Home » Modeling » TMF (Xtext) » DSL Formatter does not execute(xtext formatter)
DSL Formatter does not execute [message #1219614] Wed, 04 December 2013 17:44 Go to next message
Hoping for some help with what I believe is a basic problem.
I have a DSL (we'll call it MyDsl), the plugin and generator for which work perfectly. However, some of the methods that are called by the generator cause line breaks to occur in bad spots, such as:
private int
  someField;
I have assumed that the best way to remove these lines breaks is through the MyDslFormatter.xtend::configureFormatting method. Something like
c.setNoLinewrap().after(ga.getFieldValueRule())
However, even a basic
c.setAutoLinewrap(20)
has no effect on the code which is produced by the generator.
A breakpoint in the MyDslFormatter.java class never gets hit.
What am I missing? Do I need to add something to a config file to cause my formatter to get picked up during the modeling workflow process?
Re: DSL Formatter does not execute [message #1219631 is a reply to message #1219614] Thu, 05 December 2013 00:57 Go to previous message
Hi the formatter is for formatting DSL files (if you call it in the
editor or call the serializer ) and not for your igenerator
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext at itemis dot de
Previous Topic:Problem while exporting eclipse product
Next Topic:Error method or field is undefined for the type xxx
Current Time: Sun Jul 20 06:25:32 EDT 2025
Powered by FUDForum. Page generated in 0.03430 seconds
