[EMFStore] handling dangling references [message #1220263] |
Tue, 10 December 2013 12:42  |
Occasionally some application coding change I make will introduce a
dangling reference in my model that shows up during an EMFStore local
save operation as an DanglingHREFException.
Since my testing doesn't find every case where a dangling reference
could be introduced, I'd like the application to be resilient to this
problem and still be able to save, but log the problem so I can fix it
later. An example stack trace is below.
Is it possible to customize the way EMFStore processes dangling
references? Here are the EMF options I'm familiar with:
String OPTION_PROCESS_DANGLING_HREF = "PROCESS_DANGLING_HREF";
String OPTION_PROCESS_DANGLING_HREF_THROW = "THROW";
String OPTION_PROCESS_DANGLING_HREF_DISCARD = "DISCARD";
String OPTION_PROCESS_DANGLING_HREF_RECORD = "RECORD";
Example stack trace:
!ENTRY org.eclipse.emf.emfstore.client 4 0 2013-12-10 11:36:45.716
!MESSAGE
file:/C:/projects/regatta-workbench/eclipse-4.3.1/eclipse/temp/emfstore-results-manager/profiles/default_dev/ps-_0fMuwGD7EeO-mNE_prK-yw/operations.eoc
The object
'com.humanfactor.rw.model.regatta.impl.SplitResultImpl@2893fe74
(bowNumber: 977, time: null, comments: null, status: eligible,
approvalStatus: candidate, captureStatus: expected)' is not contained in
a resource.
org.eclipse.emf.ecore.xmi.DanglingHREFException: The object
a resource.
at
org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.handleDanglingHREF(XMLHelperImpl.java:754)
at
org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.getHREF(XMLHelperImpl.java:788)
at
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveEObjectSingle(XMLSaveImpl.java:1880)
at
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveFeatures(XMLSaveImpl.java:1319)
at
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveFeatures(XMLSaveImpl.java:1219)
at
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveElementID(XMLSaveImpl.java:2711)
at
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveElement(XMLSaveImpl.java:1176)
at
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveElement(XMLSaveImpl.java:1037)
at
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveContainedMany(XMLSaveImpl.java:2412)
at
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveFeatures(XMLSaveImpl.java:1548)
at
at
at
at
at
at
at
at
at
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.writeTopObject(XMLSaveImpl.java:678)
at
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.traverse(XMLSaveImpl.java:586)
at
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.save(XMLSaveImpl.java:251)
at
org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doSave(XMLResourceImpl.java:365)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(ResourceImpl.java:1430)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(ResourceImpl.java:999)
at
org.eclipse.emf.emfstore.internal.common.model.util.ModelUtil.saveResource(ModelUtil.java:427)
at
org.eclipse.emf.emfstore.internal.client.model.impl.ResourcePersister.saveDirtyResources(ResourcePersister.java:169)
at
org.eclipse.emf.emfstore.internal.client.model.impl.ResourcePersister.inspectChanges(ResourcePersister.java:313)
at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at
org.eclipse.emf.emfstore.internal.common.observer.ObserverBus$ProxyHandler.notifiyObservers(ObserverBus.java:274)
at
org.eclipse.emf.emfstore.internal.common.observer.ObserverBus$ProxyHandler.invoke(ObserverBus.java:260)
at com.sun.proxy.$Proxy16.inspectChanges(Unknown Source)
at
org.eclipse.emf.emfstore.internal.client.model.controller.UpdateController.doUpdate(UpdateController.java:147)
at
org.eclipse.emf.emfstore.internal.client.model.controller.UpdateController.run(UpdateController.java:93)
at
org.eclipse.emf.emfstore.internal.client.model.controller.UpdateController.run(UpdateController.java:1)
at
org.eclipse.emf.emfstore.internal.client.model.connectionmanager.ServerCall.run(ServerCall.java:249)
at
org.eclipse.emf.emfstore.internal.client.model.connectionmanager.SessionManager.executeCall(SessionManager.java:120)
at
org.eclipse.emf.emfstore.internal.client.model.connectionmanager.SessionManager.execute(SessionManager.java:61)
at
org.eclipse.emf.emfstore.internal.client.model.connectionmanager.ServerCall.execute(ServerCall.java:269)
at
org.eclipse.emf.emfstore.internal.client.model.impl.ProjectSpaceBase.update(ProjectSpaceBase.java:1263)
at
org.eclipse.emf.emfstore.internal.client.model.impl.api.ESLocalProjectImpl$12.call(ESLocalProjectImpl.java:475)
at
org.eclipse.emf.emfstore.internal.client.model.impl.api.ESLocalProjectImpl$12.call(ESLocalProjectImpl.java:1)
at
org.eclipse.emf.emfstore.client.util.RunESCommand$WithException$1.doRun(RunESCommand.java:60)
at
org.eclipse.emf.emfstore.internal.client.model.util.EMFStoreCommandWithResult.commandBody(EMFStoreCommandWithResult.java:31)
at
org.eclipse.emf.emfstore.internal.client.model.util.AbstractEMFStoreCommand.execute(AbstractEMFStoreCommand.java:64)
at
org.eclipse.emf.common.command.BasicCommandStack.execute(BasicCommandStack.java:78)
at
org.eclipse.emf.emfstore.internal.client.model.changeTracking.commands.EMFStoreBasicCommandStack.execute(EMFStoreBasicCommandStack.java:70)
at
org.eclipse.emf.emfstore.internal.client.model.util.AbstractEMFStoreCommand.aRun(AbstractEMFStoreCommand.java:108)
at
org.eclipse.emf.emfstore.internal.client.model.util.EMFStoreCommandWithResult.run(EMFStoreCommandWithResult.java:59)
at
org.eclipse.emf.emfstore.client.util.RunESCommand$WithException.runWithResult(RunESCommand.java:77)
at
org.eclipse.emf.emfstore.internal.client.model.impl.api.ESLocalProjectImpl.update(ESLocalProjectImpl.java:472)
at
org.eclipse.emf.emfstore.internal.client.ui.controller.UIUpdateProjectController.doRun(UIUpdateProjectController.java:213)
at
org.eclipse.emf.emfstore.internal.client.ui.controller.UIUpdateProjectController.doRun(UIUpdateProjectController.java:1)
at
org.eclipse.emf.emfstore.internal.client.ui.common.MonitoredEMFStoreAction$1.run(MonitoredEMFStoreAction.java:70)
at
org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:121)
Re: [EMFStore] handling dangling references [message #1220517 is a reply to message #1220263] |
Thu, 12 December 2013 05:10  |
Hi Scott,
yes, you are able to ignore DanglingHREFExceptions by using the
org.eclipse.emf.emfstore.common.discardDanglingHREFs extension point and
set its value to 'true'. If you ignore DanlingHREFs, EMFStore will log them.
Note that this extension point may be used for the client as well as for
the server.
Hope this helps.
Edgar
Am 10.12.2013 18:42, schrieb scott@xxxxxxxx:
> !MESSAGE
> The object
> a resource.
> a resource.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.lang.reflect.Method.invoke(Method.java:597)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Edgar Mueller
Get Professional Eclipse Support: http://eclipsesource.com/munich
FUDForum. Page generated in 0.03673 seconds
