Home » Archived » BIRT » BIRT Viewer Gets Disabled after rendering contents from datasets(BIRT Viewer Gets Disabled after rendering contents from datasets)
BIRT Viewer Gets Disabled after rendering contents from datasets [message #1183240] Tue, 12 November 2013 13:45 Go to next message
BIRT Viewer gets disabled when the report contents displays the dataset rows..
IE 9
Re: BIRT Viewer Gets Disabled after rendering contents from datasets [message #1199417 is a reply to message #1183240] Wed, 20 November 2013 16:05 Go to previous messageGo to next message
Can you explain more about what you're seeing? I'm not quite sure I'm understanding.
Re: BIRT Viewer Gets Disabled after rendering contents from datasets [message #1200007 is a reply to message #1199417] Wed, 20 November 2013 22:45 Go to previous messageGo to next message
This issue got resolved. The issue was we had our build which was using 2.4 WebContent and the reports were designed on v 4.2 . Later I replaced WebContent with 4.2 version.
fyi:
The reports rendering is fine but the tool bars (print, export to excel..) were disabled and this was due to old version of WebContent
Re: BIRT Viewer Gets Disabled after rendering contents from datasets [message #1201353 is a reply to message #1200007] Thu, 21 November 2013 12:58 Go to previous message
Thanks for the update! Let us know whenever you have questions! Smile
Previous Topic:can't edit data source url
Next Topic:Making dynamic bar chart series stack?
Current Time: Sun Jul 20 08:09:39 EDT 2025
Powered by FUDForum. Page generated in 0.26315 seconds
