Home » Modeling » EMF » Prevent elements to be moved from one container to another
Prevent elements to be moved from one container to another [message #1219535] |
Wed, 04 December 2013 08:31  |
In my model, I have containment references. E.g.
class A {
contains B[] bs
class B{}
Now I want to prevent Bs to be (accidentally) moved from one container
to another. It should be possible to add and remove bs from a, but not
to move an B instance from one container to another.
This should be possible by slightly enhancing the model, e.g.
abstract class NonMoveableElement{}
class B extends NonMoveableElement{}
and by providing a custom implementation for NonMoveableElement, overriding
org.eclipse.emf.ecore.impl.MinimalEObjectImpl.eBasicSetContainer(InternalEObject)
(with a version throwing an exception if there is a container and if it
is changed (and not set to null)).
However, this custom class may be without effect in case of a more
complicated model with multi-inheritance. Besides, I would assume that
this is a common problem, so there might be a general more "model"-like
solution for that (e.g., an annotation). Is there such as solution?
Jens
PS: I'm aware of the nice utility class EcoreUtil.copy, and even better
EcoreUtil2.cloneIfContained (an Xtext utility class), which can be used
to prevent the situation in the first place. Unfortunately, one
sometimes forget to use these nice methods...
Re: Prevent elements to be moved from one container to another [message #1219540 is a reply to message #1219535] |
Wed, 04 December 2013 09:06   |
Jens,
Comments below.
On 04/12/2013 2:31 PM, Jens v.P. wrote:
> class A {
> contains B[] bs
> class B{}
> to another.
When might this accident happen. The user in the editor? Or the
developer using the API?
> It should be possible to add and remove bs from a, but not to move an
That sounds tricky. After all, this don't necessarily happen with just
a single "operation". In the editor you could use Cut and then Paste,
in the API you can do a remove followed by an add.
> overriding
That sounds frightening.
> it is changed (and not set to null)).
And again, you're likely to find the container is set to null and then
later set to something else...
No, it seems a bit fishy...
> so there might be a general more "model"-like solution for that (e.g.,
No, I'm not sure how it's really sensible given that the fine grained
transitions, add/remove are to be allowed, and there isn't generally a
higher level transition of "move"...
> Regards,
> Jens
> better EcoreUtil2.cloneIfContained (an Xtext utility class), which can
> be used to prevent the situation in the first place. Unfortunately,
> one sometimes forget to use these nice methods...
Are you just trying to find bugs? Perhaps there are objects you want
to make "read-only" to find bugs? One approach for that is to attach an
EContentAdapter that throws exceptions for any notifyChanged calls...
Re: Prevent elements to be moved from one container to another [message #1219546 is a reply to message #1219540] |
Wed, 04 December 2013 09:51   |
Ed,
Actually, yes, I "only" try to find bugs ;-)
I probably didn't explained the context: it's Xtext. And the element I
want to be restricted from being moved are elements serving as (type)
references. This is a (simplified) snippet of my grammar and model:
VarDecl: typeRef=TypeRef varName=ID
TypeRef: declaredType=[Type|ID]
So, this is my model:
class VarDecl {
contains TypeRef typeRef
String name
class TypeRef {
references Type
class Type {
String name
A typeref must never be moved from one variable to another. This could
easily happen by accident, e.g., during type inference or binding.
In general, adding content adapters might be a good solution. But in
this specific case, in which there are literally thousands of TypeRef
instances, I would prefer to have a class based solution.
But I agree of course, my case seems quite special. Actually, before we
decided to use EMF for modeling our type model, we were already worried
about this containment problem with regard to type references...
On 04.12.13 15:06, Ed Merks wrote:
>> overriding
Hehe... maybe I will give it a try, just for finding bugs and for
writing a little horror story :-D
Current Time: Sat Jul 19 08:32:09 EDT 2025
Powered by FUDForum. Page generated in 0.07195 seconds
