Home » Modeling » Papyrus » Getting rid of Xtext (I think it is...)
Getting rid of Xtext (I think it is...) [message #1195970] Tue, 19 November 2013 02:17 Go to next message
In several places, ports, state transitions etc, there is a popup allowing me to edit some values of the element. However there seem to be bugs that affects this display (see attached image). While I guess these bugs are well known, is there a way to turn off this function completely?
I have tried to identify any related setting but failed.
Tomas Sandkvist
Re: Getting rid of Xtext (I think it is...) [message #1200661 is a reply to message #1195970] Thu, 21 November 2013 05:46 Go to previous messageGo to next message
There are indeed known Xtext bugs which appear to be being worked on.
IIRC it was bad in Kepler but has not been causing me trouble since M2.
These appear to be synchronization issues where parsing happens at
inappropriate times. However the same message may occur genuinely if the
support for an Xtext grammar is inadequate; I have certainly fixed some
OCL bugs, but I don't think that the OCL parser should be in background use.
The error log should provide a stack trace that identifies the offending
grammar. Raise a Bugzilla against the problem component.
Ed Willink
> Regards,
> Tomas Sandkvist
Re: Getting rid of Xtext (I think it is...) [message #1201196 is a reply to message #1200661] Thu, 21 November 2013 11:23 Go to previous messageGo to next message
Hi Tomas,
The advanced editors can be disabled in the preferences:
Window > Preferences > Papyrus > Embedded editors
Camille
Re: Getting rid of Xtext (I think it is...) [message #1201362 is a reply to message #1201196] Thu, 21 November 2013 13:02 Go to previous message
Hi Camille,
Ok, I have found that but I still can't understand how to turn them off?
Not all editors has any options that look like an on/off flag, and even those that have, it says something like activate compiler. I thought the umlPortEditor was the right one for ports so I tried to deacativate the compiler but that made no difference in the diagram?
Tomas
Previous Topic:Problem with SysML Stereotypes and DirectedCompositions
Next Topic:MARTE timedConstraint Mode
Current Time: Sat Jul 19 08:21:05 EDT 2025
Powered by FUDForum. Page generated in 0.09427 seconds
