Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Texo] Unset value/Update query
[Texo] Unset value/Update query [message #1200807] Thu, 21 November 2013 07:22 Go to next message
Hi Martin,
I've got a problem while unsetting a value. I want to set a double value (in EMF EDoubleObject, in DB double) to null. This works as long as I don't save the resource. Then the value gets reverted to the originally set value.
To avoid this, I created an update query on the resource to set the attribute null. But I got this exception:
java.lang.IllegalStateException: You cannot call getResultList() on this query.  It is the incorrect query type.
Of course, this makes sense. Is there any possibility to unset this value, either by unsetting it directly or by executing a query?
Best regards
Bastian
Re: [Texo] Unset value/Update query [message #1200978 is a reply to message #1200807] Thu, 21 November 2013 09:08 Go to previous messageGo to next message
Hi Bastian,
Is the value set back to the original value by Texo on the server side or by EMF on the client side?
There is special EMF behavior that if you set an efeature to null it will return its default value when doing eGet
(which Texo does). So then the default value gets saved on the server. It should work fine as you have EDoubleObject
which should support nulls, but still, can you check?
One other thing which can happen is that Texo on the client side thinks that the value is not set and does not send
anything to the server. So the json send to the server does not contain the changed efeature. Can you check that?
gr. Martin
On 11/21/2013 01:22 PM, Bastian Wagenfeld wrote:
> Hi Martin,
> executing a query?
> Best regards
> Bastian
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: [Texo] Unset value/Update query [message #1202488 is a reply to message #1200978] Fri, 22 November 2013 01:57 Go to previous messageGo to next message
Hi Martin,
it is almost like you supposed at last: The changed object is added to the "eObjectsToUpdate" list. At this place the attribute is null. But the json-String on the server side does not even contain the attribute, neither the attribute nor its value (null).
Best regards
Bastian
Re: [Texo] Unset value/Update query [message #1202555 is a reply to message #1202488] Fri, 22 November 2013 02:42 Go to previous messageGo to next message
Hi Bastian,
Ok, but looking at the code it should do it, can you debug into the BaseModelJSONConverter in the
convertSingleEAttribute method. There the value is retrieved from the EMF object and put in the jsonobject.
Does it get there in your case for this eattribute?
gr. Martin
On 11/22/2013 07:57 AM, Bastian Wagenfeld wrote:
> Hi Martin,
> its value (null).
> Best regards
> Bastian
The Netherlands
Re: [Texo] Unset value/Update query [message #1202660 is a reply to message #1202555] Fri, 22 November 2013 03:53 Go to previous messageGo to next message
the value is null and the propName is set correctly. The toJSON method of the JSONValueConverter returns null since none of the conditions is true. So the put method of the JSONObject is invoked with the correct key and null. The JSONObject code looks like that:
 public JSONObject put(String key, Object value) throws JSONException {
        if (key == null) {
            throw new NullPointerException("Null key.");
        if (value != null) {
            testValidity(value);
            this.map.put(key, value);
        } else {
            this.remove(key);
        return this;
The value is null, so this.remove(key) is called.
Is there a possibility to avoid this?
Bastian
Re: [Texo] Unset value/Update query [message #1202710 is a reply to message #1202660] Fri, 22 November 2013 04:24 Go to previous messageGo to next message
Ha, yes I think so, there is a JSONObject.NULL which I guess I can use.
Will try that.
gr. Martin
On 11/22/2013 09:53 AM, Bastian Wagenfeld wrote:
> if (key == null) {
> } else {
> this.remove(key);
> return this;
> Bastian
The Netherlands
Re: [Texo] Unset value/Update query [message #1205611 is a reply to message #1202710] Sat, 23 November 2013 13:19 Go to previous messageGo to next message
Hi Bastian,
I published a new build which should solve this.
gr. Martin
> Will try that.
> gr. Martin
>> Hi,
>> if (key == null) {
>> } else {
>> this.remove(key);
>> return this;
>> Bastian
The Netherlands
Re: [Texo] Unset value/Update query [message #1209199 is a reply to message #1205611] Mon, 25 November 2013 06:40 Go to previous message
Hi Martin,
that fixed it. Thank you!
Bastian
Previous Topic:EMFStore stand-alone client api
Next Topic:[CDO] [Teneo] Default enum value persisted as NULL
Current Time: Sat Jul 19 14:05:13 EDT 2025
Powered by FUDForum. Page generated in 0.05790 seconds
