.CompilationUnitEditor.createPartControl(CompilationUnitEditor.java:1410)
	at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:670)
	at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:465)
	at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:595)
	at org.eclipse.ui.internal.EditorReference.getEditor(EditorReference.java:289)
	at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched(WorkbenchPage.java:2863)
	at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:2768)
	at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPage.java:2760)
	at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:2711)
	at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2707)
!SESSION 2013-12-10 22:32:35.592 -----------------------------------------------
!ENTRY org.eclipse.core.resources 2 10035 2013-12-10 22:32:37.960
!MESSAGE The workspace exited with unsaved changes in the previous session; refreshing workspace to recover changes.
!ENTRY org.eclipse.ui 4 0 2013-12-10 22:42:36.706
!STACK 0
	at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:469)
	at org.apache.xerces.impl.XMLEntityManager.expandSystemIdStrictOff(Unknown Source)
	at org.apache.xerces.impl.XMLEntityManager.expandSystemId(Unknown Source)
	at org.apache.xerces.impl.XMLEntityManager.setupCurrentEntity(Unknown Source)
	at org.apache.xerces.impl.XMLVersionDetector.determineDocVersion(Unknown Source)
	at org.apache.xerces.parsers.XML11Configuration.parse(Unknown Source)
	at org.apache.xerces.parsers.XMLParser.parse(Unknown Source)
	at org.apache.xerces.parsers.AbstractSAXParser.parse(Unknown Source)
	at org.apache.xerces.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unknown Source)
	at org.eclipse.wst.dtd.core.internal.saxparser.DTDParser.parse(DTDParser.java:128)
	at org.eclipse.wst.dtd.core.internal.emf.util.DTDUtil.parse(DTDUtil.java:102)
	at org.eclipse.wst.dtd.core.internal.contentmodel.DTDImpl.buildDTDModel(DTDImpl.java:88)
	at org.eclipse.wst.dtd.core.internal.contentmodel.DTDImpl.buildCMDocument(DTDImpl.java:79)
	at org.eclipse.wst.dtd.core.internal.contentmodel.CMDocumentFactoryDTD.createCMDocument(CMDocumentFactoryDTD.java:37)
	at org.eclipse.wst.xml.core.internal.contentmodel.ContentModelManager.createCMDocument(ContentModelManager.java:56)
	at org.eclipse.wst.xml.core.internal.contentmodel.modelqueryimpl.CMDocumentManagerImpl.buildCMDocument(CMDocumentManagerImpl.java:284)
	at org.eclipse.wst.xml.core.internal.contentmodel.modelqueryimpl.CMDocumentManagerImpl.loadCMDocument(CMDocumentManagerImpl.java:259)
!SESSION 2013-12-10 22:50:55.588 -----------------------------------------------
!ENTRY org.eclipse.core.resources 2 10035 2013-12-10 22:50:58.026
!SESSION 2013-12-11 20:36:09.276 -----------------------------------------------
!ENTRY org.eclipse.core.resources 2 10035 2013-12-11 20:36:11.812
!SESSION 2013-12-11 20:44:46.393 -----------------------------------------------
!ENTRY org.eclipse.ui 4 0 2013-12-11 22:19:53.504
!STACK 0
	at org.eclipse.emf.ecore.impl.EcoreFactoryImpl.createEAttribute(EcoreFactoryImpl.java:249)
	at org.eclipse.emf.ecore.impl.EPackageImpl.createEAttribute(EPackageImpl.java:785)
	at org.eclipse.emf.ecore.impl.EcorePackageImpl.createPackageContents(EcorePackageImpl.java:2286)
	at org.eclipse.emf.ecore.impl.EcorePackageImpl.init(EcorePackageImpl.java:488)
	at org.eclipse.emf.ecore.EcorePackage.<clinit>(EcorePackage.java:73)
	at org.eclipse.emf.ecore.impl.EPackageImpl.<init>(EPackageImpl.java:191)
	at org.eclipse.wst.dtd.core.internal.emf.impl.DTDPackageImpl.<init>(DTDPackageImpl.java:254)
	at org.eclipse.wst.dtd.core.internal.emf.impl.DTDPackageImpl.init(DTDPackageImpl.java:287)
	at org.eclipse.wst.dtd.core.internal.contentmodel.DTDImpl.<clinit>(DTDImpl.java:72)
	at org.eclipse.wst.xml.core.internal.contentmodel.modelqueryimpl.CMDocumentManagerImpl.getCMDocument(CMDocumentManagerImpl.java:195)
	at org.eclipse.wst.xml.core.internal.contentmodel.modelqueryimpl.XMLAssociationProvider.getCMDocument(XMLAssociationProvider.java:149)
	at org.eclipse.wst.xml.core.internal.contentmodel.modelqueryimpl.XMLAssociationProvider.getCMElementDeclaration(XMLAssociationProvider.java:220)
	at org.eclipse.wst.html.core.internal.modelquery.HTMLModelQueryImpl.getCMElementDeclaration(HTMLModelQueryImpl.java:156)
	at org.eclipse.wst.xml.ui.internal.editor.CMImageUtil.getDeclaration(CMImageUtil.java:50)
	at org.eclipse.wst.xml.ui.internal.contentoutline.JFaceNodeAdapter.getLabelImage(JFaceNodeAdapter.java:144)
	at org.eclipse.wst.jsdt.web.ui.views.contentoutline.JFaceNodeAdapterForJs.getLabelImage(JFaceNodeAdapterForJs.java:310)
	at org.eclipse.wst.xml.ui.internal.contentoutline.JFaceNodeLabelProvider.getImage(JFaceNodeLabelProvider.java:56)
	at org.eclipse.wst.sse.ui.StructuredTextEditor.updateStatusLine(StructuredTextEditor.java:3412)
	at org.eclipse.wst.sse.ui.StructuredTextEditor$10.selectionChanged(StructuredTextEditor.java:2249)
	at org.eclipse.wst.sse.ui.StructuredTextEditor$4.run(StructuredTextEditor.java:583)
	at org.eclipse.wst.sse.ui.StructuredTextEditor$StructuredSelectionProvider.fireSelectionChanged(StructuredTextEditor.java:581)
	at org.eclipse.wst.sse.ui.StructuredTextEditor$StructuredSelectionProvider.handlePostSelectionChanged(StructuredTextEditor.java:662)
	at org.eclipse.wst.sse.ui.StructuredTextEditor$3.selectionChanged(StructuredTextEditor.java:555)
	at org.eclipse.jface.text.TextViewer.firePostSelectionChanged(TextViewer.java:2745)
	at org.eclipse.jface.text.TextViewer.firePostSelectionChanged(TextViewer.java:2693)
	at org.eclipse.jface.text.TextViewer$5.run(TextViewer.java:2672)
	at org.eclipse.swt.widgets.Display.runTimer(Display.java:4167)
!SESSION Wed Dec 11 22:27:53 IST 2013 ------------------------------------------
!ENTRY org.eclipse.equinox.launcher 4 0 2013-12-11 22:27:53.900
!MESSAGE Exception launching the Eclipse Platform:
!STACK
Re: Eclipse crashes [message #1220493 is a reply to message #1220342] Thu, 12 December 2013 03:16 Go to previous message
Since there is
You need to increase the memory size of PermSize in eclipse.ini
>--launcher.XXMaxPermSize
>256m
I'm not sure whether default 256M is not enough for your usage, though.
BTW,
It(Helios) is too old.
memo:
FAQ How do I increase the permgen size available to Eclipse? - Eclipsepedia
Bug 319514 [launcher] VM argument in eclipse.ini not take in account with java 1.6u21
Previous Topic:Missing PHP Debug Persepective/Preferences with Eclipse Juno 4.2.1 and PDT 3.1.1
Next Topic:PHP formatter inserts unwanted whitespace in web pages
Current Time: Sun Jul 20 05:29:32 EDT 2025
Powered by FUDForum. Page generated in 0.08354 seconds
