Detecting project "move" [message #120593] |
Tue, 02 September 2003 14:26  |
We have our product specific files in Eclipse project directory. When
Eclipse project is renamed or moved, we need to take care of our own
files. Simple file copy is not sufficient. When Eclipse project is
renamed, I noticed I get POST_CHANGE event with ADDED delta and REMOVED
delta, as well as PRE_DELETE event. It is sufficient for me to do what I
need to do. However, when project is "moved", the only event I see is
POST_CHANGE event with CHANGED delta. It would be OK, if I can figure out
the "before" and "after" locations of the project. I tried the following
code:
IResourceDelta[] changedDeltas =
event.getDelta().getAffectedChildren(IResourceDelta.CHANGED) ;
if (changedDeltas[0].getResource().getType() == IResource.PROJECT) {
IPath from = changedDeltas[0].getMovedFromPath();
IPath to = changedDeltas[0].getMovedToPath();
In the above code, both 'from' and 'to' are null's. What would be the
proper way to obtain the "before" and "after" locations of the project
when it is moved by user?
Thanks in advance,
JK
Re: Detecting project "move" [message #121808 is a reply to message #120593] |
Wed, 03 September 2003 06:12   |
You can use the MOVED_FROM and MOVED_TO flags, e.g.
if (changedDeltas[0].getFlags() & IResourceDelta.MOVED_FROM) != 0) {
Jerome
"JK Lah" <jk.lah@intel.com> wrote in message
news:bj2nbo$fk7$1@eclipse.org...
> code:
> Thanks in advance,
> JK
Re: Detecting project "move" [message #122263 is a reply to message #121808] |
Wed, 03 September 2003 13:03   |
Thanks for the reply. However, the value of changedDeltas[0].getFlags()
is 0x80000 which is DESCRIPTION. I don't receive any other event when I
move project. I am using Eclipse 2.1.1 on Windows. Is there something I
am missing?
JK
> Jerome
> > code:
> > Thanks in advance,
> > JK
Re: Detecting project "move" [message #122565 is a reply to message #122263] |
Thu, 04 September 2003 05:48  |
I just looked at the IResource.move(...) methods and it looks like you can
rename a project only by changing its description.Unfortunately I don't
think you can get the previous description (as you can get the MovedFromPath
for other resources).
You should enter a feature request (against Platform/Core).
Jerome
news:bj56ss$v7k$1@eclipse.org...
> am missing?
> JK
> > Jerome
REMOVED
what I
out
following
> > > code:
> > > Thanks in advance,
> > > JK
FUDForum. Page generated in 0.05957 seconds
