Home » Eclipse Projects » Eclipse Scout » How To add Tabs to TabBox programmatically (Adding Tabs to TabBox)
How To add Tabs to TabBox programmatically [message #1219751] Thu, 05 December 2013 10:57 Go to next message
Hi!
I have a SplitBox with a TreeField on the left and a TabBox on the right.
I would like to add tabs to the TabBox as soon as the user double-clicks on the nodes of the tree (or open an already existing tab, for that matter)
How can this be achieved?
Thanx!
Uwe
Re: How To add Tabs to TabBox programmatically [message #1220267 is a reply to message #1219751] Tue, 10 December 2013 13:20 Go to previous messageGo to next message
A typical approach with scout would be to hide and display the tabs...
The UI in Eclipse Scout is near to a declarative approach (e.g. you know all your UI elements when the form is loaded). You have a representation of your form that is instantiated when the form is opened and rendered in one of the UI. Because this approach was too restrictive, we have introduced new possibilities (like field injection) to provide more flexibility. For some use cases this is not enough...
I am not sure to understand what your use case is; it is difficult to tell what the possibilities are...
Re: How To add Tabs to TabBox programmatically [message #1220534 is a reply to message #1220267] Thu, 12 December 2013 07:04 Go to previous message
My use case is similar to Eclipse, when you click on a file in the Explorer, it opens up a new Editor Tab.
Likewise, I would like to add new Tabs to my TabBox when the user clicks on some nodes in my TreeField.
TreeField and TabBox live togheter in a SplitBox.
Previous Topic:Groovy support?
Next Topic:AbstractDoubleColumn: rounding decimal values
Current Time: Sun Jul 20 16:45:15 EDT 2025
Powered by FUDForum. Page generated in 0.03665 seconds
