Home » Newcomers » Newcomers » java was started but returned exit code = 2 (I tried opening the Eclipse Indigo and this pops up)
java was started but returned exit code = 2 [message #1220251] Tue, 10 December 2013 10:56 Go to next message
index.php/fa/16983/0/
What happened before this is that I was trying to run some java tool.
And, I issued the java - version and set classpath command in a particular folder which may have caused this.
Any help is appreciated!
Re: java was started but returned exit code = 2 [message #1220286 is a reply to message #1220251] Tue, 10 December 2013 15:42 Go to previous message
Have you ever installed Java on this system? If so, try launching Eclipse from a command line window with the -vm switch directing it to the real java.exe, which should be somewhere other than under the Windows directory. If not, get the latest 32-bit Java and make sure you update to at least Indigo SR2.
Previous Topic:call plsqlstoredfunctioncall with nested table type
Next Topic:Debug error on eclipse
Current Time: Sat Jul 19 09:35:45 EDT 2025
Powered by FUDForum. Page generated in 0.08224 seconds
