Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [Teneo] Problem with StringToStringMap and @Lob @Column Annotation
[Teneo] Problem with StringToStringMap and @Lob @Column Annotation [message #117298] |
Tue, 08 April 2008 16:09  |
Originally posted by: schlamp.medihack.org
Hello.
I have a little problem when persisting an EMF StringToStringMap with
Teneo/Hibernate.
I defined the map as stated at
http://wiki.eclipse.org/EMF/FAQ#How_do_I_create_a_Map_in_EMF .3F
Everything works fine, but when I add the teneo.jpa annotation @Lob
@Column(length=100000) for the "value" field of the map, Teneo doesn't
create the table for this map anymore.
The above annotation works as exspected when used for other EMF class
fields (the table is created correctly and Derby uses CLOB instead of
VARCHAR). Only a StringToStringMap resp. any map has the problem not
accepting this annotation.
Another thing ... the naming scheme for maps seems to be a bit other than
for usual EMF objects.
Let's presume the model looks like below:
Document
|-properties:StringToStringMap
|-type:DocumentType (a ref to another EMF class)
|-content:String
Then Teneo/Hibernate creates the following tables (without specifying any
special naming via "@Column"): document, PROPERTIES, documenttype,
documentcontent.
Is there a reason why Hibernate names properties upper case and without
"document"?
Kai
Re: [Teneo] Problem with StringToStringMap and @Lob @Column Annotation [message #117312 is a reply to message #117298] |
Tue, 08 April 2008 17:15   |
Hi Kai,
What exception do you get when trying out the lob and column annotation on the value member of the emap?
Can you post a small test model then I can try out what happens here? I checked the emap testcases I
have and they work fine. However, the current test case does not contain the @Lob and @Column
annotation for the value side.
Do you set any options when initializing the datastore?
gr. Martin
Kai Schlamp wrote:
> Hello.
> Teneo/Hibernate.
> than for usual EMF objects.
> Document
> |-content:String
> any special naming via "@Column"): document, PROPERTIES, documenttype,
> documentcontent.
> "document"?
> Best regards,
> Kai
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] Problem with StringToStringMap and @Lob @Column Annotation [message #117708 is a reply to message #117312] |
Thu, 10 April 2008 17:18   |
Hy, Martin.
My intention is to store large strings (up to one million characters).
Without specifying the @Lob and @Column(length=1000000) annotation for a
string attribute Teneo/Hibernate creates a VARCHAR length=255 database
field. This is a known problem with Derby, so the @Lob and @Column is a
workaround. With the help of those annotations, Hibernate creates CLOB
fields for those annotated string attributes. (See
http://opensource.atlassian.com/projects/hibernate/browse/HH H-2614)
@Lob and @Column
Below my posting is the ecore and genmodel. It is a very simple test model
with only two classes. I use the @Lob and @Column annotation direct on a
string property and that works fine, Teneo/Hibernate creates a CLOB field
for this class attribute.
I also use the same annotation on the value attribute of the
StringToStringMap, but this time Teneo/Hibernate does simply not create
the appropriate table. When deleting the annotation of the value
attribute, the table for the map is created, but the value field is only
VARCHAR length=255 (as exspected).
Nothing special:
hibernateProperties.setProperty(Environment.USER, username);
hibernateProperties.setProperty(Environment.PASS, password);
hibernateProperties.setProperty(Environment.DRIVER, driver);
hibernateProperties.setProperty(Environment.URL, url);
hibernateProperties.setProperty(Environment.DIALECT, dialect);
Thanks for the help,
Kai
Ecore ------------------------------------------------------------ -
<ecore:EPackage xmi:version="2.0"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="testmodel"
nsURI="http://www.pubcurator.org/tester/testmodel"
nsPrefix="org.pubcurator.tester.testmodel">
<eClassifiers xsi:type="ecore:EClass" name="TestElement">
<eStructuralFeatures xsi:type="ecore:EReference" name="testMap"
upperBound="-1"
eType="#//StringToStringMap" containment="true"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="testProp"
eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString">
<eAnnotations source="teneo.jpa">
<details key="value" value="@Lob
@Column(length=1000000)"/>
</eAnnotations>
</eStructuralFeatures>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="StringToStringMap"
instanceClassName="java.util.Map$Entry">
<eStructuralFeatures xsi:type="ecore:EAttribute" name="key"
eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="value"
</eAnnotations>
</eClassifiers>
</ecore:EPackage>
Genmodel ----------------------------------------
<genmodel:GenModel xmi:version="2.0"
xmlns:genmodel="http://www.eclipse.org/emf/2002/GenModel"
modelDirectory="/org.pubcurator.tester.testmodel/src"
modelPluginID="org.pubcurator.tester.testmodel" modelName="Testmodel"
importerID="org.eclipse.emf.importer.ecore"
complianceLevel="6.0" copyrightFields="false">
<foreignModel>testmodel.ecore</foreignModel>
<genPackages prefix="TestModel" basePackage="org.pubcurator.tester"
disposableProviderFactory="true"
ecorePackage="testmodel.ecore#/">
<genClasses ecoreClass="testmodel.ecore#//TestElement">
<genFeatures property="None" children="true" createChild="true"
ecoreFeature="ecore:EReference testmodel.ecore#//TestElement/testMap"/>
<genFeatures createChild="false" ecoreFeature="ecore:EAttribute
testmodel.ecore#//TestElement/testProp"/>
</genClasses>
<genClasses ecoreClass="testmodel.ecore#//StringToStringMap">
testmodel.ecore#//StringToStringMap/key"/>
testmodel.ecore#//StringToStringMap/value"/>
</genClasses>
</genPackages>
</genmodel:GenModel>
Re: [Teneo] Problem with StringToStringMap and @Lob @Column Annotation [message #117734 is a reply to message #117708] |
Thu, 10 April 2008 23:13   |
Hi Kai,
I tested your ecore model and with me (and mysql) it seems to work fine, I get a mediumtext column.
The bibernatemapping also seems correct to me:
<map name="testMap" lazy="true" cascade="all,delete-orphan">
<key update="true">
<column name="`testelement_testmap_e_id`" not-null="false" unique="false"/>
</key>
<map-key type="java.lang.String"/>
<element type="text" not-null="false" unique="false">
<column not-null="false" unique="false" name="`value`" length="1000000"/>
</element>
</map>
Can you enable hibernate logging and check why the table is not created? My experience with
hibernate-mysql is that eventhough tables don't get created hibernate still continues, the sql error
is then displayed in the log.
gr. Martin
Kai Schlamp wrote:
> Hy, Martin.
>> annotation on
>> contain the
> @Lob and @Column
> model with only two classes. I use the @Lob and @Column annotation
> direct on a string property and that works fine, Teneo/Hibernate creates
> a CLOB field for this class attribute.
> Nothing special:
> Kai
> xmlns:xmi="http://www.omg.org/XMI"
> upperBound="-1"
> </eAnnotations>
> </eClassifiers>
> </eAnnotations>
> </eClassifiers>
> </ecore:EPackage>
> </genClasses>
> </genClasses>
> </genPackages>
The Netherlands
Re: [Teneo] Problem with StringToStringMap and @Lob @Column Annotation [message #120498 is a reply to message #117734] |
Mon, 28 April 2008 17:39   |
Hello Martin,
sorry for the late reply ... I needed a little off time (for skiing and
fetching some sun :-)).
I tried to enable hibernate logging, but I can't get it to work :-(
I copied the log4j.properties file
(http://www.elver.org/hibernate/samples/log4j.properties) directly to the
src folder of my EMF model plugin. I also added log4j.properties to
bin.includes and src.includes of the build.properties.
I also tried to directly add org.apache.log4j as dependency for the emf
model plugin.
But no hibernate stuff appears on the console, nor on the "Error Log".
What else do I have to do? Add something to the source code?
Kai
Martin Taal wrote:
> Hi Kai,
> <key update="true">
> </key>
> </element>
> </map>
experience with
> gr. Martin
> Kai Schlamp wrote:
>> Hy, Martin.
>>> annotation on
>>> contain the
>> @Lob and @Column
>> Nothing special:
>> Kai
>> <?xml version="1.0" encoding="UTF-8"?>
>> upperBound="-1"
>> </eAnnotations>
>> </eClassifiers>
>> </eAnnotations>
>> </eClassifiers>
>> </ecore:EPackage>
>> </genClasses>
>> </genClasses>
>> </genPackages>
Re: [Teneo] Problem with StringToStringMap and @Lob @Column Annotation [message #120640 is a reply to message #120498] |
Tue, 29 April 2008 13:59   |
Hi Kai,
How do you run the program? I also find it difficult to get log4j working when running programs as
plugins within Eclipse. However when I run programs through static main methods or junit then log4j
output shows up.
I would also check the output folder (bin) to see if the log4j.properties is actually copied there.
gr. Martin
Kai Schlamp wrote:
> Hello Martin,
> the src folder of my EMF model plugin. I also added log4j.properties to
> model plugin.
> Best regards,
> Kai
> Martin Taal wrote:
>> Hi Kai,
>> fine, I
>> <key update="true">
>> unique="false"/>
>> </key>
>> length="1000000"/>
>> </element>
>> </map>
>> created? My
> experience with
>> still
>> gr. Martin
>> Kai Schlamp wrote:
>>> Hy, Martin.
>>>> annotation on
>>> characters). Without specifying the @Lob and @Column(length=1000000)
>>> annotation for a string attribute Teneo/Hibernate creates a VARCHAR
>>> length=255 database field. This is a known problem with Derby, so the
>>> @Lob and @Column is a workaround. With the help of those annotations,
>>> Hibernate creates CLOB fields for those annotated string attributes.
>>> (See http://opensource.atlassian.com/projects/hibernate/browse/HH H-2614)
>>>> contain the
>>> @Lob and @Column
>>> creates a CLOB field for this class attribute.
>>> create the appropriate table. When deleting the annotation of the
>>> value attribute, the table for the map is created, but the value
>>> field is only VARCHAR length=255 (as exspected).
>>> Nothing special:
>>> Kai
>>> upperBound="-1"
>>> </eAnnotations>
>>> </eClassifiers>
>>> </eAnnotations>
>>> </eClassifiers>
>>> </ecore:EPackage>
>>> modelName="Testmodel" importerID="org.eclipse.emf.importer.ecore"
>>> </genClasses>
>>> </genClasses>
>>> </genPackages>
The Netherlands
Re: [Teneo] Problem with StringToStringMap and @Lob @Column Annotation [message #121574 is a reply to message #120640] |
Wed, 30 April 2008 17:07   |
Hy Martin,
I managed getting log4j hibernate to work. I simply copied your
log4j.properties file as hibernate-log4j.properties in the
org.hibernate.eclipse_3.2.1.GA directory of the Eclipse hibernate plugin
(I use the plugin from here: http://www.hibernate.org/255.html).
Now everything is logged to the console, even if I run my application as
plugin within Eclipse (perhaps a good entry for your FAQ).
Ok, back to my main problem ... here is the interesting part from the log:
5053 [main] DEBUG org.hibernate.tool.hbm2ddl.SchemaUpdate - create table
properties ("document_properties_id" bigint, "value" varchar(1000000), idx
varchar(255) not null, primary key ("document_properties_id", idx))
5081 [main] ERROR org.hibernate.tool.hbm2ddl.SchemaUpdate - Unsuccessful:
create table properties ("document_properties_id" bigint, "value"
varchar(1000000), idx varchar(255) not null, primary key
5081 [main] ERROR org.hibernate.tool.hbm2ddl.SchemaUpdate - The length,
precision, or scale attribute for column, or type mapping
'VARCHAR(1000000)' is not valid.
As I stated in a previous post, "properties" is a attribute of "Document"
and is of type "StringToStringMap".
The "StringToStringMap" has a "key" and a "value" (both Strings).
"value" is annotated (the teneo.jpa way) with:
@Lob
I would expect, that Hibernate uses not a VARCHAR, but a CLOB. It does
this correctly when adding the above annotation to an other attribute not
of a map type (e.g. a String attribute named "longtext" of "Document").
But it seems a bit that this this is a bug of hbm2ddl together with the
Derby dialect.
As I am already thinking about switching to HSQL, I hope that this won't
be a problem anymore then. I keep you updated, when I have done the switch.
I also have another little problem with bulk cascade delete, but I will
open a new thread for this.
Kai
Martin Taal wrote:
> Hi Kai,
> output shows up.
> gr. Martin
> Kai Schlamp wrote:
>> Hello Martin,
>> model plugin.
>> Best regards,
>> Kai
>> Martin Taal wrote:
>>> Hi Kai,
>>> fine, I
>>> <key update="true">
>>> unique="false"/>
>>> </key>
>>> length="1000000"/>
>>> </element>
>>> </map>
>>> created? My
>> experience with
>>> still
>>> gr. Martin
>>> Kai Schlamp wrote:
>>>> Hy, Martin.
>>>>> annotation on
>>>>> contain the
>>>> @Lob and @Column
>>>> Nothing special:
>>>> Kai
>>>> upperBound="-1"
>>>> </eAnnotations>
>>>> </eClassifiers>
>>>> </eAnnotations>
>>>> </eClassifiers>
>>>> </ecore:EPackage>
>>>> </genClasses>
>>>> </genClasses>
>>>> </genPackages>
Re: [Teneo] Problem with StringToStringMap and @Lob @Column Annotation [message #121611 is a reply to message #121574] |
Thu, 01 May 2008 08:25   |
Ok, I tested the behavior with H2 database. The same thing here.
With the same annotation @Lob @Column(length=1000000000) Hibernate's
hbm2ddl one time creates a clob column for a String attribute of a normal
class and a other time tries to create a varchar column for a String
attribute of a StringToStringMap.
I am not really sure why this happens, but I simply avoid this problem now
by creating special string attributes for long strings, that are not
stored inside a StringToStringMap.
Kai
Kai Schlamp wrote:
> Hy Martin,
> @Lob
> Derby dialect.
> Best regards,
> Kai
> Martin Taal wrote:
>> Hi Kai,
>> output shows up.
is
>> gr. Martin
>> Kai Schlamp wrote:
>>> Hello Martin,
>>> model plugin.
>>> Best regards,
>>> Kai
>>> Martin Taal wrote:
>>>> Hi Kai,
>>>> fine, I
>>>> <key update="true">
>>>> unique="false"/>
>>>> </key>
>>>> length="1000000"/>
>>>> </element>
>>>> </map>
>>>> created? My
>>> experience with
>>>> still
>>>> gr. Martin
>>>> Kai Schlamp wrote:
>>>>> Hy, Martin.
>>>>>> annotation on
>>>>>> contain the
>>>>> @Lob and @Column
>>>>> Nothing special:
>>>>> Kai
>>>>> upperBound="-1"
>>>>> </eAnnotations>
>>>>> </eClassifiers>
>>>>> </eAnnotations>
>>>>> </eClassifiers>
>>>>> </ecore:EPackage>
>>>>> </genClasses>
>>>>> </genClasses>
>>>>> </genPackages>
Re: [Teneo] Problem with StringToStringMap and @Lob @Column Annotation [message #121721 is a reply to message #121611] |
Fri, 02 May 2008 01:32  |
Hi Kai,
How does the hibernate mapping of the map look like? Does Teneo set a type="text"?
gr. Martin
> normal class and a other time tries to create a varchar column for a
> String attribute of a StringToStringMap.
> now by creating special string attributes for long strings, that are not
> Kai
> Kai Schlamp wrote:
>> Hy Martin,
>> plugin (I use the plugin from here: http://www.hibernate.org/255.html).
>> as plugin within Eclipse (perhaps a good entry for your FAQ).
>> log:
>> Unsuccessful: create table properties ("document_properties_id"
>> bigint, "value" varchar(1000000), idx varchar(255) not null, primary
>> length, precision, or scale attribute for column, or type mapping
>> "Document" and is of type "StringToStringMap".
>> @Lob
>> not of a map type (e.g. a String attribute named "longtext" of
>> "Document").
>> the Derby dialect.
>> won't be a problem anymore then. I keep you updated, when I have done
>> the switch.
>> will open a new thread for this.
>> Best regards,
>> Kai
>> Martin Taal wrote:
>>> Hi Kai,
>>> working
>>> output shows up.
>>> log4j.properties
> is
>>> gr. Martin
>>> Kai Schlamp wrote:
>>>> Hello Martin,
>>>> and fetching some sun :-)).
>>>> to the src folder of my EMF model plugin. I also added
>>>> log4j.properties to bin.includes and src.includes of the
>>>> build.properties.
>>>> emf model plugin.
>>>> Best regards,
>>>> Kai
>>>> Martin Taal wrote:
>>>>> Hi Kai,
>>>>> fine, I
>>>>> <key update="true">
>>>>> unique="false"/>
>>>>> </key>
>>>>> length="1000000"/>
>>>>> </element>
>>>>> </map>
>>>>> created? My
>>>> experience with
>>>>> hibernate still
>>>>> gr. Martin
>>>>> Kai Schlamp wrote:
>>>>>> Hy, Martin.
>>>>>>> annotation on
>>>>>> @Column(length=1000000) annotation for a string attribute
>>>>>> Teneo/Hibernate creates a VARCHAR length=255 database field. This
>>>>>> CLOB fields for those annotated string attributes. (See
>>>>>>> here? I
>>>>>>> contain the
>>>>>> @Lob and @Column
>>>>>> test model with only two classes. I use the @Lob and @Column
>>>>>> annotation direct on a string property and that works fine,
>>>>>> Teneo/Hibernate creates a CLOB field for this class attribute.
>>>>>> Nothing special:
>>>>>> Kai
>>>>>> name="testmodel"
>>>>>> upperBound="-1"
>>>>>> name="testProp" eType="ecore:EDataType
>>>>>> value="@Lob
>>>>>> </eAnnotations>
>>>>>> </eClassifiers>
>>>>>> value="@Lob
>>>>>> </eAnnotations>
>>>>>> </eClassifiers>
>>>>>> </ecore:EPackage>
>>>>>> basePackage="org.pubcurator.tester" disposableProviderFactory="true"
>>>>>> createChild="true" ecoreFeature="ecore:EReference
>>>>>> </genClasses>
>>>>>> </genClasses>
>>>>>> </genPackages>
The Netherlands
Re: [Teneo] Problem with StringToStringMap and @Lob @Column Annotation [message #616111 is a reply to message #117298] |
Hi Kai,
gr. Martin
Kai Schlamp wrote:
> Hello.
> Teneo/Hibernate.
> Document
> |-content:String
> documentcontent.
> "document"?
> Best regards,
> Kai
The Netherlands
Re: [Teneo] Problem with StringToStringMap and @Lob @Column Annotation [message #616190 is a reply to message #117312] |
Hy, Martin.
@Lob and @Column
Nothing special:
Kai
upperBound="-1"
</eAnnotations>
</eClassifiers>
</eAnnotations>
</eClassifiers>
</ecore:EPackage>
</genClasses>
</genClasses>
</genPackages>
Re: [Teneo] Problem with StringToStringMap and @Lob @Column Annotation [message #616194 is a reply to message #117708] |
Hi Kai,
<key update="true">
</key>
</element>
</map>
gr. Martin
Kai Schlamp wrote:
> Hy, Martin.
>> annotation on
>> contain the
> @Lob and @Column
> Nothing special:
> Kai
> upperBound="-1"
> </eAnnotations>
> </eClassifiers>
> </eAnnotations>
> </eClassifiers>
> </ecore:EPackage>
> </genClasses>
> </genClasses>
> </genPackages>
The Netherlands
Re: [Teneo] Problem with StringToStringMap and @Lob @Column Annotation [message #617944 is a reply to message #117734] |
Hello Martin,
model plugin.
Kai
Martin Taal wrote:
> Hi Kai,
> <key update="true">
> </key>
> </element>
> </map>
experience with
> gr. Martin
> Kai Schlamp wrote:
>> Hy, Martin.
>>> annotation on
>>> contain the
>> @Lob and @Column
>> Nothing special:
>> Kai
>> upperBound="-1"
>> </eAnnotations>
>> </eClassifiers>
>> </eAnnotations>
>> </eClassifiers>
>> </ecore:EPackage>
>> </genClasses>
>> </genClasses>
>> </genPackages>
Re: [Teneo] Problem with StringToStringMap and @Lob @Column Annotation [message #617954 is a reply to message #120498] |
Hi Kai,
output shows up.
gr. Martin
Kai Schlamp wrote:
> Hello Martin,
> model plugin.
> Best regards,
> Kai
> Martin Taal wrote:
>> Hi Kai,
>> fine, I
>> <key update="true">
>> unique="false"/>
>> </key>
>> length="1000000"/>
>> </element>
>> </map>
>> created? My
> experience with
>> still
>> gr. Martin
>> Kai Schlamp wrote:
>>> Hy, Martin.
>>>> annotation on
>>>> contain the
>>> @Lob and @Column
>>> Nothing special:
>>> Kai
>>> upperBound="-1"
>>> </eAnnotations>
>>> </eClassifiers>
>>> </eAnnotations>
>>> </eClassifiers>
>>> </ecore:EPackage>
>>> </genClasses>
>>> </genClasses>
>>> </genPackages>
The Netherlands
Re: [Teneo] Problem with StringToStringMap and @Lob @Column Annotation [message #617971 is a reply to message #120640] |
Hy Martin,
@Lob
Derby dialect.
Kai
Martin Taal wrote:
> Hi Kai,
> output shows up.
> gr. Martin
> Kai Schlamp wrote:
>> Hello Martin,
>> model plugin.
>> Best regards,
>> Kai
>> Martin Taal wrote:
>>> Hi Kai,
>>> fine, I
>>> <key update="true">
>>> unique="false"/>
>>> </key>
>>> length="1000000"/>
>>> </element>
>>> </map>
>>> created? My
>> experience with
>>> still
>>> gr. Martin
>>> Kai Schlamp wrote:
>>>> Hy, Martin.
>>>>> annotation on
>>>>> contain the
>>>> @Lob and @Column
>>>> Nothing special:
>>>> Kai
>>>> upperBound="-1"
>>>> </eAnnotations>
>>>> </eClassifiers>
>>>> </eAnnotations>
>>>> </eClassifiers>
>>>> </ecore:EPackage>
>>>> </genClasses>
>>>> </genClasses>
>>>> </genPackages>
Re: [Teneo] Problem with StringToStringMap and @Lob @Column Annotation [message #617974 is a reply to message #121574] |
Kai
Kai Schlamp wrote:
> Hy Martin,
> @Lob
> Derby dialect.
> Best regards,
> Kai
> Martin Taal wrote:
>> Hi Kai,
>> output shows up.
is
>> gr. Martin
>> Kai Schlamp wrote:
>>> Hello Martin,
>>> model plugin.
>>> Best regards,
>>> Kai
>>> Martin Taal wrote:
>>>> Hi Kai,
>>>> fine, I
>>>> <key update="true">
>>>> unique="false"/>
>>>> </key>
>>>> length="1000000"/>
>>>> </element>
>>>> </map>
>>>> created? My
>>> experience with
>>>> still
>>>> gr. Martin
>>>> Kai Schlamp wrote:
>>>>> Hy, Martin.
>>>>>> annotation on
>>>>>> contain the
>>>>> @Lob and @Column
>>>>> Nothing special:
>>>>> Kai
>>>>> upperBound="-1"
>>>>> </eAnnotations>
>>>>> </eClassifiers>
>>>>> </eAnnotations>
>>>>> </eClassifiers>
>>>>> </ecore:EPackage>
>>>>> </genClasses>
>>>>> </genClasses>
>>>>> </genPackages>
Re: [Teneo] Problem with StringToStringMap and @Lob @Column Annotation [message #617982 is a reply to message #121611] |
Hi Kai,
gr. Martin
> Kai
> Kai Schlamp wrote:
>> Hy Martin,
>> log:
>> @Lob
>> "Document").
>> the Derby dialect.
>> the switch.
>> Best regards,
>> Kai
>> Martin Taal wrote:
>>> Hi Kai,
>>> working
>>> output shows up.
>>> log4j.properties
> is
>>> gr. Martin
>>> Kai Schlamp wrote:
>>>> Hello Martin,
>>>> build.properties.
>>>> emf model plugin.
>>>> Best regards,
>>>> Kai
>>>> Martin Taal wrote:
>>>>> Hi Kai,
>>>>> fine, I
>>>>> <key update="true">
>>>>> unique="false"/>
>>>>> </key>
>>>>> length="1000000"/>
>>>>> </element>
>>>>> </map>
>>>>> created? My
>>>> experience with
>>>>> hibernate still
>>>>> gr. Martin
>>>>> Kai Schlamp wrote:
>>>>>> Hy, Martin.
>>>>>>> annotation on
>>>>>>> here? I
>>>>>>> contain the
>>>>>> @Lob and @Column
>>>>>> Nothing special:
>>>>>> Kai
>>>>>> name="testmodel"
>>>>>> upperBound="-1"
>>>>>> value="@Lob
>>>>>> </eAnnotations>
>>>>>> </eClassifiers>
>>>>>> value="@Lob
>>>>>> </eAnnotations>
>>>>>> </eClassifiers>
>>>>>> </ecore:EPackage>
>>>>>> </genClasses>
>>>>>> </genClasses>
>>>>>> </genPackages>
The Netherlands
Current Time: Sat Jul 19 21:59:37 EDT 2025
Powered by FUDForum. Page generated in 0.08919 seconds
